Had to rotate Ant. 80 degrees to recieve CBC and FOX NY digital - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-16-2002, 07:42 AM - Thread Starter
LJG
LJG's Avatar
Quoted: 330 Post(s)
Liked: 142
I panicked on Saturday when I was receiving drop outs and low readings on the HD reciver(60-70 signal strength). Previously I was recieving a signal strenght in the low 90's.
My area Zip Code is 11545
I rotated ther antenna almost 80 degrees and low and behold I was in the low 90's again.
I wonder why I needed to rotate the antenna after almost one year?
LJG
LJG is online now
post #2 of 3 Old 04-16-2002, 08:52 AM
jackcs's Avatar
I also noticed that CBS, previously optimally tuned with a large Yagi in the attic has dropped completely out. My RS bow-tie by the set still gets so I am sure I can repoint and get it back. Something defintely changed
jackcs is offline
post #3 of 3 Old 04-16-2002, 01:04 PM
Blue Rain's Avatar
Quoted: 140 Post(s)
Liked: 40
Which way was your antenna pointing before you moved it?
Also, which way is pointed now after you turned it?
I noticed dropouts last night for thr first time ever. Something changed.
Blue
Polk 7.1
Samsung PN60F8500
73" 73738 Mits DLP
Onkyo TX-NR3008
Panasonic AE4000 Projector
Blue Rain is offline
Closed Thread Local HDTV Info and Reception
