Tucson, AZ - HDTV - Page 127 - AVS Forum | Home Theater Discussions And Reviews
post #3781 of 3799 Old 01-16-2015, 09:53 AM
glenngreen's Avatar
Quoted: 17 Post(s)
I noticed that the cox guide was off by an hour that night. Luckily I caught it in time to record TGW at 8, cause the guide showed it at 9.
Fear is a path to the Dark Side: Fear leads to Anger, Anger leads to Hate, Hate leads to Suffering.
--- Master Yoda, a long time ago in a galaxy far, far away.
glenngreen is offline
post #3782 of 3799 Old 01-17-2015, 12:24 AM
dhett's Avatar
OTA watchers: If you haven't seen it already, you should be getting a new subchannel between now and Tuesday. Justice Channel is set to debut by Tuesday on KMSB channel 11.3, joining Fox and Movies! Seems that despite the "sale" to Sander, and the move-in with KOLD, Gannett is still pulling the strings at channel 11, as they are the ones with the agreement with Justice Channel.
dhett is offline
post #3783 of 3799 Old 01-19-2015, 04:16 PM
SycamoreSeej's Avatar
Anyone else bothered by Grit's fixed 16x9 in a 4x3, and that many of the movies are stretched to 16x9? If it was the other way around, I could change the settings on my tv, but alas I cannot with this. At least on my recent visit back to Chicago, it wasn't like that on the station there. Any news on ThisTV coming on 9.3, or did that deal fall thru? Usually, all the new channels just show up on my tv when they start broadcasting, no rescan needed. Movies TV still shows as ThisTV in the EPG a year later, lol.
Justice Channel looks like nothing but Divorce Court and Judge Judy shows. I'll pass.
Now in NE Tucson, AZ with a cheap rabbit ears antenna. Got everything except KTTU (MyNetwork).
SycamoreSeej is offline
post #3784 of 3799 Old 01-24-2015, 08:00 AM
Liked: 0
Justice channel on 11.3 coming in at 100% in Oro Valley AZ, as of 23 January. No program guide, using DISH OTA module. Couldn't find an on-line guide on Justice channel's home page either.
tricocereus is offline
post #3785 of 3799 Old 02-03-2015, 09:53 PM
azusaguy's Avatar
So sorry for the incredibly late reply. I finally installed a Winegard HD8200U today. I also purchased a Winegard LNA-200 Boost XT Digital HDTV Preamplifier in hopes of picking up the towers on the mountain. I first tried to see what I would get without the preamp. 17 channels! But no Fox, which I really want. So, I hooked up the preamp properly and I got...6 channels. I turned the antenna toward the West and tried with/without preamp. Again, less channels WITH the preamp. So, I disconnected the preamp and pointed toward 8 degrees magnetic again. I Was able to get Fox for about 30 seconds and then it pixelated to hell and I never got it back. So, I turned the antenna back toward the West and I was able to get 20 channels with no preamp. But, of course no Fox.
First, does anyone know why the preamp would produce these results? Second, is there anything more I can do to get Fox? TV Fool makes it seem as if I should be able to get it with the monster of an antenna I have on my roof now. I can PM you the link to the radar picture since I'm too new to post links in here.
TIA!
Originally Posted by ebo View Post
azusaguy:
Looks like you do have a problem:
Here's my best guess of your TVFool TV Signal Analysis[/URL] based on 10 miles at 8 degrees magnetic to the main transmitters on Bigelow Mt. I suspect you're getting KGUN, KOLD and PBS from their repeaters on Tumamoc Hill and Tower Peak, about 15 and 20 miles respectively WSW of you. What PBS subchannels do you get in addition to the HD one? KUAS on Tumamoc has Kids and World; KUAT on Bigelow has V-Me and Encore.
KVOA (NBC) has a repeater on Tumamoc as well but it's on channel 4 so your flat panel indoor antenna isn't going to cut it. You need an antenna that can receive low VHF, unless you can get enough signal from the main transmitter on Bigelow, which is on channel 23. Sadly, KMSB (Fox) doesn't have a repeater.
BTW, you didn't mention KWBA (CW) but they're about 35 miles south of you. Despite the distance they should be easy to get.
azusaguy is offline
post #3786 of 3799 Old 02-04-2015, 12:57 AM
dhett's Avatar
I'm not an engineer, but based on my own experience with amplified reception, I would bet that you're getting signal overload with the amplifier. At 10 miles, you're way too close to the towers to need an amplifier.
As for KMSB channel 11, here is the station's signal contour, from RabbitEars:
http://www.rabbitears.info/contour.p...=1069565&map=Y
Depending on where you live in NE Tucson, you could be terrain blocked. Mounting the antenna higher could help. Or not. I get channel 11 at night from time to time in Chandler. Go figure.
dhett is offline
post #3787 of 3799 Old 02-04-2015, 08:55 AM
azusaguy's Avatar
Thanks for the reply. I think there's definitely some terrain maskin going on, which I guess shouldn't be surprising given how many land masses are between my house and the tower. The antenna is at least 30 feet of the ground, so I'm not sure going any higher would help. But it might. As soon as I'm allowed to I'm going to post all my radar graphs for communal ingestion and help.
Does anyone know if Fox is planning to erect a repeater any time soon?
Also, is it odd I can't get the CW? My understanding is the Winegard 8200U is one of the best OTA antennas out there and should pick up the signal. Again, i wish I could post links so you could see where I am.
azusaguy is offline
post #3788 of 3799 Old 02-04-2015, 09:15 AM
Liked: 0
Channel 13 and Subs
Is anyone in Northeast Tucson having problems getting signal on channel 13 and its subs.Previous to the rain here my signal was perfect and after, nothing.I posted to KOLD's facebook page and they did have an outage Sunday,however they are supposed to be back up yet I have rescanned several times and there is no signal. Nothing has changed with my rooftop antenna and all other stations are crystal clear. Thanks,and any suggestions are greatly appreciated.
rabecht is offline
post #3789 of 3799 Old 02-04-2015, 12:19 PM
ebo
ebo's Avatar
Quoted: 47 Post(s)
azusaguy:
I agree with dhett that preamp overload is the most likely reason you get fewer channels with it than without it but there are a few other things to check. Make sure the antenna and TV cables are going to the right connectors on the amp and that the amp's power supply is also connected in the right direction and getting power. You could try the amp with and without the supply plugged in to see if there's a difference; if not, the supply may be bad.
You could add an attenuator between the antenna and the amp to see if you can find a sweet spot where the amp helps without overloading. However, I suspect you'll find it works best without the amp at all.
If you're very close to the mountains you might have to point the antenna up toward the transmitters rather than horizontal. That might be difficult; most mountings don't allow for that.
The reason you can't get the CW station is that the antenna is very directional and that transmitter is south of you. But if you point the antenna south you'll probably lose all of your other channels (unless you're lucky enough to get a bounce off of some large object to the south). But almost any UHF antenna should be able to get it so try whatever antenna you were using before. If it works by itself, try coupling it into the main antenna feed to the TV.
ebo is offline
post #3790 of 3799 Old 02-04-2015, 04:29 PM
azusaguy's Avatar
Copy all. Definitely a lot of potential variables here. Thanks for the feedback, folks.
azusaguy:
azusaguy is offline
post #3791 of 3799 Old 02-04-2015, 04:33 PM
azusaguy's Avatar
I just got home and noticed the wind rotated the antenna. The mounting brackets on the side of the house don't quite tighten enough to prevent the beast from turning in the wind apparently. I need to add some friction between the pipe and the brackets to prevent that from happening again. Any suggestions of material to use to wedge between the u bolts and the pipe to create a good amount of friction?
azusaguy is offline
post #3792 of 3799 Old 02-04-2015, 05:03 PM
azusaguy's Avatar
Ok, I can finally post links. Not sure if this info changes anything already discussed, but I'm open to any new suggestions this may draw out. Thanks in advance.
http://www.tvfool.com/?option=com_wr...2c156908d293eb
azusaguy is offline
post #3793 of 3799 Old 02-07-2015, 03:03 AM
dhett's Avatar
Fox has no control over the station. It is owned by Sander Broadcasting, which is likely a puppet owner for Gannett, and is operated by Raycom out of the KOLD studios. Back in the analog days when KMSB had its antenna down near Green Valley (from when it was licensed to Nogales) channel 11 maintained a translator on channel 50 from Mt. Bigelow, but since moving its signal to Bigelow, it turned in its ch 50 license, so I don't see KMSB ever getting a translator.
I don't think it's odd at all, since KWBA's signal doesn't originate from Mt. Bigelow or Tower Peak like all the others do. KWBA is licensed to Sierra Vista, so their tower is located SE of Tucson in the Santa Rita mountains. You could be experiencing a whole different set of terrain blockage issues.
dhett is offline
post #3794 of 3799 Old 02-07-2015, 07:14 AM
azusaguy's Avatar
Thanks for the help, everyone. Got it all sorted out and even get CW at night! It's too bad I can't get Fox, but I'll keep exploring the options.
azusaguy is offline
post #3795 of 3799 Old 06-12-2015, 07:37 PM
Jynx980's Avatar
Been having an issue with Direct TV local channels intermittently shutting off at midnight. Noticed it the most on Late Night with Seth Meyers because of the time its on. Gets 25 minutes into the recording, then just black. Does not happen every time but it has happened 3 or 4 times now. I'm reluctant to call Direct TV because I know they are just going to tell me to reset the receiver like they do every time. Anyone else experiencing this?
Jynx980 is offline
post #3796 of 3799 Old 04-20-2016, 10:38 PM
mourningstar625's Avatar
I have a question about getting an HDTV converter box, I think i need to get one because my current TV(Pioneer Kuro Pro101fd)/receiver(Pioneer VSX-1123) doesn't have any coax connections. I look for reviews for these things but what I mostly find are reviews from the 2008 time period and nothing really newer. Should I look for anything in particular ? I am kind of hesitant to get a random one because it seems most have poor reviews.
mourningstar625 is offline
post #3797 of 3799 Old 04-21-2016, 08:58 AM
shpitz's Avatar
Quoted: 57 Post(s)
Liked: 51
You could get an HDHomeRun OTA tuner, such as this one:
https://www.silicondust.com/products...un-connect-na/
It's a network streamer, so you will need an HTPC connected to the TV in order to watch TV. Nice thing about it is that is allows you to watch on any device (phones, tablets, laptops, etc...).
Windows has an app called Windows Media Center that functions as a DVR, and that's what I use at home.
I currently use an HDHomeRun Prime which only does cable (using a cablecard from Comcast), and not OTA.
shpitz is offline
post #3798 of 3799 Old 04-27-2016, 01:03 AM
ya I have an HTPC but I found that windows media center is pretty crap. I had a ceton PCI card that did cable card and the service was pretty bad through cox, although it was on win 7 I haven't tried it on win 10. I am just trying to simplify this for my non-tech family, and loading up WMC isn't very reliable.
post #3799 of 3799 Old 04-27-2016, 10:20 AM
shpitz's Avatar
Quoted: 57 Post(s)
Liked: 51
WMC is very reliable for me, I have it setup to use an Harmony One and Harmony 700.
They both have a device called 'Microsoft MCE Keyboard' which has a shortcut to LiveTV, that when pressed, will launch WMC and go straight to live TV. Can't get any easier than that.
I also have a button that issues a RecordedTV command, which takes you to recorded TV directly.
Both shortcuts work regardless if WMC is running or not (if not running, it will launch it for you).
For LiveTV, WMC is amazing, for anything else, it sucks. I only use it for live TV.
shpitz is offline
