How can I get a good vcr picture through my hdtv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-01-2002, 04:23 PM - Thread Starter
midnight's Avatar
Hi everyone
I just bought a 27" dynaflat hdtv and the vcr picture is horrible. It looks much worse than my regular antenna signal. I know hdtvs are for higher quality signals but I want to enjoy my vcr also. I would appreciate any suggestions.
midnight is offline
post #2 of 7 Old 03-01-2002, 06:47 PM
BarryO's Avatar
Yoiu probably can't. VCR pictures ARE horrible. That's just the way they are.
'haven't watched a tape since I bought my first DVD player.
You have a right to install OTA and dish antennas on property under your control.
See http://www.fcc.gov/mb/facts/otard.html
BarryO is offline
post #3 of 7 Old 03-01-2002, 10:25 PM
pnichols's Avatar
midnight,
I get very good VCR images on my Elite 58" 16X9 RPTV, but it took some work to get them because you're dealing with an analog system. On the other hand, DVD's give you great images with very little work.
I use a high end VCR, a good S-Video cable, and use a separate input on my Elite so I can have custom picture settings dialed in just to optimize things for the VCR.
If you like to enjoy films from many different eras you must have a decent VCR setup because many great films are not yet on DVD ........ or some not on laser disk either.
I try always to buy widescreen VHS movies for my RPTV and I expand them out to nearly fill the screen for a quite passable home theater experience. I often use simulated surround sound to juice up the audio, but DPL II would do VCR sound better.
For instance, try to find Hawaii, Lion of the Desert, Wind and the Lion, and The Martian Chronicles on DVD (or laser disk either).
Phil
pnichols is offline
post #4 of 7 Old 03-02-2002, 10:41 AM - Thread Starter
midnight's Avatar
Thanks guys. I'll try and mess with it some more. I guess I might have to buy a better vcr to get the picture I want. I can't seem to get rid of the distortion and the orange tint in the picture.
Thanks again
midnight is offline
post #5 of 7 Old 03-02-2002, 11:42 AM
HD_JUNKIE's Avatar
How about buying an SVHS deck with 19 micron heads?? This will be your best option for recording TV, unless of course if you want to shell out the $$$$ for DVHS.
Also buy quality tapes. SVHS tapes are better quality and are required if you want to record in SVHS quality on a SVHS machine. Make sense? Sorry if I confused the situation......
Last connect your VCR using a decent quality SVideo cable (not the one that comes with the VCR).
HD_JUNKIE is offline
post #6 of 7 Old 03-02-2002, 12:39 PM - Thread Starter
midnight's Avatar
I'm thinking of looking at the jvc HR-S9900 super vhs. Will I get a decent picture using the tapes I recorded with the vcr I have now? It's just a regular 4 head hi-fi vcr.
midnight is offline
post #7 of 7 Old 03-03-2002, 10:21 AM
ATR
ATR's Avatar
U should also open your vcr and clean the head real good and then de-Mag it if u have access to a de_mag tool
ATR is offline
Closed Thread Local HDTV Info and Reception
