Do I Need An Outdoor Terk Ant. Or Can I Use My $30 RCA? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-11-2002, 06:33 PM - Thread Starter
McPatrickClan's Avatar
I have seen many people note the Radio Shack bowtie ant., and I wonder if I need to install an outdoor ant.? Can I just use my RCA ant. that I have been using for years? I receive fair reception for my local channels here in Dallas. I assume that you just pull down the HDTV locals and then tune them in digitally with your set-top box.
Thanks for your feedback!
Do you have questions about life? Ask me.
McPatrickClan is offline
post #2 of 7 Old 04-11-2002, 06:40 PM
DP1
DP1's Avatar
Well what exactly is a $30 RCA antenna?? You mean like rabbit ears and a UHF loop? Yeah, that can work. It just depends on all the other variables like distances from the transmitters and such.
But I use one of those type antennas on one of my 2 digital tuners and it receives 3 out of 4 of my local digital channels. I do need an outdoor one for the other channel which is stupidly low power.
Anyway, try it and see.
Dan
Don't confuse me with facts...
My mind is made up.
DP1 is offline
post #3 of 7 Old 04-11-2002, 06:42 PM
DAP
DAP's Avatar
From some of the reviews of Terk antennas, you might be better off with a wooden coat hanger. At the very least they are way too expensive. If that $30 RCA is already installed, give it a try before you start spending money on other things, if it worked for analog, it will certainly work for digital.
DAP is offline
post #4 of 7 Old 04-11-2002, 07:21 PM - Thread Starter
I gotcha fellas. So if I live in an area that has strong power signals, a piece of tin foil would do. If you live in the sticks with a low power station far away, you may need a serious ant.? Correct me if I am wrong!
post #5 of 7 Old 04-12-2002, 10:36 AM
Chris Williams's Avatar
The 80" Radio Shack outdoor antenna is on sale, and does a great job. Stay, far, far away from Terk.
Chris Williams is offline
post #6 of 7 Old 04-15-2002, 10:02 PM
veinboy's Avatar
Why?
veinboy is offline
post #7 of 7 Old 04-16-2002, 12:23 PM
fishman's Avatar
Stay away from Terk! Get a real antenna. Try contacting Warren Electronics a get A Channel Master 4228 Bowtie! THE BEST FOR RECIVING HDTV SIGNALS! www.warrenelectronics.com !
fishman is offline
Closed Thread Local HDTV Info and Reception
