HD Masters in Houston - KHOU-DT - AVS Forum | Home Theater Discussions And Reviews
Old 04-11-2002, 03:23 PM - Thread Starter
merc's Avatar
Well initially we had some very bad audio echo but now that is gone. It sure does look pretty but I am getting intermittent pixelization, image freezing, and occasional dolby audio dropouts, and not at the same time. Is anyone else seeing this as well?
Although it may be OTA reception problems causing this for me, I usually receive CBS perfectly. I wonder if KHOU is not using full power since this is not a prime time period for HD broadcasting?
I guess I'll find out tonight for CSI and the Agency???
merc is offline
Old 04-11-2002, 03:51 PM
PassedPawn's Avatar
I am getting some of the same noise... about every 30-60 seconds some kind of pixellation or compression error.
I am in Tampa.
#include stdsig.h
PassedPawn is offline
Old 04-11-2002, 05:16 PM
sfmartin's Avatar
Same in San Antonio
sfmartin is offline
Old 04-11-2002, 07:38 PM
Ken H's Avatar
Please see this topic:
http://www.avsforum.com/avs-vb/showt...hreadid=132416
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
