what is the best hdtv program guide on the net? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-04-2002, 10:40 AM - Thread Starter
snakeman's Avatar
i live in san diego, just got a hdtv and now i need program
guide to find out what is on!
snakeman is offline
post #2 of 6 Old 03-04-2002, 11:16 AM
Ken Erickson's Avatar
You can try HDTV Galaxy or HiDefGuide and for HDNet (if you have DirecTV) HDNet
Ken Erickson is offline
post #3 of 6 Old 03-04-2002, 11:36 AM
Tryg's Avatar
Tryg is offline
post #4 of 6 Old 03-04-2002, 11:46 AM
SeanKelly's Avatar
http://titantv.com/
Sean Kelly / Independent Consultant
http://www.seankelly.tv/
SeanKelly is offline
post #5 of 6 Old 03-04-2002, 12:07 PM
Kevinw's Avatar
I have used them all and find Titan to be the easiest to use.
Samsung KS 8000
Samsung UBD-K8500 BDP
Yamaha RX-A1060
Fluance XL7F main
Mirage Nanosat surrounds
JVC JL-F45 turntable
Kevinw is offline
post #6 of 6 Old 03-05-2002, 11:03 AM
Iaen Sullivan's Avatar
They send this one to you daily, usually early the evening before the air date.
http://www.ilovehdtv.com/
Iaen Sullivan is offline
Closed Thread Local HDTV Info and Reception
