Cleveland, OH - HDTV - Page 242 - AVS Forum | Home Theater Discussions And Reviews
 263Likes
post #7231 of 7242 Old 07-19-2016, 02:55 PM
Michael P 2341's Avatar
Quoted: 145 Post(s)
Originally Posted by Andrew K View Post
A couple weeks ago, I finished my remotely controlled antenna setup in Doylestown. So whenever there is any tropospheric ducting, it shows me what signals are being received there. The location is ideal since it’s on a high elevation and just outside of Akron in a low-noise area. It seems to do a good job picking up Columbus and Pittsburgh just about every night. This morning, it was receiving a couple channels from Lexington Kentucky (WTVQ and WDKY). It should be interesting to see what a good location like this can do. Here is a list of last night’s scan (see attachment). All signals lead to Doylestown.
In Doylestown there is an amateur radio repeater that I can hit with full quieting from Parma. By any chance is your remote set-up associated with this repeater?
Michael P 2341 is online now
post #7232 of 7242 Old 07-19-2016, 07:43 PM
Andrew K's Avatar
Quoted: 529 Post(s)
Liked: 97
No, my brother just bought a house in Doylestown, and I convinced him to allow me to install an XG91 UHF antenna on his roof. I can remotely control it using a program called TeamViewer. I have a laptop hooked up to the antenna rotator, and when I remotely log in to it, I can rotate the antenna whichever way I want to. It's hooked up to an HDHR computer based tuner and special scanning software that logs everything it receives. The software uses the tuner to continually scan all the channels 24/7. The elevation at his house is 1250', which is one of the higher points around the area. All tropo leads to Doylestown it seems. I was even picking up WOWK RF 13 from Huntington WV with just a UHF antenna there. Here is a screenshot of what the desktop looks like when I log into the remote laptop at his house...
Andrew K is offline
post #7233 of 7242 Old 07-20-2016, 08:49 AM
Quoted: 145 Post(s)
Impressive! It appears that Doylestown is 29 miles due south of the WKYC tower (O deg.) and 360 deg. from WBNX.
post #7234 of 7242 Old 07-20-2016, 09:09 AM
Bismarck440's Avatar
Quoted: 627 Post(s)
Liked: 122
Doesn't that all depend on your antenna setup, elevation, power & what band? It's been so long since on, I forgot the specifics.
It's Akroncentric!
You might also like........
Bismarck440 is offline
post #7235 of 7242 Old 07-20-2016, 09:30 AM
Quoted: 145 Post(s)
It's Akroncentric!
I've got a discone 28' high and 50 watts on 2 meters. When tropo was up I hit a repeater in Indiana on the same frequency as a repeater in Massillon (145.18). Some of my ham friends called discone antennas "dummy loads". They may not have gain, but they do get you on the air.
I know someone who used as discone for a TV antenna! It probably would not work back in the analog days, but with digital it did work for him in North Royalton.
post #7236 of 7242 Old 07-20-2016, 09:49 AM
Quoted: 627 Post(s)
Liked: 122
I had to refresh my memory on the discone, I used to use a Ringo Ranger on 2M, & a home made ground plane on 440.
North Royalton, that's practically sitting on the farm.
It's Akroncentric!
post #7237 of 7242 Old 07-20-2016, 11:25 AM
Quoted: 145 Post(s)
Just checked the Hepburn site. Friday & Saturday should be an interesting time in N.E. Ohio for Tropo!
(Edit)The link I took of the Saturday 7/23/16 1200 GMT Hepburn prediction changed to one of Sunday's, so I removed it. The Saturday map showed a small pink area right over NE Ohio and orange spreading out over a larger area. I was able to hear several Detroit FM stations in my car on my drive into work this morning @7 AM. I even got perfect reception of a Detroit station that was a 1st adjacent channel to WCRF (103.5 WMUZ). Both stations came in perfectly on my car radio including the RDS information.
snowdog 88 likes this.
post #7238 of 7242 Old 07-21-2016, 09:48 AM
Quoted: 627 Post(s)
Liked: 122
WEKA seems to come in good in the overnight hours & goes away in the daylight.... not that anyone else here is an insomniac.
It's Akroncentric!
You might like........
post #7239 of 7242 Old 07-21-2016, 10:35 AM
Quoted: 145 Post(s)
It's Akroncentric!
It may be a vampire station
post #7240 of 7242 Old 07-21-2016, 12:54 PM
snowdog 88's Avatar
Quoted: 485 Post(s)
Liked: 62
It's Akroncentric!
Improved reception here at night also. Let's see if WEKA comes in like a local on Friday & Saturday.
Newer is not always better.
snowdog 88 is online now
post #7241 of 7242 Old Yesterday, 09:17 AM
Quoted: 627 Post(s)
Liked: 122
It's Akroncentric!
Hey, I resemble that remark!
Saturday AM:
That would be about 7AM?, & what is before & after that?
It's Akroncentric!
You may like........
post #7242 of 7242 Old Today, 08:05 AM
Quoted: 145 Post(s)
It's Akroncentric!
Actually 8AM, however when I post a link tot he Hepburn site it changes rather than becoming a snapshot. See my edited comment above. We were "in the pink".
