Using the VGA in on my tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-24-2002, 07:07 AM - Thread Starter
Jondalar's Avatar
My Zenith 64" has only one component video -in, and I have a dvd and a hdtv cable box, so I attached the dvd to the component video -in and my cable box to the tv's vga-in, using an adapter. The dealer said he spoke to Zenith and Zenith said that the VGA-in bypasses all electronics in the tv. In other words, whatever is the original signal is what is on the screen, no upconversions to 1080i. I like that idea. So eventually, when ABC comes back to TimeWarner cable here in nyc, I will get 780p rather than 1080i. Does anyone know if this information about the vga-in on this set is true and do you agree with my reasoning?
Jondalar is offline
post #2 of 3 Old 02-25-2002, 05:52 PM
pcold's Avatar
I would check the specs myself on the zenith web site. salesmen aren't always the most knowledgable :) on most RP hdtv's the vga input limited to 480p.
does your set accept 720p? does your tuner pass 720p?
pcold is offline
post #3 of 3 Old 02-25-2002, 05:55 PM
pcold's Avatar
product specs here:
http://www.digitalconnection.com/Hom.../IQB64W10W.htm
says tv's hd formats are 480p and 1080i on the component and vga inputs.
you will not be able to see native 720p on that set.
pcold is offline
Closed Thread Local HDTV Info and Reception
