where's channel 6.1 ABC Philly? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-13-2009, 08:57 PM - Thread Starter
henrychanowski's Avatar
Before the transition to digital I was receiving channel 6.1 ABC Philadelphia OTA on a UHF antenna without problems. Since the switchover I no longer receive it. Why is this?
henrychanowski is offline
post #2 of 8 Old 06-13-2009, 09:21 PM
dewster1977's Avatar
With the end of analog they moved their digital signal from UHF 64 back to VHF 6, You will need a Lowband VHF antenna to receive them now.
dewster1977 is offline
post #3 of 8 Old 06-13-2009, 09:25 PM - Thread Starter
I can attach one right to my existing UHF antenna right? Would I get a lot more channels when I scan?
post #4 of 8 Old 06-13-2009, 10:05 PM
Is your antenna on the roof or in the attic? You could add a VHF antenna with a "UVSJ" that is a UHF VHF antenna joiner, it allows you to connect a UHF and VHF antenna to the same coax and allow one cable run from your antenna to your TV. How far are you from Roxborough antenna farm?
post #5 of 8 Old 06-13-2009, 10:55 PM
afiggatt's Avatar
WHYY PBS 12 also moved back to VHF 12. Check the Philadelphia thread or antenna threads for more info.
afiggatt is offline
post #6 of 8 Old 06-15-2009, 07:01 PM - Thread Starter
My antenna was in the attic. I actually moved it out to the roof this morning and then rescanned. Channel 6.1 and 12.1 both were coming in clear. This evening I went to watch Jeopardy! (6.1), no go, it was not receiving. Even 29.1 Fox was coming in badly tonight and I never have problems with blocking and bad reception on that channel. My son told me the FCC was involved with Abc because they are having broadcast problems. It's funny, I finally move the antenna to the roof, and my reception actually got worse! As to the question regarding my distance from Roxbourgh, I guess around 30 miles.
post #7 of 8 Old 06-15-2009, 07:07 PM
Javatime's Avatar
I have 2 people that I work with that live in huntington valley complaining about the same thing.
Javatime is offline
post #8 of 8 Old 06-15-2009, 07:11 PM
Trip in VA's Avatar
Quoted: 550 Post(s)
Liked: 147
Send a message via AIM to Trip in VA
29 is supposed to be doing antenna work and thus increasing coverage in the near future.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
