Cleveland, OH - HDTV - Page 228 - AVS Forum | Home Theater Discussions And Reviews
 222Likes
post #6811 of 6828 Old Yesterday, 01:00 PM
Trip in VA's Avatar
Quoted: 360 Post(s)
Liked: 113
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
Originally Posted by Bismarck440 View Post
Similar, (correct??) anything with those fading & floating images, popups & boxes wreak havoc with any of my machines, at home or at work.
If you're seeing the map at all, then JavaScript is working. I can't tell you, though, why the map image isn't showing up.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #6812 of 6828 Old Yesterday, 05:56 PM
Michael P 2341's Avatar
Quoted: 120 Post(s)
Map image works for me. WEKA is green out to the Euclid/Willowick border, and south to most of Parma.
I'm afraid to rescan to get it if it's a virtual 27 since I get WKBN full-time.
OTA Newbie likes this.
Michael P 2341 is offline
post #6813 of 6828 Old Yesterday, 06:38 PM
snowdog 88's Avatar
Quoted: 408 Post(s)
Liked: 55
The addition of WEKA-LD on 27 should not interfere with WKBN as the RF channels are different. However, results will vary depending on the manufacturer of your TV/converter box. Here are some examples on what may happen...
WEKA's channels maybe mixed in with WKBN's on your TV/converter box, so you might see something like this:
27.1, 27.2, 27.2, 27.3, 27.3, 27.4
Some TV's/boxes may insert the other station's channels before or after, depending which one the TV finds first. (Zenith boxes will do this). So you might see something like this:
27.2, 27.3, 27.4, 27.1, 27.2, 27.3
Or a combination of both:
(Red = WKBN, Blue = WEKA)
Worst case scenario would be the TV overwriting WEKA with WKBN when the rescan reaches RF 41. It's probably unlikely that this would happen, but I have seen it happen on a SONY HDTV with WOIO, probably because the PSIP data for their repeater is the same as their full power.
Newer is not always better.
snowdog 88 is online now
post #6814 of 6828 Old Yesterday, 07:17 PM
Trip in VA's Avatar
Quoted: 360 Post(s)
Liked: 113
Or WKBN failing to overwrite WEKA. Or WKBN being pushed to 70-1 or 41-1, or any number of other unexpected behaviors. Overlapping virtual channels should be handled in the way you describe, but not all receivers handle it correctly.
I grabbed an e-mail address from a filing for WEKA-LD and asked them to consider moving to 41-1.
- Trip
snowdog 88 likes this.
N4MJC
RabbitEars
post #6815 of 6828 Old Yesterday, 07:56 PM
Andrew K's Avatar
Quoted: 470 Post(s)
Liked: 78
When I scan, I get WYFX-LD and WOIO (both the Akron repeater & Cleveland main signal) all on virtual channel 19. Why hasn't WYFX ever considered using a different virtual channel? And it probably causes issues with WPCW (virtual 19) on the other side, closer to Pittsburgh.
Andrew K is offline
post #6816 of 6828 Old Today, 03:20 AM
Trip in VA's Avatar
Quoted: 360 Post(s)
Liked: 113
Likely because nobody ever complained. But WYFX-LD should probably be 62-1, which I believe matches its last analog channel before converting. (Right?)
- Trip
N4MJC
RabbitEars
post #6817 of 6828 Old Today, 08:04 AM
Bismarck440's Avatar
Quoted: 550 Post(s)
Liked: 108
Not the brightest bulbs making the rules (?) then again it's a non issue since "everybody has cable".
The virtual 41 on WEKA would make sense too. Per Antenna Fool, 27 is suppose to be quite a bit stronger out here than 16, yet both my dad & I (being a few miles apart) don't get it (even with his rotor & adjustments only gets to a 13-14 db max), so if they are running at full power, fool is incorrect ... now why doesnt that surprise me when I'm suppsose to get VIZ's repeater on 38 with an indoor?
Correct Trip I believe Fox Y-Town was a LP on 62.
- Trip
I would expect you folks in Akron/Parma to now have 2 27-2 & -3s? likely correct? When I picked up the 55 out of Ft Wayne, I had 2 55-1's.
Something changes, all the Maps used to work, not even all the ones at the FCC work (some still do),
I checked months ago, WEKA should be throwing a better signal my way.
Bismarck440 is online now
post #6818 of 6828 Old Today, 09:05 AM
snowdog 88's Avatar
Quoted: 408 Post(s)
Liked: 55
- Trip
Maybe WYFX thought they would be forgotten at the upper end of the allocation if they kept virtual 62? To me, it seems like all new stations after the transition use the RF channel for their virtual. Wasn't there an issue with WJLP in New York using virtual 3.10, thus making viewers believe the channel was being broadcasted from a neighboring virtual 3 station?
post #6819 of 6828 Old Today, 09:50 AM
Trip in VA's Avatar
Quoted: 360 Post(s)
Liked: 113
Maybe they did think that, but mapping to 19-1 wasn't the right answer. The PSIP standard specifies 62-1 in the case of WYFX-LD.
As far as WJLP, yes, and the FCC has ruled against WJLP (requiring them to use 33-1) and WJLP has appealed.
- Trip
N4MJC
RabbitEars
post #6820 of 6828 Old Today, 10:07 AM
Andrew K's Avatar
Quoted: 470 Post(s)
Liked: 78
WOAY TV in West Virginia was on channel 4 analog. Then when they got a digital channel on 50, they re-branded from channel 4 to WOAY TV 50. I'm not sure what the logic was behind that.
Andrew K is offline
post #6821 of 6828 Old Today, 10:23 AM
Quoted: 550 Post(s)
Liked: 108
Does WYFX still identify themselves with the "TV 62" Branding or did they ever?
Since WAOC took on new calls & format post transition, they took on 47 as their Virtual Channel, & dropped 67.
Then there is 61, which for some reason on my main set, reprogrammed itself to 34-3 after the addition of Get & Escape which took on correctly 61-3 & 61-4.
The correct thing to do?
A few I have spoke with think OTA is gone because of the virtual channel assignments, it's confusing to them, just like the concept of this "texting" thing is confusing to me!
post #6822 of 6828 Old Today, 10:24 AM
snowdog 88's Avatar
Quoted: 408 Post(s)
Liked: 55
New ownership perhaps? Or was it a separate application like W35AX/W16DO?
Remember WRLM dropped 67 and used the RF channel for the virtual when they bought WOAC from Multicultural Television, probably so viewers will find them while channeling from 43 to 49. (Probably thought no one would channel past 55).
post #6823 of 6828 Old Today, 10:42 AM
Quoted: 120 Post(s)
- Trip
I had to reload the page to get the full map with Longly Rice (using Safari on an iMAC). It comes up faster at work using Firefox on a PC. In any event the coverage map looks exceptional (large "green" area covering the majority of Cuyahoga County) considering the location of the antenna.
Trip, I have a question about WEKA. How can they have Canton as their COL when none of their applications cover Canton? Also with the Cleveland signal lit-up, does that preclude them also lighting up the other application in Medina County?
I wonder why they skipped 27.1? Is DTV America the group that wanted to use the spectrum for wireless broadband?
Finally I have been watching 27.3 "Buzzr" and have yet to see a legal ID.
post #6824 of 6828 Old Today, 10:58 AM
snowdog 88's Avatar
Quoted: 408 Post(s)
Liked: 55
27.1 is likely reserved for Telemondo or Dr TV.
I haven't seen any onscreen ID's either. I guess that's why their calls are in all the labels.
At least the time is set correctly.
post #6825 of 6828 Unread Today, 11:46 AM
Trip in VA's Avatar
Quoted: 360 Post(s)
Liked: 113
Beats me. That one was a puzzler if I've ever seen one. Of course, according to the FCC, WOAY should be 4-1.
Neither.
The maps are very big in terms of file size, which does make them take a while to load on slower connections. And I know on older computers it can be a big sluggish trying to display that massive image over a map like that, but it's really the only way to get such a highly-detailed map that people can zoom in on down to their own houses.
It's all in reading carefully and understanding how it works. WEKA-LD has three "active" filings. One is a license, for a previous facility. One is a permit, for the new facility. And the final one is a "pending license" for the new facility. Once the pending license ("license to cover") is filed, the station can operate the facility noted in the permit and turn off the previously licensed facility, if it has one, until its license is granted for the new facility, at which point it is now licensed for that facility. So only one of the transmitters on file can operate at a given time. What WEKA-LD did here is "hop" its way in. Its initial permit was granted far away, and the rules allow an LPTV station to move 30 miles at a time, but each step must be licensed. So, like a game of hop-scotch, one step at a time, WEKA-LD moved into Cleveland through the series of filings everyone saw.
As for city of license, there is no requirement in the LPTV rules that an LPTV station cover the community of license. The logic behind this is that, in theory, an LPTV operating at a few watts could cover just a small neighborhood within a community of license, and you wouldn't want a station on a low budget to have to cover more people than necessary. Of course, in practice, you can wind up with things like you see here where the station is actually located nowhere near the community specified.
You're probably right that 27-1 is reserved for programming that has not yet launched. And yes, it's the same DTV America.
LPTV stations are only required to ID maybe once a day (I don't remember) but I have heard that having the call sign in the PSIP is supposed to count for LPTV stations.
- Trip
N4MJC
RabbitEars
post #6826 of 6828 Unread Today, 12:37 PM
Quoted: 550 Post(s)
Liked: 108
- Trip
WVIZ's translator is in Thompson, COL Eastlake, doubtfully the signal would ever make it there.
So is WEKA running their full power yet or are they just in the testing stages?
post #6827 of 6828 Unread Today, 01:33 PM
snowdog 88's Avatar
Quoted: 408 Post(s)
Liked: 55
I'd have to say they're at full power. ~3.4 kW is being sent in my direction, which makes reception here a tad bit stronger than WVIZ's 1 kW digital broadcast that was being broadcast from their former studios in Parma.
post #6828 of 6828 Unread Today, 03:54 PM
Quoted: 550 Post(s)
Liked: 108
Well there's another disappointment, looked like they were going to serve the NE viewing area. Was looking forward to Buzzr.
