WSVN in South Florida is broadcasting on 8-02 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-07-2002, 11:02 AM - Thread Starter
hardrock's Avatar
The picture looks alot better than 480i. Could it be 480p?
Subchannel 8-01 has a signal but no picture or sound on my Dish 6000.
USA
hardrock is offline
post #2 of 5 Old 04-07-2002, 03:41 PM
aviators99's Avatar
I wish I had been home to check this out. Right now, they are broadcasting only on 8-1, and it is not programmed to map to 7-1 like it normally is, so this is different. It is the same 480i signal, though...
aviators99 is offline
post #3 of 5 Old 04-07-2002, 04:19 PM
wjbjr's Avatar
I am receiving it on both 7-1 and 8-1. No 8-2.
B
wjbjr is offline
post #4 of 5 Old 04-07-2002, 06:47 PM - Thread Starter
hardrock's Avatar
The picture quality during the NASCAR pre-show this afternoon was alot better than I have ever seen on WSVN.
Right now it looks the same as it has in the past - crappy.
USA
hardrock is offline
post #5 of 5 Old 04-07-2002, 07:44 PM
aviators99's Avatar
If you see it again, please post again...my HTPC will tell me the resolution.
Unfortunately, I'll be away all day tomorrow, so I won't be able to check it.
By the way, it wouldn't be 480p. It would either be 720p or 1080i, and the 480p content would be upconverted. According to my last conversation with their chief engineer, they were leaning towards 720p.
Closed Thread Local HDTV Info and Reception
