Cleveland, OH - HDTV - Page 246 - AVS Forum | Home Theater Discussions And Reviews
 272Likes
post #7351 of 7360 Unread 08-25-2016, 04:27 AM
JJkizak's Avatar
Quoted: 79 Post(s)
Originally Posted by toby10 View Post
Very true. I haven't bothered even having an am/fm antenna in my home for many years. Local radio is absolute crap. DJ’s ramble on (cuz they think they are talented and funny but are not), too many commercials, playlists are repetitive, etc…
In my car I seldom listen to any broadcast radio. I drive a lot for business. During business hours I’m usually on the phone anyway, non-business hours I might listen to NPR or WTAM depending on the topic. Often I just BlueTooth my own music collection.
For home I stream many online stations, completely free. I have no subscription service at all (like Pandora or Spotify). One device I have streams internet radio 24/7/365. I primarily use two free services, both are “aggregators” of many online stations. ShoutCast and Radionomy. These offer many thousands of stations in every imaginable genre from all over the globe, mostly DJ and ad free, those with DJ’s and ads are far less frequent and intrusive than broadcast radio. Most of these offered stations are NOT re-broadcasts of terrestrial radio stations (which is the primary focus of iHeartRadio and TuneIn which are simply aggregators of terrestrial radio).
Sound quality on ShoutCast and Radionomy is good. Radinomy is all 128k (I think). ShoutCast is anywhere from 32k to 320k. But ShoutCast offers a “bitrate limiter” where you can set a minimum bitrate so any station offering less than your limit (minimum) is not shown in the menus and searches. Mine is set to 192k and still offers dozens of stations in any genre I’ve searched on.
One great online independent station is Radio Paradise. No ads, listener supported (but not required), excellent audio quality, extremely diverse playlist from Bach to Bachman Turner Overdrive and everything in between, DJ’s are excellent and rarely heard from.
I would like to know the bitrates of 98.5HD, 105.7HD, and 107.3HD. I believe 107.3 is greater than the other two.
JJK
JJkizak is offline
post #7352 of 7360 Unread 08-25-2016, 06:20 AM
toby10's Avatar
Quoted: 26 Post(s)
JJK
You'll have to try each and see. Often the station will offer several bitrates so you can choose which is better for your needs. If streaming to small ear buds and/or have a limited data plan then you can choose the lower bitrates (typically 64k). If you are streaming to a full stereo system you would generally want the higher bitrates (say 192k to 320k) as such a more robust setup would reveal compression and digital artifacts of the lower bitrate streams.
Try just searching for those stations on iHeartRadio.com or TuneIn.com as they usually display the offered bitrate and formats available (at least from their service). Bitrate alone is not the all deciding factor in audio quality but it is a generally good indicator. The format is important as well. Example a 64k AAC format will sound (aprox) equal to a 128k MP3 format, etc...
Also try emailing the stations of interest and ask for a "direct stream URL" which is a standard URL that any device can play without having to be on the stations web site. Often these are unpublished higher bitrate URL's but are available upon request. But then just as often these are not even an offered option from a station (or they don't understand what you are asking for).
toby10 is offline
post #7353 of 7360 Unread 08-25-2016, 06:56 AM
JJkizak's Avatar
Quoted: 79 Post(s)
I'm running Klipsch corner horns with Denon X-4000 and they do reveal a lot of stuff.
JJK
JJkizak is offline
post #7354 of 7360 Unread 08-25-2016, 08:05 AM
toby10's Avatar
Quoted: 26 Post(s)
JJK
Indeed. Same here with a Yamaha to Paradigm Studio's. At the 192k+ level you are basically at FM quality as far as the human ear is concerned. If you like WDOK's offerings I'd seriously look into ShoutCast genres for easy listening/lite rock at 192k+. Once you get spoiled with few or no commercials and a wider/diverse playlist you'll *cringe* every time you have to listen to broadcast radio in your car.
toby10 is offline
post #7355 of 7360 Unread 08-25-2016, 09:01 AM
JJkizak's Avatar
Quoted: 79 Post(s)
I will give them a shot. The first things I notice are the "breathy consonants" of shouting and multiple voices while other tracks are pristine. The Eagles, Heart, Joe Walsh, BG's, (just a few named) never have any problems. It seems the more compression and voice manipulation that is employed the more bitrate you need. One of the worst is the Beatles revolution guitar which sounds at times like a buzzsaw but not all the time.
JJK
JJkizak is offline
post #7356 of 7360 Unread 08-25-2016, 04:21 PM
snowdog 88's Avatar
Quoted: 516 Post(s)
Liked: 62
JJK
To me, HD-1 broadcasts sound like 96kbps MP3's and HD-2, 3, etc. broadcasts sound like 64kbps MP3's.
Sirrus XM sounds HORRIBLE for what you pay for. It's like a 48-56kbps web stream on dial-up. (I know, people meter).
You mean, what WDOK used to offer. (They're not soft rock anymore!)
I'll take a look into that, but I'm likely going be disappointed. Most of these custom radio services play "filler" or "B-side" songs that were never hits.
Newer is not always better.
snowdog 88 is offline
post #7357 of 7360 Unread Yesterday, 04:36 AM
toby10's Avatar
Quoted: 26 Post(s)
Shows you how little I use local radio. I don't even know their genre format anymore.
Many ShoutCast stations are dedicated exclusively to "hits". Just search "80's hits" (or whatever era you are interested in). Many cover multiple era's like 60's & 70's & 80's on one station, etc...
Other services with multiple streams/genres/era's to check out:
1.FM
181.FM
320KB (not all streams are 320k)
.977
Radionomy
toby10 is offline
post #7358 of 7360 Unread Yesterday, 05:33 AM
JJkizak's Avatar
Quoted: 79 Post(s)
What is the frequency of WDOK?
JJK
JJkizak is offline
post #7359 of 7360 Unread Yesterday, 08:27 AM
toby10's Avatar
Quoted: 26 Post(s)
Originally Posted by jjkizak View Post
what is the frequency of wdok?
Jjk
102.1
toby10 is offline
post #7360 of 7360 Unread Today, 12:18 PM
Andrew K's Avatar
Quoted: 547 Post(s)
Liked: 103
This morning at around 11:30, I checked my remote setup in Doylestown, and the DTV scan was showing Scranton/Wilkes-Barre decoding on RF channels 11 and 13 using just a UHF antenna... 303 miles. Here is what the scan results showed (see attached).
Andrew K is online now
