Cleveland, OH - HDTV - Page 245 - AVS Forum | Home Theater Discussions And Reviews
 270Likes
post #7321 of 7349 Old 08-11-2016, 06:22 PM
Andrew K's Avatar
Quoted: 547 Post(s)
Liked: 103
Nebraska and Saskatchewan received this evening here in Akron Ohio (attached photos).
ID:	1597865   Click image for larger version
Andrew K is online now
post #7322 of 7349 Old 08-14-2016, 07:12 PM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
Is anyone having issues receiving WOIO's RF 10? (Those who can normally receive it without problems).
I'm not experiencing any breakups, but I've noticed lately (last 4 days) that their signal doesn't seem to be as strong as it should be. (SNR is currently at 27.5 dB, normally up to 31 dB).
Newer is not always better.
snowdog 88 is online now
post #7323 of 7349 Old 08-14-2016, 08:59 PM
CleCakYngMfd's Avatar
Quoted: 376 Post(s)
Liked: 70
How's does that SNR translate with the signal level?
I do believe that this season's weather pattern for much of the summer is messing with my TV52's signal. Not as strong with some bad break-ups due to dipping to the 40's and 30's at times.
52 was bad for me at 9am and ok enough at 9pm today.
I'll have to survey the other OTA channels and see if I can detect other signal reductions.
I don't recall having this much trouble last summer.
- Pj
My Model-Specific Message Threads with Settings for the 2016 Vizio P50-C1 & the XR6P10 Tablet.
(The Above Needs Updating - Hopefully during August.)
Post Number One of the Main 2016 P-Series Message Thread - Continually Updated with Info.
CleCakYngMfd is offline
post #7324 of 7349 Old 08-15-2016, 07:49 AM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
Signal level is in the high 70's, normally 100.
When I first caught this, it was raining heavily and storming outside, so I thought the weather was to blame. The one day when we had all that lightning (when Andrew noted WQHS was off air/reduced power), WOIO went out twice for several seconds as if their tower got struck. The signal has recovered a few times since then, but it now seems to be reduced. 8 seems fine, so I don't think it's my antenna/setup.
I don't think I'm receiving interference from CFPL. If I did, it would only be temporally and not an all day thing.
post #7325 of 7349 Old 08-15-2016, 07:47 PM
Quoted: 376 Post(s)
Liked: 70
...Signal level is in the high 70's, normally 100...
I'm thinking it's this year's wx pattern with all this heat/humidity/ and temperature inversion capping, etc. A quick check shows my OTA signals are not quite what they were last summer. Maybe it's the ChemTrailing or a large influx of evil spiritual entities messing-up signal levels. It's the End-Times, you know.
Maybe something from space is coming our way. NASA just said they're shutting down the ISS video feed to the public come Sep 1st, 2016.
My friend in Tallmadge says he does not see the 'Greenies' (OTA) with today's RifleGuy. It looked real bad to me with greens and pinks throughout, plus the Green Pulsing.
My friend's TV is a Toshiba (24"). Could some tuners be 'holding back' on the Greenies while others let it fly through?
- Pj
post #7326 of 7349 Old 08-16-2016, 09:14 AM
nsa1062's Avatar
Quoted: 85 Post(s)
Nope, no issues here (NW of Medina)
nsa1062 is offline
post #7327 of 7349 Old 08-16-2016, 01:10 PM
Andrew K's Avatar
Quoted: 547 Post(s)
Liked: 103
Maybe WOIO tweaked its signal to send more of it toward Akron and less toward Bismarck's house
OTA Newbie likes this.
post #7328 of 7349 Old 08-17-2016, 05:18 AM
dleising's Avatar
Quoted: 18 Post(s)
Anyone having issues with WEWS this morning? Was strong for me then went completely dead.
dleising is online now
post #7329 of 7349 Old 08-17-2016, 05:27 AM
dleising's Avatar
Quoted: 18 Post(s)
Its back now, although the signal is all over the place.
post #7330 of 7349 Old 08-17-2016, 09:04 AM
Andrew K's Avatar
Quoted: 547 Post(s)
Liked: 103
It's the tropo affecting it. It could be that CHCH or WPSU is wiping it out. I just had WJET Erie decode OVER WOIO's Akron repeater. Toronto and Buffalo DTVs were strong this morning.
post #7331 of 7349 Old 08-17-2016, 09:08 AM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
Sounds like the same problem I have with WUAB from time to time.
I get an average signal strength of 84% with WEWS. Should be much higher with their 1000 kW signal. Heck, even W16DO blows them away with their 10 kW signal with a strength of over 95%.
post #7332 of 7349 Old 08-17-2016, 12:39 PM
Quoted: 376 Post(s)
Liked: 70
Don't know about this morning, but during the Brownz Pee-Wee game last week, TeeVee Dead-on-Five was busting up, pixelating, and dropping-out at times. This is from local Cable. I record/watch TV3 News at 7pm (1080i) and do not see this problem. I think I'll setup a recording session for Thursday's Brownz Pee-Wee game. Maybe, just maybe they can for once, produce a technical problem-free production... let alone any signal reception problem.
Speaking of news... be it TV3 or the other locals... why do they show a lot of non-local clips in SD? Looks horrible on my 50" screen. Same for sports 'lowlights', such as WOIO with ugly compressed video artifacts.
- Pj
post #7333 of 7349 Old 08-17-2016, 04:08 PM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
Can't say about the non-local clips, but remotes are now mostly done through the internet and 3G/4G connections, hence the bad compression artifacts and low definition quality. This makes the newscasts look unprofessional as if the cameraman is using his iPhone to transmit the report back to the station.
Are radio stations using the internet as a STL? Listen very closely to some of the big name FM stations (not in HD) and you'll hear compression artifacts in the audio. Are they doing this because of iHeartRadio or because they can avoid the relicensing of their microwave STL?
post #7334 of 7349 Old 08-17-2016, 09:41 PM
Gary16's Avatar
Quoted: 31 Post(s)
Is no one at WOIO monitoring the audio levels on 19.2? The overall level is low but their local inserts are at least twice as loud. This definitely violates FCC rules as well as my eardrums.
Gary16 is offline
post #7335 of 7349 Old 08-17-2016, 10:06 PM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
I e-mailed the engineer about this two months ago when the same problem occurred! The levels were promptly fixed, but I noticed they dropped back down sometime Tuesday afternoon.
post #7336 of 7349 Old 08-17-2016, 10:13 PM
Gary16's Avatar
Quoted: 31 Post(s)
[QUOTE=I e-mailed the engineer about this two months ago when the same problem occurred! The levels were promptly fixed, but I noticed they dropped back down sometime Tuesday afternoon.[/QUOTE]
Any chance you can email again?
Gary16 is offline
post #7337 of 7349 Old 08-18-2016, 09:24 AM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
http://www.cleveland19.com/story/149455/management (Under managers, send an email to engineering).
post #7338 of 7349 Old 08-18-2016, 09:31 AM
Bismarck440's Avatar
Quoted: 642 Post(s)
Liked: 124
What, not an all year thing?
in the past year I've seen WTOL more than WOIO, & that has only been a half dozen times.
They apparently did, about a year ago.
I have yet to see much Tropo this year, except for the negative effects, something has been eroding WJW's signal for me in the past 6 weeks or so.
No Erie yet this year. (for as clse as I am)
is WEWS getting the Browns games this year or just Pre Season?
Sent from a desktop PC with Windows 7
You may like...... Ads, with misleading links & more flash content!
You may also like.... Ads that cover what you are trying to read
You may also like.... Jerky & unresponsive script
You may also like.... Browser windows that restart after being closed (so you may read advertising content you may have missed).
For "the best" viewing experience... please "upgrade"...... Google Chrome
Bismarck440 is offline
post #7339 of 7349 Old 08-18-2016, 11:50 AM
unclehonkey's Avatar
Quoted: 224 Post(s)
Liked: 41
just pre-season.
unclehonkey is online now
post #7340 of 7349 Old 08-18-2016, 12:48 PM
Michael P 2341's Avatar
Quoted: 150 Post(s)
What you are hearing is the audio watermark for the "People Meter". It sounds like a very short digital delay effect. It's actually a pair of tones that gets mixed into the audio. The people meter uses these tone to ID the stations that are being listened to, and then use that data to generate the ratings.
I noticed that all I Heart Media stations use these tones when I drove to Columbus. I switched from WTAM to WTVN during The Rush Limbaugh show. I heard a similar but obviously different tone coming from WTVN.
Making matters worse stations use this device to make sure the watermark is always heard above whatever is in the program audio at any given moment.
I also believe Sirius XM is using watermarks as well. I used to blame the low bit rate they used on their satellite, but what I'm hearing is very similar to what I hear on both AM & FM stations. Non-commercial stations are probably the only ones left not using watermarks.
Michael P 2341 is offline
post #7341 of 7349 Old 08-18-2016, 01:23 PM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
A splitter that I recently replaced in order to improve reception on my RCA DTA880 was degrading WOIO's signal as well as as a few other stations. Signal strength is now back to where it was before after switching the faulty one out.
post #7342 of 7349 Old 08-18-2016, 02:01 PM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
Interesting... They are probably losing listeners to Sirius XM and internet radio and what more accurate rating numbers? Of course, this only applies to streaming platforms?
I don't blame them. Terrestrial radio is doomed! Doomed I tell you! Stations still can't figure out why people are listening to other sources for their music. Half of them sound exactly alike and play the same awful music over and over again! No variety or genre anymore that makes a particular station stand out! Won't be long until radio stations drop all local personalities and affiliate themselves with a 24/7 iHeart network. Oldies are slowly dying out from broadcast radio. Youngstown listeners are still bickering over the shift to country on WBBG 106.1. Really nothing for me to listen to since WDOK dropped it's soft rock format and went to New/Star 102. (Yuck!). I keep WMJI on in the car but rarely pay attention to it. (Songs are TOO repetitive, DJ's NEVER shut up, audio processing PUSHED to the limit). Because of the bad selection of stations in our area, I often listen to my own CD's or iPod instead. (Sometimes Real Oldies on iHeart Radio), but that's it.
post #7343 of 7349 Old 08-18-2016, 10:11 PM
Quoted: 376 Post(s)
Liked: 70
And now, some great one-liners by SnowDog...
Stations still can't figure out why people are listening to other sources for their music...
Youngstown listeners are still bickering over the shift to country...
Songs are TOO repetitive...
DJs NEVER shut up, audio processing PUSHED to the limit...
I often listen to my own CD's or iPod instead...
That first line had me going. Funny.
Once upon a time, I became familiar with 'Podcasts' and iTunes... then the AM/FM radio stations of the world 'died' in my little world.
I have an iFartRayDeeOh App on my Vizio Tablet, but I only got as far as the opening screen to 'Sign-in or Register'. No way. So I have the 'Tune-in Radio' App. It has pop-up ads and 30-second audio ads at times before playing my selection. I would've paid for it, but not at $10 per month.
I did one-time pay for three Apps. One is a 'storm-chasing' type Radar App. Another is a radio scanner App. The third is a scanning radio scanner program for my Win7Pro desktop.
I've been tortured enough over the decades by commercial radio and TV. No more. Sometimes, technology comes by for the rescue.
- Pj
post #7344 of 7349 Old 08-19-2016, 09:45 AM
Quoted: 642 Post(s)
Liked: 124
Tut tut, it's true then, people really want to & are willing to pay for something they could get for nothing.
I seldom listen to music on radio except for possibly WNCX/WZAK on Sat nights & Dee Snyders Metal program on Sunday Evening. "Pop" music really don't appeal to me anymore (what actually is mainstream top 40??), not to mention the ever increasing advertising content. ... I miss Disco, & when R&B really was R&B
I listen to the Fan in the car, but even that gets old.... bad enough I dislike being in a car.
Edit, Don't you all just play with your electronic handheld devices, & are too busy for Radio?
Sent from a desktop PC with Windows 7 (or lower)
post #7345 of 7349 Old Yesterday, 01:39 PM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
So... What happened to channel 25?
Was watching it and then it lost all PSIP data. Now I'm with channels 26-3, 26-4, 26-5, 26-6 and 26-9 with no labels.
RCA DVR only lets me view 25-1 (26-3) and now has a goofy label of PR60003.
post #7346 of 7349 Old Yesterday, 05:46 PM
Quoted: 376 Post(s)
Liked: 70
I just checked on 25 moments ago by doing a 'ReScan' (Wipes out all, start afresh) with my ClearStream-4 pointed North.
I got everything, except 21 and 33 and 'I Hate Eight' 8. Good signals tonight. 25 is ok for me with PSIP/Guide/Numbers. You might want to 'ReScan', but you say it was there and disappeared while watching, so perhaps the signal took a dip and that's how the RCA unit reacts? So it never came back, assuming the signal was there or came back?
- Pj
post #7347 of 7349 Old Yesterday, 06:26 PM
snowdog 88's Avatar
Quoted: 513 Post(s)
Liked: 62
All is fine now with WVIZ. When the PSIP came back, the RCA corrected itself.
post #7348 of 7349 Old Today, 09:46 AM
Andrew K's Avatar
Quoted: 547 Post(s)
Liked: 103
There was a massive red tropo blob invading the area yesterday. I checked, and it was mainly limited to VHF and FM. I saw CIII analog channel 2 from Bancroft Ontario @ 355 miles and also heard Majic 100.3 from Ottawa Ontario (420 miles).
post #7349 of 7349 Old Today, 10:29 AM
Andrew K's Avatar
Quoted: 547 Post(s)
Liked: 103
Speaking of bizarre PSIP with WVIZ, my auto-scanner shows that WVIZ had the PSIP of “WOSU” at one brief point in time, just long enough for the scanner to catch and me not to notice for my OTA viewing. This was a few weeks ago.
