Harrisburg, PA - HDTV - Page 33 - AVS | Home Theater Discussions And Reviews
post #961 of 984 Old 03-11-2014, 10:40 AM
spivonious's Avatar
@pamajestic : thanks. I was afraid Baltimore would be out-of-reach. I imagine you pick themup just fine out in Gettysburg. smile.gif It is worth pointing out that when I originally did my channel scans, I could pick them up, even with the antenna pointing WNW. Signal levels were really low, 10-20% measured on TV with no splits.
It's good to know about the VHF low/high combiner to keep the FM and VHF TV separate. I suppose getting a standalone VHF antenna also makes sense, over a combined one like the AntennaCraft HBU-22. That way I can point the VHF antenna directly at WHTM and leave the UHF antenna alone.
Is there a risk that the amp you posted will overload existing channels? 22dB seems like a lot. Real channel 8 is already in the high 90s, and real channels 21 and 36 are very strong as well (with no splits in line).
spivonious is offline
post #962 of 984 Old 03-11-2014, 07:07 PM
pamajestic's Avatar
Yup, all of Baltimore and a few Washington come in fine here.
With the 80 feet of cable plus the splitter I don’t think overload will be a problem. Pete Higgins did a very detailed review of the RCA amp on the High Def Forum last summer with additional contributions from “ADTech” and he addressed overload in the review. The short of it is he has a tower 3 miles from his house and he did not have overload. I don’t want to link to another forum here, so shoot me a PM if you can’t find the review by searching. Pete includes his Tvfool so you can see what he is dealing with.
pamajestic is offline
post #963 of 984 Old 05-19-2014, 01:36 PM
spivonious's Avatar
Wow, I'm slow to act on things.
I'm putting together things to buy and found the amp and antenna much cheaper on Amazon (where I also get free shipping from my Prime membership). I can't seem find a HLSJ on there. Any other options except Solid Signal?
post #964 of 984 Old 05-19-2014, 05:13 PM
tylerSC's Avatar
Quoted: 383 Post(s)
Liked: 122
Perhaps MCM or Summit Source.
tylerSC is offline
post #965 of 984 Old 05-20-2014, 07:19 AM
spivonious's Avatar
I ended up finding it on cablesatellitesupply.com for $3 shipped. Hopefully it's real. smile.gif
post #966 of 984 Old 05-20-2014, 05:53 PM
pamajestic's Avatar
WGCB-49 add “The Works” on sub-channel .3 a few weeks ago. It looks like classic movies mostly from the 50’s and 60’s. I did not find an official web-site for it, but Titan TV does show the listings.
post #967 of 984 Old 05-27-2014, 01:15 PM
spivonious's Avatar
Okay, got everything installed in the attic on Saturday.
#1: PVC Conduit is measured by the inside diameter, and PVC conduit clamps are measured by the outside diameter. This helped fulfill the First Commandment of Projects, "Thou shalt go to Home Depot at least twice." 1" conduit worked great for an antenna mast. I had previously strung up my home-made UHF antenna with string.
#2: AntennaCraft FMSS works great! I can now pick up every local FM station with no static, and a whole lot of other stations that I didn't know about (albeit with some static, but not unlistenable). It's very nice having FM in the basement family room.
#3: AntennaCraft Y5-7-13 was a disappointment. Pretty large, at 5' long and 3' wide, but only marginal improvement on reception of WHTM-27 (real channel 10). I guess reliabily picking it up with an attic antenna isn't going to happen in my location. It's not a huge deal, since we rarely watch ABC, but it does feel like I threw away $20. I'm going to take out all of the splitters tonight to see if I can get a realistic signal level.
The RCA amp and HLSJ combiner work well. I noticed no degradation of my UHF signals after hooking up the FM and VHF.
@pamajestic: Could it be the spacing of the antennas? I figured I didn't really need to worry about interference because the amp would block VHF from going to the UHF antenna and vice versa. The antennas are all about 3' from each other at their closest.
And the Works channel looks like fun. Windows Media Center doesn't pick up any listings for it yet.
post #968 of 984 Old 05-28-2014, 04:01 AM
Digital Rules's Avatar
Quoted: 98 Post(s)
Originally Posted by spivonious View Post
AntennaCraft Y5-7-13 was a disappointment. . . . . it does feel like I threw away $20. . . . I noticed no degradation of my UHF signals after hooking up the FM and VHF. . . . . . Could it be the spacing of the antennas?
I would try moving the FM antenna away from the VHF antenna at least 4 feet. Have you tested reception with the FM antenna disconnected from the HLSJ? The strong signal from 96.9 FM has the potential to cause issues with channel 10.
Digital Rules is offline
post #969 of 984 Old 06-02-2014, 11:26 AM
spivonious's Avatar
^ Good idea, I'll try that out tonight. It makes sense as 96.9 is about half of the 192-198 of VHF 10.
96.1 FM is pretty strong too, and right in the channel 10 range as well.
I thought the HLSJ would have taken care of that.
post #970 of 984 Old 01-02-2015, 10:39 AM
pamajestic's Avatar
The new year brought some affiliation changes…….
WLYH 15.2 Grit replaces Live Well
WGAL 8.2 MeTV replaces This Network
With MeTV moving to WGAL, WGCB 49 is now a Cozi affiliate with some religious and paid programming mixed in on 49.1. The national Cozi schedule on 49.2, and The Works on 49.3.
post #971 of 984 Old 01-05-2015, 08:18 PM
mvcg66b3r's Avatar
Quoted: 29 Post(s)
Liked: 1
Potential Sinclair subchannel shuffle in Harrisburg:
WHP: 21.1 CBS (720p HD), 21.2 CW (720p HD), 21.3 MNT (480i SD), 21.4 Grit (480i SD)
WLYH (spun off): 15.1 ????
One person's craziness is another person's reality. - Tim Burton
mvcg66b3r is offline
post #972 of 984 Old 01-06-2015, 07:54 AM
mvcg66b3r's Avatar
Quoted: 29 Post(s)
Liked: 1
The posts I made here and on other threads are just pure speculation on just what might happen in these markets, with the FCC's crackdown on JSAs/SSAs and the impending incentive auction. Some of you may have been offended, and for that I apologize.
post #973 of 984 Old 01-13-2015, 11:48 AM
spivonious's Avatar
I miss the Live Well Network already. Steven & Chris was fun as well as Motion and My Family Recipe Rocks.
post #974 of 984 Old 01-13-2015, 12:03 PM
spivonious's Avatar
I missed that DOJ decision in the news. That could be big. Maybe WLYH could become an ION affiliate.
post #975 of 984 Old 01-13-2015, 06:04 PM
Trip in VA's Avatar
Quoted: 237 Post(s)
Liked: 89
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
There was no DOJ decision. mvccg66b3r made it up.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #976 of 984 Old 01-13-2015, 08:19 PM
mvcg66b3r's Avatar
Quoted: 29 Post(s)
Liked: 1
- Trip
See post #972
post #977 of 984 Old 01-14-2015, 10:25 AM
spivonious's Avatar
There is definitely some activity at the FCC about it.
http://www.fcc.gov/document/fcc-adop...rennial-review
I wouldn't be surprised if we saw WHP and WLYH split in the next couple of years.
post #978 of 984 Old 01-16-2015, 08:55 AM
StevieB's Avatar
WHP is broadcasting in 720P? Since when? Weren't they always in line with CBS, broadcasting in 1080i?
StevieB is offline
post #979 of 984 Old 01-16-2015, 09:09 AM
Trip in VA's Avatar
Quoted: 237 Post(s)
Liked: 89
They're not. Ignore that post. It's a complete fabrication.
- Trip
N4MJC
RabbitEars
post #980 of 984 Old 01-16-2015, 11:51 AM
oriolesmagic's Avatar
Quoted: 32 Post(s)
Liked: 40
While I know Comcast doesn't carry it, a lot of WHP's programming is in HD on DirecTV. So they're being offered an HD feed.
oriolesmagic is offline
post #981 of 984 Old 01-27-2015, 11:25 AM
dbturbo2's Avatar
Quoted: 12 Post(s)
Anyone know the resolution Comcast broadcasts in through their subscription HD cable service in the Harrisburg area? Trying to find out if it is possible to get a basic HD DVR/cable box through Comcast that receives a 1080p signal. Keep getting different answers each time I talk to Comcast. Thanks
dbturbo2 is offline
post #982 of 984 Old 01-27-2015, 12:07 PM
ejb1980's Avatar
Quoted: 52 Post(s)
Liked: 25
I think the X1 will output 1080p, but it really doesn't matter. Most, if not all, cable and broadcast networks are 720p and 1080i.
ejb1980 is offline
post #983 of 984 Old 01-28-2015, 01:51 PM
dbturbo2's Avatar
Quoted: 12 Post(s)
Thanks for the info - sad that 4k is on the way and we don't yet have broadcasts in 1080p.
dbturbo2 is offline
post #984 of 984 Old Today, 07:39 AM
N3NTJ's Avatar
I think 4K may use a more efficient encryption method than 1080p.. thereby making 1080p a much more quantitative stream (meaning more bandwidth). There is virtually no 4K programming, so if getting a 4K TV.. what are you gonna watch?
N3NTJ is online now
