HDTV broadcast status - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-16-2002, 11:43 AM - Thread Starter
dirk1843's Avatar
Quoted: 12 Post(s)
Does any one know if there is a web site(or other resource) that confirms the broadcast of digital signals for each station, and if they are HD quality or just "enhanced" NTSC??
I've seen things you wouldn't believe. Attack ships on fire off the shoulder of Orion. I watched C-beams glitter in the dark near the Tannhauser gate.
dirk1843 is offline
post #2 of 4 Old 04-16-2002, 12:40 PM
Lee Wood's Avatar
The closest thing is www.titantv.com, they actively try to get the information from the stations about what it is they are doing. You can also check the CEA's 'DTV Guide' listing of stations at: http://www.ce.org/publications/books...ting_apr02.pdf (this is a PDF file).
Lee Wood is offline
post #3 of 4 Old 04-16-2002, 03:01 PM
agtiny's Avatar
You can also try www.hdtvpub.com but it's pretty dependent upon user submissions and I'm not sure how much traffic it gets.
agtiny is offline
post #4 of 4 Old 04-16-2002, 03:03 PM
jhe
jhe's Avatar
I also use http://www.100000watts.com
Too bad all these sites seem to be out of date somewhat.
jhe is offline
Closed Thread Local HDTV Info and Reception
