Cleveland, OH - HDTV - Page 280 - AVS Forum | Home Theater Discussions And Reviews
 364Likes
post #8371 of 8395 Old 03-17-2017, 05:44 PM
CleCakYngMfd's Avatar
Quoted: 888 Post(s)
Liked: 279
Originally Posted by Andrew K View Post
Here is my VHF antenna...
Awesome! Suhhhh-Weet pic, Andrew. Neat antenna and cool clouds.
I see the spot where you were sitting on the roof.
CleCakYngMfd is online now
post #8372 of 8395 Unread 03-17-2017, 06:14 PM
Quoted: 888 Post(s)
Liked: 279
Originally Posted by Michael P 2341 View Post
Is there any programming unique
to WGGN that is not also on WDLI?
I ... got an old web page telling people
that the analog signal is about to go away!
They haven't updated their "official" web
page since 2009!
Yes. Local stuff and some Pastor Rusty Sermons.
Also, there are a few Prophecy programs on WGGN that I don't have
here in the area, except the programs are available on their websites.
There were two of them briefly carried on TBN/WDLI, but TBN picked
up on the horrid HillCrap programming and dumped some
Prophecy content.
I don't know why there's not a redirect to WGGN's newer site:
www.CBMtoday.org - TV and Radio Stations
www.CBMtoday.org
They still have a Aug 2015 PDF Program Guide listed.
Discerning the Times with Pastor Rusty
post #8373 of 8395 Unread 03-17-2017, 06:45 PM
Quoted: 888 Post(s)
Liked: 279
Originally Posted by snowdog 88 View Post
Sadly, this is what CleCakYngMfd will need
on top of his house in order to continue receiving
WGGN, and even that won't be good enough if
he currently has issues receiving them on UHF.
I may need the ClearStream-5!
Name:	ClearStream5 - Large.jpg
post #8374 of 8395 Unread 03-17-2017, 07:21 PM
snowdog 88's Avatar
Quoted: 705 Post(s)
Liked: 75
I doubt that the CS-5 will catch enough of that low VHF signal. You need what Andrew has on his roof.
Depending how far you are from WGGN's transmitter, when they move to low-VHF, they will basically be the same as a low power UHF broadcast with added bonus of electromagnetic interference.
Newer is not always better.
snowdog 88 is online now
post #8375 of 8395 Unread 03-18-2017, 01:48 AM
ProjectSHO89's Avatar
Quoted: 248 Post(s)
Liked: 120
The C5 will not work for low-VHF, not what's made for. Where did you get that idea?
ProjectSHO89 is offline
post #8376 of 8395 Unread 03-18-2017, 06:22 AM
Quoted: 888 Post(s)
Liked: 279
Originally Posted by ProjectSHO89 View Post
The C5 will not work for low-VHF.
Not what it is made for.
Idea? Here:
Ok, I was dreaming that I might get away with the idea to use this model.
Perhaps home-brewed or I suspect manufacturers will be producing various Low, High, and Low/High VHF Combo antennas? Perhaps one day a C-5-Low?
I do have a NIB Radio Shark 15-1711 that I never got around to put in service, but this would be tough for an indoor setup.
How much estimated time before RF42 goes TV-dark?
Name:	Antennas Direct Review - CS5.JPG
post #8377 of 8395 Unread 03-18-2017, 07:05 AM
Quoted: 248 Post(s)
Liked: 120
You misinterpreted the above review post. "Channel 2 out in Chicago" is WBBM who transmits on VHF channel 12 which is in the design band for the C5, it's not a low-VHF station anymore.
A C5-like design (loop in front of reflector) for low-VHF could be done, you'd just need to re-scale it by a factor of around 3X-4X. Probably not something done in a reasonable manner, a 4 or 5 element low-VHF Yagi would probably be more feasible.
Michael P 2341 likes this.
post #8378 of 8395 Unread 03-18-2017, 07:21 AM
nsa1062's Avatar
Quoted: 183 Post(s)
Liked: 34
I was able to pick up WKYC (at nearly 100% signal strength) when it was on RF2 with this. It is mounted on a shed in the back yard only about 10-12 feet high. Unfortunately, it is no longer made but you might be able to find a used one somewhere like EBay:
https://www.amazon.com/Channel-Maste...ct_top?ie=UTF8
WKYC on RF2 was around 9KW then and I was about 25 miles away. YMMV.
With Low VHF whatever you have must be outdoors. With WKYC/2 an attic antenna (a Yagi that covered low VHF) was very flaky and no rabbit-ear type antenna worked at all.
Probably not until next year at the earliest. Could be as late as 2020.
nsa1062 is offline
post #8379 of 8395 Unread 03-18-2017, 07:29 AM
Andrew K's Avatar
Quoted: 714 Post(s)
Liked: 118
Whatever happened to an old-fashioned yagi antenna like the one I'm using? You can't find them sold anymore because people think they're too big and ugly. But the bottom line is... they work!! Good luck trying to find one. The antenna manufacturers have a hard time trying to sell them. My yagi was purchased from some guy in Pennsylvania who happened to have an attic full of old antennas he wanted to get rid of.
A few suggestions about receiving low-VHF signals... there is a lot of stuff that causes interference and trashes the low-VHF band. Sometimes the signal could be strong enough, but the signal would be made undecodeable from interference. I've found that I get interference from light bulbs particularly the CFLs with dimmable switches and 3-way brightness capability. Even my Keurig-style coffee pot interferes with all VHF, so I unplug it when not in use. Other sources include laptops and my 42" LCD TV upstairs. I have an old radio that tunes to 50 MHz, and I can carry the radio around the house and place it next to electronics to listen for interference.
Regarding WGGN's power of 1.42 kW on low-VHF... that seems too low. Most full-power DTVs on low-VHF are at least 3 kW. I wonder if that's the transmitter output and not the ERP.
Andrew K is online now
post #8380 of 8395 Unread 03-18-2017, 10:31 AM
Trip in VA's Avatar
Quoted: 609 Post(s)
Liked: 167
Send a message via AIM to Trip in VA
It's ERP.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #8381 of 8395 Unread 03-20-2017, 11:35 AM
snowdog 88's Avatar
Quoted: 705 Post(s)
Liked: 75
WRAP-LP is apparently back on the air, but it's only the analog signal that covers a few blocks in Shaker Heights and not the "full power" digital signal from Parma.
Maybe I should send a message to D.T.V. LLC and see if I can get more info about the future of WRAP.
post #8382 of 8395 Unread 03-20-2017, 12:48 PM
Andrew K's Avatar
Quoted: 714 Post(s)
Liked: 118
After the repack, I'd suspect that WRAP wouldn't be allowed to use digital channel 32 anyways. That would present problems with what we now know about WFMJ moving to channel 33, and someone else moving to 31 possibly WKBN.
post #8383 of 8395 Unread Yesterday, 03:02 PM
Quoted: 888 Post(s)
Liked: 279
post #8384 of 8395 Unread Yesterday, 03:11 PM
snowdog 88's Avatar
Quoted: 705 Post(s)
Liked: 75
WEAK 41 swapped Buzzr and Sonlife around. Now they are on the right subs according to their website and TitanTV.
Is it just me or do their channels now look twice as compressed as they did before?
They still haven't fixed the PSIP issue with my Samsung.
post #8385 of 8395 Unread Yesterday, 03:26 PM
snowdog 88's Avatar
Quoted: 705 Post(s)
Liked: 75
How about this critter?:
I doubt it. That looks like a high-VHF antenna. You need a low-VHF antenna in order to receive RF 3. The elements need to be at least 7.8 feet long in order to capture the entire wavelength, and depending on how far you are from their transmitter, a pair or two of elements may not be enough to grab enough of the signal and overcome interference.
post #8386 of 8395 Unread Yesterday, 03:38 PM
nsa1062's Avatar
Quoted: 183 Post(s)
Liked: 34
Something like this
http://www.solidsignal.com/pview.asp?p=hd8200xl
Has between 5 and 6.7 dB gain at RF3
snowdog 88 likes this.
nsa1062 is offline
post #8387 of 8395 Unread Yesterday, 04:21 PM
Michael P 2341's Avatar
Quoted: 188 Post(s)
Liked: 25
Actually it looks like an FM Yagi. That picture is hard to tell without having the dimensions listed. The driven element of a single channel Yagi for Ch. 3 would need to be 7.6 feet long.
Michael P 2341 is online now
post #8388 of 8395 Unread Yesterday, 04:32 PM
Quoted: 888 Post(s)
Liked: 279
It's a Low-VHF Band Ch 2-to-6 (Ch-4 centered) antenna.
At the moment, I don't want a multi-band antenna. Just a dedicated Low-VHF type for TV52 (RF3).
  • 4.5 dB gain
  • Element width:110"
  • Boom length: 59"
  • Weight: 8.5 lbs.
post #8389 of 8395 Unread Yesterday, 04:32 PM
snowdog 88's Avatar
Quoted: 705 Post(s)
Liked: 75
Yeah, I should have known that it looked like a FM antenna.
I was slightly off on the length of the elements? I used this site to calculate the length. (63 MHz, half wave)
Online Conversion - Frequency Wavelength Calculator
post #8390 of 8395 Unread Yesterday, 04:42 PM
Quoted: 888 Post(s)
Liked: 279
Yeah, it 'looks' like some other Yagis I've seen that are FM, but the the elements on this Low-VHF aunt Tenna are longer (see my edited previous post for specs).
post #8391 of 8395 Unread Yesterday, 06:02 PM
Quoted: 248 Post(s)
Liked: 120
  • 4.5 dB gain
  • Boom length: 59"
  • Weight: 8.5 lbs.
If that is the Antennas Direct V4 antenna, it should do fine for channel 3.... unless you can find one of the really big Winegard or Antenna Craft low-V antennas that were discontinued a while back. If it's the V4, then it's a channel 4 Yagi hence the model name.
post #8392 of 8395 Unread Yesterday, 07:32 PM
Andrew K's Avatar
Quoted: 714 Post(s)
Liked: 118
ATSC 1.0 is terrible on low-VHF. It's difficult getting anything to reach the decode threshold. I've never had any luck getting low-VHF DTV tropo to decode here even with that massive antenna I use. Last September, I almost had WLMB 5/40 Toledo (see photo). The signal bar was 50% with no decode... very annoying. WGGN probably won't be much better.
post #8393 of 8395 Unread Yesterday, 08:03 PM
snowdog 88's Avatar
Quoted: 705 Post(s)
Liked: 75
I've had WLMB decode here a couple times, even with my crippled antenna which lost most of it's low-VHF elements. Tropo has to be extreme for WLMB to come in, which means WTOL & WTVG have to blast in like locals along with CBET.
Last year I had WJBK from Detroit decode over WCDN, which doesn't happen too often. When I did receive WCDN on a regular basis and it disappeared, that was an indication that the tropo was up.
post #8394 of 8395 Unread Today, 06:45 AM
nsa1062's Avatar
Quoted: 183 Post(s)
Liked: 34
Same here, WLMB often decodes during summer tropo, but it is always glitchy (even with no thunderstorms in the area).
nsa1062 is offline
post #8395 of 8395 Unread Today, 09:49 AM
Quoted: 888 Post(s)
Liked: 279
Indeed, it's the V4. Is it worth it at $65 delivered?
