WPBT Signal Problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-05-2002, 08:59 AM - Thread Starter
holtwm's Avatar
Anyone else having problems receiving WPBT? I get a signal strength of 77 but it goes down to 0 every 15 seconds or so. Doesn't seem to happen all of the time either. Am I the only one having this problem? Are they still doing testing or something?
It is very frustrating because programs get interrupted every 15 seconds when the signal becomes unlocked. I live in Coral Gables and am using a Sony HD100 with a RS VU-190 antenna that is not amplified. Any suggestions for solving this problem? Anyone have an email address for any of the WPBT broadcast engineers? Thanks.
Will
holtwm is offline
post #2 of 8 Old 04-05-2002, 09:18 AM
hardrock's Avatar
George_Dooley@WPBT.pbs.org
Graham_Simmons@wpbt.org
Neal_Hecker@wpbt.org
rafkindj@wpbt.org
Phone: (305) 949-8321 or 949-1922
Ask for "Master Control" or Jeff Rafkind
USA
hardrock is offline
post #3 of 8 Old 04-05-2002, 09:33 AM
hardrock's Avatar
Will,
You may want to try to reacquire their signal.
I have had alot of trouble with their signal on my Dish 6000. They broadcast on two (2) separate subchannels - 1 for SD and 1 for HD. If I tune to the SD channel and they happen to be broadcasting in HD (or vice versa) my STB will lose both subchannels.
Sometime last month they changed their configuration and I was able to acquire channel 18-01 which broadcasts both subchannels in the appropriate format.
USA
hardrock is offline
post #4 of 8 Old 04-05-2002, 09:42 AM
David McRoy's Avatar
On my Zenith tuner I can only "add" and save whichever of the two program streams they happen to be sending at the time that I do a search.
On my RCA DTC-100, I can "add" and save both program streams, even if only one is being sent while I'm doing a channel search.
I'll try a new search on the Zenith, based on hardrock's info on their new formatting.
HiDefDave
WPTV/WFLX West Palm Beach, FL
David McRoy is offline
post #5 of 8 Old 04-05-2002, 10:19 AM
hardrock's Avatar
Dave,
Their formatting is very sporadic. It's almost as if each engineer is using his/her own personal preference when they are at the helm of the controls.
Last night at 11 PM I was receiving the program "Shape of Life" in SD. It is supposed to be HD. When I attempted to manually re-acquire their broadcast channel (18) on my receiver, it came up as sub-channels 2-01 and 2-03. I did not save it for fear that I would lose the 18-01 configuration which allows me to get both the HD and SD streams.
USA
hardrock is offline
post #6 of 8 Old 04-05-2002, 12:09 PM
wjbjr's Avatar
No reception problem in south Coral Gables. Signal at 100 using Mitsubishi HD4, starting RS outdoor VHF/UHF antenna, no amplifier.
The HD signal is received on 2-2, while 2-1 carries the channel 2 analog programming in analog.
B
wjbjr is offline
post #7 of 8 Old 04-05-2002, 12:35 PM
hardrock's Avatar
Will,
You may also want to try doing a "switch check" on your Sony HD100. I need to do this on my Dish 6000 whenever I disconnect the cables between my dishes and the receiver.
I also have reception problems on my Dish 6000 when I try to surf from a satellite SD channel to a local HD channel. Tuning from "satellite HD" to "local HD" is non-problematic.
USA
hardrock is offline
post #8 of 8 Old 04-11-2002, 04:08 PM - Thread Starter
holtwm's Avatar
Fixed the problem last night. My antenna had moved very slightly. It is amazing that extending one of the UHF arms a few inches can make such a difference. I didn't think this could be the problem since my antenna is in the attic! Anyway I am now getting WPBT at 82 constant signal strength and I am loving it! Thanks for all of the help (also to Larry Crouper (sp?) at WPBT).
Will
holtwm is offline
Closed Thread Local HDTV Info and Reception
