Cleveland, OH - HDTV - Page 292 - AVS Forum | Home Theater Discussions And Reviews
 449Likes
post #8731 of 8919 Old 04-19-2017, 05:18 PM
Liked: 1
Originally Posted by lakeeriemonster View Post
From the west wall position:
WKYC 74
WEWS 74
WJW 80
W16.. 60
WDLI 40 (on and off)
WOIO 74
WQDI 54
WVPX 51
WVIZ 59
WEKA 60
WUAB 78
WEAO 39 (on and off)
WCDN can't pick up
WBNX 81
WQHS 85
This is as opposed to the north wall. Hope this helps someone using similar antenna.
I have tried the Leaf antenna like yours but it is the amplified one. It generally worked well but had difficulty with WEAO at my location which is why I went with the Clearstream 4. Since you are getting decent signals, possibly an amplifier would help unless it would overload your tuner. I only have found that one tuner (Magnavox DVD/DVR which is a Funai product) would sometimes overload with weak signals but it does have a built-in attenuator to correct that. My Sony tv, Insignia tv, Zenith converter box, RCA portable, none of these have a problem with overload with an amplifier.
With the Leaf, what sometimes works better is if you lay the antenna flat (horizontal) towards the direction you want as opposed to a vertical orientation. Use your signal strength meter to see if it works better but for distant stations, it made a difference for me.
jkeldo is offline
post #8732 of 8919 Old 04-19-2017, 05:27 PM
Quoted: 59 Post(s)
Liked: 8
Thanks for the tip jkeido. I will try that.
lakeeriemonster is online now
post #8733 of 8919 Old 04-19-2017, 06:10 PM
Quoted: 59 Post(s)
Liked: 8
I'm seeing rumors that Sinclair could be close to buying Tribune properties including local WJW. They are having a vote on ownership cap tomorrow. If it passes, deal could be complete by early May. Another company also making a bid on Tribune.
post #8734 of 8919 Old 04-19-2017, 06:11 PM
nsa1062's Avatar
Quoted: 236 Post(s)
Liked: 55
Just checked them and I totally agree, all of Ion's SD subs look atrocious now. They didn't look this bad yesterday or the day before.
Originally Posted by snowdog 88 View Post
I take back what I said. I rechecked WVPX's subs and they do indeed look very compressed. More so than the WEKA subs.
What happened? Did they suck out bandwidth from each channel and give it to 23.1? I can tell you that their .2 and .3 subs did not look as bad compared to what they are now. Looks like ION needs to buy some up-to-date encoders.
nsa1062 is offline
post #8735 of 8919 Old 04-19-2017, 06:33 PM
snowdog 88's Avatar
Quoted: 783 Post(s)
Liked: 87
I hope those rumors are false. I can already see Sinclair dropping Antenna TV and replacing it with one of their crappy networks.
Newer is not always better.
snowdog 88 is online now
post #8736 of 8919 Old 04-19-2017, 06:49 PM
Quoted: 59 Post(s)
Liked: 8
IF this happens, WJW would probably drop Antenna and pick up American Sports Network, Comet, Charge! and possibly TBD. Antenna would probably end up on WEKA or WQDI. It would also leave room on DTV to pick up some of the Sealsco networks.
post #8737 of 8919 Old 04-19-2017, 10:30 PM
Inundated's Avatar
Quoted: 130 Post(s)
Liked: 42
Keep in mind that Tribune owns Antenna TV outright. Would Sinclair (if they are the buyer) own the network or shut it down?
I sure hope that Sinclair doesn't pick up Tribune. Sinclair is a horrible owner, and its subchannel networks have zero appeal to me.
snowdog 88 likes this.
Inundated is offline
post #8738 of 8919 Old 04-20-2017, 08:06 AM
snowdog 88's Avatar
Quoted: 783 Post(s)
Liked: 87
I asked WJW when they were still owned by Local TV LLC if Antenna TV would be dropped if they were bought out by someone else. They told me that they would continue to carry Antenna TV regardless of the ownership.
Dropping existing diginets and making room for new ones would likely be a different story.
And yes, if WJW drops Antenna TV, it will likely be picked up by "can you see us?" DTV America.
Couldn't agree more.
post #8739 of 8919 Old 04-20-2017, 08:46 AM
Liked: 2
I wonder if WJW will ever add any more subchannels?
skiwest is offline
post #8740 of 8919 Old 04-20-2017, 09:10 AM
Quoted: 59 Post(s)
Liked: 8
I'm sure if Sinclair buys them they will. The Sinclair diginets are now on WQDI low power. Seals/Dinnan has 9 diginets they want to debut soon including an animal, movie, music and fashion channel. They could use the space vacated by the Sinclair stations on DTV America. Unless, Seals/Dinnan starts buying stations? Hmm.
post #8741 of 8919 Old 04-20-2017, 09:25 AM
snowdog 88's Avatar
Quoted: 783 Post(s)
Liked: 87
What's the purpose of launching all these new diginets? There's hardly any stations left with adequate bandwidth to carry these networks, and replacing the popular diginets will only result in backlash to both the station and the network. Give the least popular and the Sinclair diginets to DTV America's under-powered stations.
post #8742 of 8919 Old 04-20-2017, 09:30 AM
Quoted: 59 Post(s)
Liked: 8
Sealsco.com
Direct your question to them, the field does seem crowded now.
post #8743 of 8919 Old 04-20-2017, 12:16 PM
wd8kct's Avatar
Quoted: 89 Post(s)
This afternoon:
23-1 Ion 7-8 Mbps
23-2 Qubo 950 Kbps
23-3 IONLife 1.25 Mbps
23-4 Shop 1.20
23-5 QVC 1.20
23-6 HSN 1.20
0x1fff 4.1 Mbps (null packets or mDTV?)
wd8kct is offline
post #8744 of 8919 Old 04-20-2017, 01:31 PM
nsa1062's Avatar
Quoted: 236 Post(s)
Liked: 55
Hmmm, 4.1 Mbps null packets (I don't think WVPX has mobile DTV, according to RabbitEars only WKYC does). Sure looks like they are making room for one or both of the displaced religious stations' main channels (in SD).
Originally Posted by wd8kct View Post
This afternoon:
23-1 Ion 7-8 Mbps
23-2 Qubo 950 Kbps
23-4 Shop 1.20
23-5 QVC 1.20
23-6 HSN 1.20
nsa1062 is offline
post #8745 of 8919 Old 04-20-2017, 01:43 PM
nsa1062's Avatar
Quoted: 236 Post(s)
Liked: 55
Do you know if those are fixed rates? No wonder they look so bad. The artifacting is obvious even on a smaller-screen TV.
>> 23-2 Qubo 950 Kbps <<
Even WKYC's weather radar has a higher average bitrate (and it is variable/statmux).
This afternoon:
23-1 Ion 7-8 Mbps
23-2 Qubo 950 Kbps
23-4 Shop 1.20
23-5 QVC 1.20
23-6 HSN 1.20
nsa1062 is offline
post #8746 of 8919 Old 04-20-2017, 01:49 PM
CleCakYngMfd's Avatar
Quoted: 1004 Post(s)
Liked: 324
This afternoon:
23-1 Ion 7-8 Mbps
23-2 Qubo 950 Kbps
23-4 Shop 1.20
23-5 QVC 1.20
23-6 HSN 1.20
The TV 23 Subs look real bad when I first checked about 2 weeks ago, so maybe they're testing the different Mbps rates?
Anyway, what is the total Mbps rate per channel?
Oh, when I last did my OTA check from my Vizio P50-C1, I didn't realize TV61 has two 1080i channels. Looks real good.
What is the maximum Mbps for low or no compression 480i SD channel?
CleCakYngMfd is online now
post #8747 of 8919 Old 04-20-2017, 02:33 PM
Inundated's Avatar
Quoted: 130 Post(s)
Liked: 42
Saw a trade report that we could know about Sinclair/Tribune by May 8, and that Sinclair may only buy "parts" of Tribune. No word if that includes either WJW or Antenna TV.
http://www.fiercecable.com/broadcast...-8-report-says
But Local TV, which first put Antenna TV on its stations, was a close semi-sister of Tribune, which eventually bought Local TV outright. So, there was no danger of Antenna TV going away.
Now? Who knows?
Here's a twist: Trade reports say Fox may block Sinclair from buying Tribune. In order, yes, so Fox can buy Tribune itself.
And that would bring WJW back in the Fox O&O fold. Heh. (Unless it peeled off WJW again. I hope not to Sinclair!)
post #8748 of 8919 Old 04-20-2017, 03:25 PM
Quoted: 59 Post(s)
Liked: 8
What diginets do Fox own or have the rights to?
post #8749 of 8919 Old 04-20-2017, 04:08 PM
wd8kct's Avatar
Quoted: 89 Post(s)
The rates do vary a little.
wd8kct is offline
post #8750 of 8919 Old 04-20-2017, 05:02 PM
wd8kct's Avatar
Quoted: 89 Post(s)
Total ATSC 1 channel bandwidth is 19.39 Mbps.
Good looking MPEG-2 in 480i SD??? 2-3 Mbps???
MPEG-4 H.264(AVC) is supposed to halve that rate and H.265(HEVC) is supposed to halve that rate.
wd8kct is offline
post #8751 of 8919 Old 04-20-2017, 05:25 PM
Inundated's Avatar
Quoted: 130 Post(s)
Liked: 42
I think that they have a piece of Movies. That, of course, is on WBNX 55.3...
post #8752 of 8919 Old 04-20-2017, 06:13 PM
snowdog 88's Avatar
Quoted: 783 Post(s)
Liked: 87
23-2 Qubo 950 Kbps
Wow! That's pretty low!
Those compression artifacts really stand out on the toons. I don't ever remember 23.2 having such a compressed picture. If anything, they should have taken bandwidth away from the shopping channels.
I could only guess that DTV America is giving 1 MBPS to each of their channels. Can anyone verify this?
post #8753 of 8919 Old 04-21-2017, 08:43 AM
nsa1062's Avatar
Quoted: 236 Post(s)
Liked: 55
Looks like a fixed-rate encoder. Similar to what WOIO/WUAB use. A variable/statmux would jump all over the place.
WKYC's weather radar varies from under 1MB/sec (mainly when they are showing the radar screens) and can peak as high as 3 or 4 Mbps during the PSA's they show.
nsa1062 is offline
post #8754 of 8919 Old 04-21-2017, 08:49 AM
Trip in VA's Avatar
Quoted: 705 Post(s)
Liked: 200
Send a message via AIM to Trip in VA
That's weird. Every other time I've looked at an ION station, I've always seen variable bitrate. You do have averaging turned off in TSReader, right?
- trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #8755 of 8919 Old 04-21-2017, 11:20 AM
wd8kct's Avatar
Quoted: 89 Post(s)
- trip
Other channels show greater variation in bitrate. On some you can see how the bitrate of the subchannels mirror the main channel. Don't see an averaging setting on the active PID window. This is version 2.8.46a.
-Ed
wd8kct is offline
post #8756 of 8919 Old 04-21-2017, 11:36 AM
Trip in VA's Avatar
Quoted: 705 Post(s)
Liked: 200
-Ed
View > Chart > Settings > Real-time Charting should be checked.
I'll post what I'm seeing on WPXW when I get home.
- Trip
N4MJC
RabbitEars
post #8757 of 8919 Old 04-21-2017, 04:10 PM
wd8kct's Avatar
Quoted: 89 Post(s)
- Trip
I'm using the crippleware version of the application so that setting is not available.
wd8kct is offline
post #8758 of 8919 Old 04-21-2017, 05:15 PM
Trip in VA's Avatar
Quoted: 705 Post(s)
Liked: 200
Ah.
I'd have posted a picture of WPXW but the plot is moving so fast that only 10 seconds at a time will fit on screen. I forget how to make that slower.
In any case, this looks different from what I remember last time I saw an ION signal. It definitely looks like the bitrates have been turned down. The max bitrates for the SD channels seem to be about half what they used to be. The HD seems like it's capped at 9 Mbps, or at least, not going above it very frequently. Previously it would go up past 11.
- Trip
N4MJC
RabbitEars
post #8759 of 8919 Old 04-22-2017, 11:46 AM
Michael P 2341's Avatar
Quoted: 199 Post(s)
Liked: 26
They can't be any worse than Tribune. It really ticked me off when FOX 8 "News" carried stories which were no more than promotional fluff for WGN original shows such as "Salem". The sad thing is, not only were these news "stories" not news, the program being promoted ran in the same time slot in competition with Fox 8 News at 10.
Michael P 2341 is offline
post #8760 of 8919 Old 04-22-2017, 01:48 PM
Inundated's Avatar
Quoted: 130 Post(s)
Liked: 42
Yes, I have seen this, and the Tribune cross-promotion irked me. And I am not really a Fox 8 News fan.
But yes, Sinclair is overall a worse company, by far.
And yes, if they take over WJW, say goodbye to Antenna TV. They just bought a small group (Bonten), and are drooling over bringing TBD, Charge and Comet to those stations...
