OK Bay Area DTV Broadcasters, LISTEN UP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-10-2002, 01:58 PM - Thread Starter
SeanKelly's Avatar
Just wanted to say thanks for all you've done. Much appreciated!
Sean Kelly / Independent Consultant
http://www.seankelly.tv/
SeanKelly is offline
post #2 of 6 Old 04-10-2002, 11:33 PM
Larry Kenney's Avatar
Quoted: 476 Post(s)
Liked: 74
On behalf of the KGO crew, we appreciate your thanks. I'll see that the rest of the staff sees your message.
Larry
KGO Technical Director
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Live reception scans from my HD Home Run receivers: http://www.larrykenney.com/hdhr/
Photos and info on my antennas: http://www.larrykenney.com/tvantennas.html
Larry Kenney is offline
post #3 of 6 Old 04-14-2002, 11:13 PM
NiteWrider's Avatar
Larry,
I'm on the borderline of receiving KGO-24, and I think it might be due to its lower transmission wattage (~600 KW?). I say this because it seems that I'm able to receive other DTV station from Sutro Tower transmitting at higher wattages.
Any possibility for you folks to turn it up a notch? :D
NiteWrider is offline
post #4 of 6 Old 04-15-2002, 06:29 PM
rcsommers's Avatar
Great Picture! - :) THANKS
I'm in Fairfield and get KGO DTV just fine on my Mits WS55895, it's a 55" rear projection high def, and the :rolleyes:nly thing KGO is doing that could use a tweak is the blasting of their logo - bug, in the lower right corner when the news is on. If they could drop that back (lower intensity), my tubes would be much happier - according to page 70 of the owner's guide!
Regards
rcsommers is offline
post #5 of 6 Old 04-21-2002, 04:55 AM
Quoted: 476 Post(s)
Liked: 74
KGO-DT has an ERP of 561K. It's about the average. Some of the stations are higher powered, some are lower as shown in the list below. Each station is licensed for the power of their transmitter times the gain of their antenna. Everyone in the Bay Area is putting out all they can with the equipment they have.
Larry
Channel - PSIP Virtual Channel - Effective Radiated Power*
12 - 11.1 - 8.9 KW
19 - 20.1/20.2 - 383 KW
24 - 7.1/7.2 - 561 KW
29 - none - 1000 KW
30 - 9.1/9.2 - 777 KW
45 - none - 206 KW
52 - 36.1/36.2 - 251 KW
56 - 2.1 - 501 KW
57 - 4.1 - 1000 KW
*=From http://100kwatts.tmi.net/tv/SFO.html
The other stations that aren't on the air are also listed there.
post #6 of 6 Old 04-21-2002, 12:01 PM
NiteWrider's Avatar
Larry,
Thanks for posting this data.
I did a little testing this morning and found that the lower power transmitters may not be the cause of my reception quality.
Location - Channel - PSIP Virtual Channel - Effective Radiated Power - Sony 57XBR2 Meter
San Jose - 12 - 11.1 - 8.9 KW - 72% (mostly solid)
SF/Mt. Sutro - 19 - 20.1/20.2 - 383 KW - 56% (mostly solid)
SF/Mt. Sutro - 24 - 7.1/7.2 - 561 KW - 56% (mildly solid)
SF/Mt. Sutro - 29 - none - 1000 KW - 60% (solid)
SF/Mt. Sutro - 30 - 9.1/9.2 - 777 KW - 72% (solid)
SF/Mt. Sutro - 45 - none - 206 KW - 48% to 56% (mostly dark, never solid)
Fremont - 52 - 36.1/36.2 - 251 KW - 60% (solid)
SF/Mt. Sutro - 56 - 2.1 - 501 KW 48% to 56% (mostly dark, never solid)
SF/Mt. Sutro - 57 - 4.1 - 1000 KW - 60% (solid)
Closed Thread Local HDTV Info and Reception
