Charlotte, NC - TWC - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #511 of 8546 Old 12-19-2003, 10:32 AM
NUPE009's Avatar
Originally posted by jmccurrytech
Channels 292 (HDNet) and 293 (HDNet Movies) have been added (hidden, of course), however there is no audio/video.
Could you define hidden? If there isn't any video and audio then to me it doesnt exist at all. Does hidden mean that it's coming soon?
NUPE009 is offline
post #512 of 8546 Old 12-19-2003, 10:42 AM
namcap's Avatar
Are you a nerd? Just kidding. These channels are hidden from otherwise normal programming (reserved for new channels to be released). If you review this thread you will find how to enter this mode and understand what we mean. The banner will specifically identify that station...even if the screen is black with no sound. This is how some of us on the board know about new programming before anyone else.
namcap is offline
post #513 of 8546 Old 12-19-2003, 01:05 PM
rcase13's Avatar
I got my 3510 HD box today. Unbelievable The picture is simply perfect. SD channels are slightly better than before. I can't wait untill everything is HD.
I asked and was told the DVI should work. I don't have a cable but will buy one and see if I see a difference. I have a 720p Sammy DLP, should be interesting to see if it works.
Rodney
rcase13 is offline
post #514 of 8546 Old 12-19-2003, 02:36 PM
Davew0670's Avatar
I've read this thread a week or two ago and saw how to access hidden mode. Now I just finished reading the whole thing again and I dont see it now. I knew I should have written it down right then.
Davew0670 is offline
post #515 of 8546 Old 12-19-2003, 02:48 PM
rcase13's Avatar
On my Pioneer 3510HD (not remote) I press the "Select" button and the "Diamond" button at the same time. Not sure for other boxes.
Rodney
rcase13 is offline
post #516 of 8546 Old 12-19-2003, 03:07 PM
Davew0670's Avatar
thanks!
post #517 of 8546 Old 12-22-2003, 06:10 AM
rcase13's Avatar
The last couple of days I have been getting very loud pops/static when I switch from one HD channel to another. Today I am not getting the sound and nothing has changed from yesterday to today as far as my system goes.
I am using TWC using the 3510HD box and the digital out to my receiver.
Has anyone else heard this. It's very loud.
Rodney
rcase13 is offline
post #518 of 8546 Old 12-22-2003, 02:04 PM
Vash_Stampede's Avatar
rcase13,
your issue is simple.Either you have a loose audio cord or its bad.Check your connection.If its tight then call TWC.It may be the box itself.
The Humanoid Typhoon!
Vash_Stampede is offline
post #519 of 8546 Old 12-22-2003, 05:15 PM
rcase13's Avatar
Originally posted by Vash_Stampede
rcase13,
Initially that is what I thought. Everything is tight. It hasn't done it all day. TV has been on all day. Also it was only on the HD channels. I will take your advice and trade the box in if it does it again.
Makes me glad I have cable. Wouldn't want to shell out $300+ after just buying the TV...
Rodney
rcase13 is offline
post #520 of 8546 Old 12-23-2003, 05:00 PM
namcap's Avatar
Both channels (HDNET & HDNET Movies) are now active in hidden mode with audio and video!!
namcap is offline
post #521 of 8546 Old 12-23-2003, 06:26 PM
jmccurrytech's Avatar
Quoted: 50 Post(s)
Ya, active on Charlotte system. Still notta on Gastonia system
jmccurrytech is offline
post #522 of 8546 Old 12-23-2003, 06:51 PM
rcase13's Avatar
Yes that's 13 channels!!!
Rodney
rcase13 is offline
post #523 of 8546 Old 12-24-2003, 05:03 AM
rcasenc's Avatar
Are they still showing up this am 12/24?? , When I tried to enter the hidden mode - I cannot access either.
rcasenc is offline
post #524 of 8546 Old 12-24-2003, 06:03 AM
sccofer's Avatar
don't know about this morning but watched last night and am loving HDNET! When I first turned it on I saw the Dallas Maverik dancers, superb! Then watched the Bruins play later! Loving HDNET...
sccofer is offline
post #525 of 8546 Old 12-24-2003, 06:26 AM
NUPE009's Avatar
Thanks guys. I am able to see the 2 hidden channels. Now i'm going to have to add new buttons on my Pronto under my HD channel list. Now if I could only use my DVI port. Hopefully pioneer will have a firmware update for the box soon.
NUPE009 is offline
post #526 of 8546 Old 12-24-2003, 10:39 AM
rcase13's Avatar
Yep same problem here... I have the Sammy Pioneer problem as well...
More info here: http://www.avsforum.com/avs-vb/showt...postid=3102711
I wonder if there will ever be a fix...
Rodney
rcase13 is offline
post #527 of 8546 Old 12-24-2003, 05:03 PM
mhdiab's Avatar
Quoted: 62 Post(s)
Liked: 39
I have the 3250HD, I press Enter & Exit till Diag is on display then I can tune directly tune to 290(ESPNHD), 293(HDNET1) and 294(HDNET MOVIES) but there's just a subscription screen showing.
Posted over in Raleigh thread - I will not be home for a while, but has anyone scanned for ESPNHD again.....
Merry Christmas to all
mhdiab is offline
post #528 of 8546 Old 12-25-2003, 05:26 AM
NUPE009's Avatar
Channel 290 is INHD so that can't be ESPNHD.
NUPE009 is offline
post #529 of 8546 Old 12-25-2003, 05:55 AM
HughScot's Avatar
That is the channel number in Raleigh.
Hugh Campbell
HughScot is offline
post #530 of 8546 Old 12-29-2003, 11:54 AM
sccofer's Avatar
I don't know about espnhd but I do know that digital phone is coming soon to the Carolinas through TW. Flat monthly rate that includes long distance. From what I have heard the quality is outstanding for VOIP, very comparable to land line service.
I will have one bill for cable, phone, internet connection, security. If only they would start selling electricity and natural gas the postman could skip my house completely...
sccofer is offline
post #531 of 8546 Old 12-29-2003, 12:02 PM
rcase13's Avatar
Cool thanks for the heads up. Other than crappy SD I have been fairly pleased with TW CLT.
I wonder if they will have an option that will not include long distance. We currently use phone cards and don't have any long distance companies tied to our phone. It has worked very well for us. We usually pay a little over .03 cents per minute with no fees of any kind. We get the cards from Sams or BJ's.
Rodney
rcase13 is offline
post #532 of 8546 Old 12-29-2003, 12:41 PM
HughScot's Avatar
We just use our cell phones for long distance. Can't beat free.
Hugh Campbell
HughScot is offline
post #533 of 8546 Old 12-29-2003, 01:48 PM
jrmckinn's Avatar
I've been using Vonage since Sept. and I'm pretty happy with it so far. All the features of the telcos and 500 mins long distance for $25. Can't beat that...yet.
jrmckinn is offline
post #534 of 8546 Old 12-29-2003, 05:38 PM
jbryer's Avatar
hmmm...do people still have land lines? I shut mine off 2 years ago and the only person who missed it is the telemarketers!
jbryer is offline
post #535 of 8546 Old 12-29-2003, 05:43 PM
Check123's Avatar
Gotta have one for DSL. I can't give any of my money to Adelphia. Switched to DirecTV a year ago and haven't looked back....
Test123
Check123 is offline
post #536 of 8546 Old 12-30-2003, 05:39 AM
bdfox18doe's Avatar
Quoted: 220 Post(s)
Liked: 123
No way in hell I'd shut off my landline, especially consdiering the crappy service provided by cellular.. I guess I'm not willing to trust needing help
in an emergency..
and just what the heck does this have to do with HDTV in Charlotte?
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #537 of 8546 Old 12-30-2003, 06:24 AM
rcase13's Avatar
Putting us back on HD... How many HD channels do you get with DirectTV and what do you do for local HD channels. Do you get PBS and UNCTV in HD?
Also is there anyway to avoid the contracts involved with DirectTV and Dish? I looked at Dish and they had a free HD package but wanted a 2 year contract. I hate contracts...
Finally how much did the equipment cost to get DirectTV HD; STB, HD dish etc...
Not trying to start a war between cable, DirectTV etc just trying to understand all my options. I am really dissatisfied with Timewarner SD quality but love everything else.
Rodney
rcase13 is offline
post #538 of 8546 Old 12-30-2003, 06:30 AM
HughScot's Avatar
As someone who has had both TWC and DirecTV at the same time let me say that the SD is no better on DirecTV than it is on TWC.
Hugh Campbell
HughScot is offline
post #539 of 8546 Old 12-30-2003, 06:34 AM
rcase13's Avatar
I guess once you have seen HD you just can't go back... I hate watching regular TV anymore.
Rodney
rcase13 is offline
post #540 of 8546 Old 12-30-2003, 11:27 AM
sccofer's Avatar
rcase -
have you had someone come out and check your cable lines in your house? Signal strength, etc. Maybe you need a line amplifier or something. Although not outstanding I don't have a problem with my SD channels...
Just call TW and tell them you are having a problem and they should come out and check it for you.
sccofer is offline
