Wilkes Barre, PA - HDTV - Page 18 - AVS Forum | Home Theater Discussions And Reviews
post #511 of 708 Old 09-30-2005, 07:01 PM
Thomas Willard's Avatar
Saw a news item on WYOU which gave a progress report on the conversion to high definition. Report showed the new antenna going up and said that a full power signal will be on the digital channel at the end of the month. Since the same company also owns WBRE, I suspect that that channel will also be showing high definition by the end of October. Hope their schedule holds up.
Tom
Thomas Willard is offline
post #512 of 708 Old 09-30-2005, 07:07 PM
Jeff Williams's Avatar
Liked: 29
Yes, you are correct Tom. They will both go HD on the same day. Where did you see that report?
Jeff Williams is online now
post #513 of 708 Old 10-10-2005, 05:19 AM
vitod's Avatar
Quoted: 266 Post(s)
Liked: 135
Those of you living here and particularly Arrowhead Lakes, what channels were you able to get very well despite all the trees and with what equipment?
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #514 of 708 Old 10-10-2005, 08:10 AM
fithian's Avatar
I have only picked these stations up once, but I am 45 miles away (Orefield). Will the full power signal be on channels 11 and 13 as they are now? And what day in October will this happen? I assume they will use 22 and 28 when analog is chopped.
Eph
fithian is offline
post #515 of 708 Old 11-03-2005, 04:45 PM
Fatbob's Avatar
Jeff Williams Yes, you are correct Tom. They will both go HD on the same day. Where did you see that report?
We wrote to Him.
Hello,
What is the status of your High Definition upgrade?
And his reply was
Target date for WBRE and WYOU is on or around Halloween.
--Randy Williams
C. Randolph Williams
I noticed that Channel 22 was off the Air last week for 2 or 3 days.
Do we now have a updated Date as to when this may start...
Fatbob is offline
post #516 of 708 Old 11-03-2005, 06:03 PM
Liked: 29
The new date is by November 11th. Everything seems to be on track to hit that date; maybe even a few days early.
post #517 of 708 Old 11-07-2005, 06:52 PM
LukFilm's Avatar
4 days to go, can't wait to see CBS and NBC in HD, will look great on my PL5000N
LukFilm is offline
post #518 of 708 Old 11-07-2005, 08:11 PM
Liked: 29
Slight delay because of the weather. Things will be officially on by Monday, but likely by late Saturday. Keep the fingers crossed.
They will go full power before passing the HD signal. Look for that to happen by Wednesday morning.
post #519 of 708 Old 11-08-2005, 08:18 AM
LukFilm's Avatar
Late Saturday of next week, correct?
LukFilm is offline
post #520 of 708 Old 11-08-2005, 09:26 AM
Liked: 29
The 12th, this Saturday.
post #521 of 708 Old 11-08-2005, 11:25 AM
LukFilm's Avatar
Awesome, thanks.
LukFilm is offline
post #522 of 708 Old 11-08-2005, 11:43 AM
dwmoss's Avatar
*fingers crossed*
dwmoss is offline
post #523 of 708 Old 11-09-2005, 07:46 AM
Jeff:
Thanks for the update, but I have a question. Every since hooking up my ATSC tuner in my home theater I have been receiving WBRE and WYOU on their respective digital channel assignments but with the standard definition signal at a decent signal strength. I saw on the news some weeks ago a report that a new antenna was being installed. Why can't they just send out the high definition signal on what antenna and transmitter equipment that has been sending out the standard definition digital signal for all these months?
Tom
post #524 of 708 Old 11-10-2005, 10:30 AM
Fatbob's Avatar
Jeff.
Just wondering.
I live in Pittston.
My Father in Wyoming.
Yesterday and for a day or so, both 22 and 28 have been off the air.
Last night Still nothing on mine. But Father in Wyoming says if he punches in 22 on his tv it goes to a 2-1 dtv and not 22-1 and on that it had Channel 22 working??
I could not do that. It would not work. Any reason or what is that channel he is showing?
Are the Stations still going to stay 22-1 using 13? I believe and 28-1 as 11?
Fatbob is offline
post #525 of 708 Old 11-12-2005, 06:57 AM
Slosh's Avatar
Quoted: 50 Post(s)
Liked: 33
WYOU (13-1 mapped at 22-1) and WBRE (11-1 mapped at 28-1) are now both HD and full power.
Slosh is offline
post #526 of 708 Old 11-12-2005, 02:30 PM
Fatbob's Avatar
YES Finally!!!!!!!!
Fatbob is offline
post #527 of 708 Old 11-12-2005, 04:03 PM
LukFilm's Avatar
Awesome! Not in WB at the moment - I have Adelphia cable, does this mean I'll be able to get these at channels 722 and 728, respectively? Thanks!
LukFilm is offline
post #528 of 708 Old 11-12-2005, 07:27 PM
Both signals reaching Moscow and my modest outdoor antenna with enough power to peg the tuner's signal strength meter.
Tom
post #529 of 708 Old 11-13-2005, 12:51 AM
Liked: 29
Tom,
The antenna and transmitter were replaced because they could not output the full power signal that the new HD needed. The antenna was also mounted higher up on the tower to give better coverage.
Fatbob,
Think most of your questions are probably answered by now. The last few days were just steps in the process to get things up and running. The channels will stay 22-1(13) and 28-1(11).
Note for Sunday morning, the 13th, from the WYOU/WBRE chief engineer:
Tomorrow around 8:30 / 9:00 AM WBRE and WYOU-DT will be off. WYOU 22 (Analog) will be at 5-10% power.
The last part of this project is my new tower lighting system. Tomorrow the tower crew will climb to the very top of our tower and analog antenna with RF Suits on to instal the top beacon.
I will make sure that WBRE-DT and WYOU-DT are back on BEFORE NFL on WYOU and NASCAR on NBC!
post #530 of 708 Old 11-15-2005, 08:55 AM
LukFilm's Avatar
Bummer, not on Adelphia's cable yet...
LukFilm is offline
post #531 of 708 Old 11-15-2005, 11:38 PM
Liked: 29
I don't think we will see them on Adelphia at all. I got the feeling that they wouldn't be added until Comcast took over.
post #532 of 708 Old 11-16-2005, 07:54 AM
Fatbob's Avatar
Great. We have all the major stations using the HD.
Any idea on when WB and PAX might go HD?
Time Frame?
Fatbob is offline
post #533 of 708 Old 11-27-2005, 08:34 PM
LukFilm's Avatar
Damn. Anyway, I'll install an external antenna to catch HDTV channels anyway (from old VOOM set-up), so I'll catch them eventually anyway. I live 2 miles away from the towers, so that's nice.
LukFilm is offline
post #534 of 708 Old 12-26-2005, 11:56 AM
Jim Shaffer's Avatar
Is anyone using SusCom cable in the Williamsport area for HD? I just got a HD-capable monitor and I'm trying to decide whether to go with them or Dish Network. SusCom doesn't have all the locals in HD yet, but then again Dish doesn't have *any* HD locals yet, and I don't know if they'll end up a satellite that isn't behind a tree when they do. My other concern with SusCom is what the picture quality will be like. I have their standard-definition digital cable package and the compression is terrible. I can easily see artifacts on everything but the premium channels; the Discovery Digital channels have such a low bit rate that it often takes several seconds to build the picture after tuning to them and the MTV channels aren't much better.
Jim Shaffer is offline
post #535 of 708 Old 01-01-2006, 08:11 PM
Trip in VA's Avatar
Quoted: 496 Post(s)
Liked: 140
Send a message via AIM to Trip in VA
Just curious, but can anyone confirm that WYOU and WBRE are now feeding HD?
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #536 of 708 Old 01-01-2006, 10:29 PM
Liked: 29
Trip,
They both are in HD, 5.1, and full pwoer.
post #537 of 708 Old 01-02-2006, 06:18 AM
Henna's Avatar
What's the status of 16-1, 16-3 and 56-1
Had them all about aweek ago, now nothing
receive 22-1 and 26-1
Sugaroaf PA
Henna is offline
post #538 of 708 Old 01-02-2006, 06:19 AM
Henna's Avatar
Sorry - I meant 16-2
Henna is offline
post #539 of 708 Old 01-02-2006, 12:06 PM
Yes, WBRE andW YOU have been feeding the HD network feeds since mid November. I noticed WNEP's high def signal was off about a week ago, but as of last night was working again.
Tom
post #540 of 708 Old 01-02-2006, 02:30 PM
Henna's Avatar
Tom
I have been receiving 56-1, 22- 1 and 28-1 since November, but have been receiving 16-1 prior to that.
Now for about a week no 16-1 or 56-1 at all. Signals varies from 20 to 40 but mostly at 20 with no picture.
22-1 and 28-1 are about 65-70 with ok reception.
What's up?
Henna is offline
For the best viewing experience please update your browser to Google Chrome
