Cleveland, OH - WOW - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-04-2011, 04:13 PM - Thread Starter
Valnar's Avatar
Quoted: 60 Post(s)
I just received an email from WOW cable about the three phase transition to digital. The letter stated that they are reducing the analog channels and converting them to digital. They will make available two digital adapters per household.
I called WOW and couldn't get an intelligent person to answer my questions. I was concerned that these adapters would be full-blown Digital boxes that had their own remote control and everything would be encrypted. He seemed to think so. I am hopeful that is not the case since I use external PVR software (SageTV) to record my TV and most of it is analog or clear-QAM (HDHomeRun for that).
After asking, they said the two devices are the Cisco DTA50 or the Evolution something-or-other.
Questions:
1) Does anyone know if these devices *require* a remote to change channels? If they don't, I can continue to record with my Hauppauge WinTV card, albeit at a slightly lower quality due to a D/A conversion in the box.
or
2) Does anyone know.....just by reading the specs or being familiar with the device....if they *input* clear QAM? Or is it encrypted? If its clear, I can continue to use my HDHomeRun to record the TV shows.
Valnar is offline
post #2 of 13 Old 02-04-2011, 09:05 PM
Ken H's Avatar
WOW will encrypt most all channels. They will no longer be in clear QAM, let alone analog.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 13 Old 02-04-2011, 10:44 PM
coyoteaz's Avatar
Local HD channels will likely be in the clear. SD limited basic channels like public/educational/government access may be in the clear. Everything else will probably be encrypted. The DTA boxes do the channel changing so you would need an IR blaster to use one with a tuner card.
coyoteaz is offline
post #4 of 13 Old 02-05-2011, 06:05 AM - Thread Starter
Valnar's Avatar
Quoted: 60 Post(s)
I was afraid of that.
OK, another question on a HDTV.
So how does this device work in conjunction with the free local HD channels I receive? If I put this device inline with my coax cable, I have to use the remote codes in comes with, right? So how then can I use my own QAM tuner in my HDTV to then tune my local HD channels? I wouldn't want them converted to analog by this device.
Valnar is offline
post #5 of 13 Old 02-05-2011, 11:48 AM
Ken H's Avatar
Split the coax signal and run it directly into the set. If the digital box they provide only has RF out, you may need to use an RF A/B switch to switch between the direct feed and digital box.
Ken H is offline
post #6 of 13 Old 02-07-2011, 09:57 AM
Ken H's Avatar
Added to US Master Topic.
Ken H is offline
post #7 of 13 Old 03-07-2011, 07:46 AM - Thread Starter
Valnar's Avatar
Quoted: 60 Post(s)
Wow's first phase of migrating analog channels to digital occurred this morning. I lost a bunch of channels. I guess I need to fire up my digital converter now.
Valnar is offline
post #8 of 13 Old 03-07-2011, 08:59 PM
Ken H's Avatar
http://www.wowway.com/digitaladapter/
Ken H is offline
post #9 of 13 Old 03-31-2011, 08:55 AM - Thread Starter
Valnar's Avatar
Quoted: 60 Post(s)
Fantastic news for WOW customers. They truly are a good cable company.
http://www.thewowbuzz.com/blog/techn...tion-revisited
Valnar is offline
post #10 of 13 Old 05-31-2012, 01:28 AM
Ken H's Avatar
The article references the fact WOW passes their Basic Cable channels in clear QAM.
WOW QAM Channel Lineups:
http://www.wowway.com/wow-built-in-d...annel-lineups/
Ken H is offline
post #11 of 13 Old 12-17-2015, 09:18 AM
IndianaGeorge's Avatar
Quoted: 18 Post(s)
I will try to bring this thread back to life Does anyone know if WOW has a better HD-DVR than the Cisco 8642HDC? I basically like it, but I am experiencing infrequent dropouts of video and/or audio. The diagnostics screen indicates signal level is near perfect and no errors. Dropouts occur even if I switch to component video. Seems unlikely that this could be happening at the head end... could it be a digital repeater problem of some sort? Anyone else getting dropouts?
IndianaGeorge is offline
post #12 of 13 Old 12-21-2015, 04:47 AM
Too_Many_options's Avatar
Quoted: 21 Post(s)
I have 2 different non-dvr boxes and I get frequent drop outs.
Too_Many_options is online now
post #13 of 13 Old 12-21-2015, 09:27 AM
Quoted: 18 Post(s)
Thanks for the input! At least I know I'm not the only one.
