Rookie Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-30-2002, 03:54 PM - Thread Starter
GSR1's Avatar
I just purchased a HDTV set. I currently have RCA Direct TV. I realize I need to get an HDTV satellite system. I need to buy the oval dish but do I also need to get the HDTV receiver? In buying this system, where is the best place to get based on price & service? I'm sure these are redundant questions on here, so forgive. Thanks.
GSR1 is offline
post #2 of 4 Old 03-30-2002, 05:50 PM
Mattman's Avatar
which RCA set did you purchase? Some of them have an integrated tuner.
Mattman is offline
post #3 of 4 Old 03-31-2002, 04:28 PM - Thread Starter
GSR1's Avatar
sorry, i probably need to clarify. my tv is hdtv ready. but, my dss system (receiver/ dish) are not.
GSR1 is offline
post #4 of 4 Old 03-31-2002, 10:49 PM
Mattman's Avatar
Yes you will need to get a High Def receiver, the oval dish and an over the air antenna (if you want local channels in HD). Where you get them is up to you. You might find them cheap over the net but then you have to do the installing yourself. You may pay more for a local guy but then you can hire them for the installation.
Mattman is offline
Closed Thread Local HDTV Info and Reception
