Battling Wind and Rain with OTA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-14-2002, 11:50 AM - Thread Starter
msamji's Avatar
I'm using the 57inch Winegard YAGI antenna in Bellevue. Wa and have had a good amount of success.
The problem that I have is that I am down in the valley, and have a good number of trees between me and Seattle.
When its a calm day, i can pickup ABC, CBS, and NBC.
But if there is any strong wind, the signal goes out the window and I start to see some strong multi-path.
Would a larger antenna, or an antenna with more active elements work better? Or is this just a loosing battle against the wind with UHF?
I was thinking about trying the CM 4248. I was also told to try the Antenna Craft antenna MX56 I think since I was told that it has 4 active elements.
Any ideas?
thanks
M. Samji
msamji is offline
post #2 of 2 Old 04-15-2002, 06:12 AM
jhe
jhe's Avatar
You need a rotor if you don't have one. Rain changes where you need to aim. Other than that you can try going higher to see over the trees, or you can get a more directional antenna as you mentioned. And use oversize masts, etc to make sure your antenna at least is very stable in the wind.
jhe is offline
Closed Thread Local HDTV Info and Reception
