Stupid Question: Are Component Cables the same as Composite?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-11-2002, 02:24 PM - Thread Starter
RAY2002's Avatar
Component cables can be pricey. Are composite cables the same? Will a good composite cable be just as good? I'm fixing red push and in a post it said to plug a composite cable into the red component spot on the Tv after passing the original signal through the attenuator. Is this correct? Does this mean that both composite and component are the same??? Please someone reply soon.
RAY2002 is offline
post #2 of 9 Old 02-11-2002, 05:33 PM
Frank's Avatar
They are indeed the same.
But don't tell anyone. It's a big secret so the retailers can rip people off with their expensive component cables.
Frank
Did IQ's suddenly drop sharply while I was away?
I enjoy 3D in spite of HDMI 1.4!
Full screen only 3D doesn't cut it!
Frank is offline
post #3 of 9 Old 02-11-2002, 06:05 PM
Ken H's Avatar
Make sure your video cables are 75 ohm, shielded and have solid construction and good quality connectors. After that, your on your own.
A common source for these are the RS Gold product.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #4 of 9 Old 02-11-2002, 08:04 PM - Thread Starter
RAY2002's Avatar
Thanks guys. You saved me 20 bucks!!:D
I'm gonna be getting a Progressive Scan DVD player on my birthday!:)
RAY2002 is offline
post #5 of 9 Old 02-12-2002, 08:18 AM
Chris Moreau's Avatar
Get the player before you buy any cables. I bought a Sony progressive scan player and a rather expensive set of component cables at the same time. When I opened the player box, I found a set of decent component cables inside. I've compared them with the expensive ones, and can see no difference in picture quality.
Chris Moreau is offline
post #6 of 9 Old 02-12-2002, 08:57 AM
Jon J's Avatar
Quoted: 39 Post(s)
Liked: 79
Don't think you'll find this spec anywhere but on coax...certainly not ordinary shielded wire with RCA connectors on each end.
When news breaks...we fix it.
Jon J is offline
post #7 of 9 Old 02-12-2002, 03:47 PM
Ken H's Avatar
Sure you can, you just have to know what your looking for. Many common price cables actually say 75 ohm on the packaging, many others don't.
Ken H is offline
post #8 of 9 Old 02-12-2002, 04:39 PM
Tryg's Avatar
Ray try this
http://pccables.com/
Many projector owners see a much cleaner picture using composite cables. More bandwidth.
Tryg is offline
post #9 of 9 Old 02-13-2002, 07:22 AM
Jon J's Avatar
Quoted: 39 Post(s)
Liked: 79
Evidently. I don't seem to be able to find a characteristic impedence table for them. Would appreciate further information.
TIA
Jon J is offline
Closed Thread Local HDTV Info and Reception
