Potentially Stupid Question About Tuning In Digital Stations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-22-2002, 02:52 PM - Thread Starter
cubdukat's Avatar
I am trying to set up a system where I can use a Samsung SIR-T150 set-top box and my S-VHS VCR to do unattended timer recording, but I have run into a slight snag.
Obviously the VCR can't tune digital channels using the current numbering scheme (i. e. 7-1 for the digital version of Channel 7), but since each digital channel also has a UHF number (i.e. Channel 52 is the UHF number for 7-1 [WLS-DT] here in Chicago, the aftrementioned Channel 7), would punching in 52 on the T150 bring up 7-1, or would I have to manually enter 7-1, thus eliminating any possibility of unattended recording?
cubdukat is offline
post #2 of 3 Old 02-22-2002, 04:03 PM
Kipp Jones's Avatar
I just set my s-vhs on input which my set top box feeds into and adjust the times to record. This way I have no problems recording the digital channels including 7-1.
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #3 of 3 Old 02-22-2002, 11:17 PM
spwace's Avatar
Quoted: 34 Post(s)
Liked: 47
I suppose it depends on the STB, but I know the DTC-100 and panasonic will go to the first subchannel (7-1, 25-1, etc.) when tuned to the actual channel.
spwace is offline
Closed Thread Local HDTV Info and Reception
