Charlotte, NC - TWC - Page 264 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #7891 of 8473 Old 06-17-2014, 09:02 AM
ke4pym's Avatar
Quoted: 48 Post(s)
We haven't even gotten to 100/5 yet. Let alone 100+/anything. Once they get the upstream channel bonding done, then we'll probably start to see higher tiers.
Right now, 300/20 is only available in NYC and LA - to the best of my knowledge.
Originally Posted by blackcat6 View Post
Would this be coming to NC/CLT?
ke4pym is offline
post #7892 of 8473 Old 06-18-2014, 04:35 AM
Zaxcom's Avatar
Quoted: 35 Post(s)
I am hearing lots of audio distortion on WCNC. I hear it on all my sets. Audio breaks into a crackly static sound during moments of slightly above average volume. This has been happening for several weeks. Its very noticeable, so I wonder why they have not corrected the issue? No issues with any other channel, so that rules out my equipment.
Zaxcom is offline
post #7893 of 8473 Old 06-18-2014, 07:09 AM
jcalabria's Avatar
Quoted: 86 Post(s)
Liked: 68
Exact same issue here. I've heard it on The Blacklist, Chicago Fire, Chicago PD and Revolution, so it's not specific to only one show, either.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 7.3.1_6
jcalabria is offline
post #7894 of 8473 Old 06-18-2014, 10:22 AM
e137811's Avatar
This is being done by TWC in certain areas of Austin Texas in response to Google Fiber.
http://kxan.com/2014/05/21/time-warn...rease-in-june/
Just goes to show what they can do if there was actual competition.
blackcat6 likes this.
e137811 is offline
post #7895 of 8473 Old 06-19-2014, 07:04 AM
Zaxcom's Avatar
Quoted: 35 Post(s)
WCNC is now aware of the issue and is working the problem.
Zaxcom is offline
post #7896 of 8473 Old 06-19-2014, 03:52 PM
jcalabria's Avatar
Quoted: 86 Post(s)
Liked: 68
Great... thanks!
post #7897 of 8473 Old 06-20-2014, 04:53 AM
Zaxcom's Avatar
Quoted: 35 Post(s)
Do you get your signal from TWC?
Zaxcom is offline
post #7898 of 8473 Old 06-20-2014, 06:00 AM
jcalabria's Avatar
Quoted: 86 Post(s)
Liked: 68
Yes. I also have OTA tuners (Silicon Dust) in my WMC configurations, but ever since the TWC channel lineup change I've been too lazy to go into WMC and/or GuideTool to re-merge and prioritize tuners to use the OTA tuners instead of the TWC feeds, so they've just been disabled. So I don't know if the same issue exists OTA. Shame on me!
post #7899 of 8473 Old 06-20-2014, 06:10 AM
Zaxcom's Avatar
Quoted: 35 Post(s)
Ok, They are trying to tell if it is a TWC issue or more. If you get a chance to try OTA, that would be good to rule it in or out.
Zaxcom is offline
post #7900 of 8473 Old 06-20-2014, 08:18 AM
blackcap93's Avatar
Quoted: 32 Post(s)
Liked: 27
Is WCNC's audio problem occurring only during NBC programming, or does it also occur during local programming?
blackcap93 is offline
post #7901 of 8473 Old 06-21-2014, 05:11 AM
Zaxcom's Avatar
Quoted: 35 Post(s)
Seems to be on network only.
Zaxcom is offline
post #7902 of 8473 Old 06-24-2014, 05:12 PM
mfogarty5's Avatar
Quoted: 61 Post(s)
Liked: 48
Does anyone experience frequent audio and video dropouts? I assume it is the Navigator software that causes the screen to go black and the HDMI connections to resync every 10 minutes or so. I tolerate it only because the alternatives are getting a new DVR which means losing recorded programs and the possibility of having a "tech" come to my house.
Reading a few forums it looks like Comcast's DVR software(old or new X1) is worse than Navigator!
mfogarty5 is offline
post #7903 of 8473 Old 06-26-2014, 05:56 PM
jrs
jrs's Avatar
You might want to try another hdmi cable...
jrs is offline
post #7904 of 8473 Old 06-27-2014, 04:54 AM
bdfox18doe's Avatar
Quoted: 194 Post(s)
Liked: 102
It's not your HDMI cable...
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #7905 of 8473 Old 06-27-2014, 05:18 AM
jcalabria's Avatar
Quoted: 86 Post(s)
Liked: 68
For those that don't visit the TWC Navigator thread... my response to mfogarty5's similar inquiry in that thread:
The audio dropouts are an issue that seems to come and go with different versions of ODN. I've been bitching about it on and off for years, and it was either completely or mostly better through the last few ODN versions. However, the current version is about as bad as it has ever been. The dropouts are on both HDMI and the coax/optical outputs. Sometimes it's a complete dropout... sometimes it's just the center channel. Power cycling (power button... not a reboot) the box will almost always fix it.
The video dropouts are new and started immediately with the current version of ODN. I initially went crazy trying to troubleshoot connections, but it does it whether it's direct to TV or through AVR and with at least a half-dozen different cables. It'll just go black... most often for just a second or so... occasionally for longer periods. Again, power cycling the box seems to make it stop dropping out for a while... at least for the remainder of the evening's viewing.
post #7906 of 8473 Old 06-28-2014, 07:32 PM
Zaxcom's Avatar
Quoted: 35 Post(s)
WCNC went HD today for their newscasts!!!
jrs likes this.
Zaxcom is offline
post #7907 of 8473 Old 07-04-2014, 09:24 AM
ke4pym's Avatar
Quoted: 48 Post(s)
Really? I long thought they had.
WBTV's news went HD in October of 2008. Nice to see WCNC playing catchup!
ke4pym is offline
post #7908 of 8473 Old 07-24-2014, 01:31 PM
Zaxcom's Avatar
Quoted: 35 Post(s)
TWC has agreed to carry the SEC Network when it launches on 8/14
Zaxcom is offline
post #7909 of 8473 Old 07-24-2014, 02:26 PM
bdfox18doe's Avatar
Quoted: 194 Post(s)
Liked: 102
Sweet! Good News!
Bob
post #7910 of 8473 Old 07-24-2014, 03:04 PM
Bookworm's Avatar
I've had several recordings missed because "the channel was not available" in the last couple of weeks, many more than usual. Has anyone else noticed an increase in this problem lately? Happens mostly on channels like TNT, AMC, etc.
Bookworm is offline
post #7911 of 8473 Old 07-26-2014, 07:56 AM
mfogarty5's Avatar
Quoted: 61 Post(s)
Liked: 48
I know I'm quoting myself, but it turns out the issue with the box was a signal issue that also caused dropouts with our phone and internet connections.
A couple of weeks ago I saw a TWC tech with the cover off the pedestal box at the corner of our lot and ever since he replaced the circuit board(amp?) in that pedestal box the DVR has not had any audio or video dropouts.
post #7912 of 8473 Old 07-31-2014, 12:49 PM
cfortan's Avatar
New announcement.....TWC to offer TWC Maxx internet in the Charlotte market next year....300/20? yes please....
http://www.timewarnercable.com/en/ab...tomer-exp.html
chuckf1 likes this.
cfortan is offline
post #7913 of 8473 Old 07-31-2014, 02:15 PM
Theo1080's Avatar
Quoted: 58 Post(s)
Liked: 34
WAXN-TV 64.3 is now on the air with color bars for the 8/18/14 Launch of ESCAPETV. You may see 64.1 programming on 64.3 in SD, 16x9 at random times between now and 8/18/14 for testing.
Ted Hand, CPBE. 8VSB, DRB, AMD
I was there on July 23, 1996...First DTV broadcast in the US..WRAL-HD
Amateur Radio - W9SOC
Theo1080 is offline
post #7914 of 8473 Old 08-01-2014, 05:58 PM
ke4pym's Avatar
Quoted: 48 Post(s)
Plan on buying a new cable modem for 300/20 service. Your 6121 or 6141 won't cut it....
ke4pym is offline
post #7915 of 8473 Old 08-01-2014, 08:41 PM
stannc's Avatar
Quoted: 25 Post(s)
Is there any word on Time Warner Cable picking up 64.3 and/or 18.2 (AntennaTV) ?
stannc is offline
post #7916 of 8473 Old 08-01-2014, 10:22 PM
stannc's Avatar
Quoted: 25 Post(s)
They rolled out all new graphics and music for their newscasts on Thursday 7/31.
stannc is offline
post #7917 of 8473 Old 08-02-2014, 08:02 AM
csmith's Avatar
Quoted: 39 Post(s)
Liked: 27
The SB6141 can handle 300/100:
http://www.arrisi.com/modems/datashe...Data_Sheet.pdf
csmith is offline
post #7918 of 8473 Old 08-02-2014, 11:44 AM
ke4pym's Avatar
Quoted: 48 Post(s)
Originally Posted by csmith View Post
That may be true. However, in markets where TWC is rolling out Maxx with 300/20, they're making people upgrade to the SB6183. A 16x4 modem. They will only provision the 8x4 modems to 100x10.
ke4pym is offline
post #7919 of 8473 Old 08-02-2014, 03:34 PM
ybsane's Avatar
Quoted: 66 Post(s)
Liked: 29
I would not worrying about upgrading in the Charlotte market area for two reasons: The Cisco 10K's that are deployed only handle 8x4 and second the markets that have 16x4 bonding (Arris CMTS units) are 862-1Ghz systems and this market is only 750Mhz except for the Huntersville/Statesvilles systems which where built to 1Ghz but are operating at a 862Mhz.
All Comments made are my own and not of my employer.
ybsane is offline
post #7920 of 8473 Old 08-02-2014, 08:33 PM
stannc's Avatar
Quoted: 25 Post(s)
So the TG862 that I have won't be able to handle 16x4? I'm at 8x1 in Union County, have been since the first of the year.
stannc is offline
taboola here
