PSIP in the DC Area - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-17-2002, 05:26 PM - Thread Starter
Scot Kight's Avatar
Quoted: 24 Post(s)
Does anyone get program information in the dc area? I am using a dish6000 and when I do get it, its on the wrong channels.
So it will give me "NYPD Blue" on fox.
Anyone have a fix for this?
Scot Kight
"Don't touch that, this isn't your house and that isn't your tv!" she says.
"But look at it, the contrast is completely blown out, the color is all off and that tint. This will only take a sec..."
Scot Kight is offline
post #2 of 3 Old 04-19-2002, 07:47 AM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
The dish 6000 does not fully support PSIP, it will only display the Virtual
and minor channel along with part of the short name, ie: 18-1 WCCB-
It will NOT display ANY of the EPG from local OTA.
Mine shows us here as being ABC for some reason.
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #3 of 3 Old 04-19-2002, 10:50 AM
Belcherwm's Avatar
You can go into the local channel setup and change your analog station to the right broadcast network, not FOX though. Then you can use the program info from the OTA analog and just turn to your OTA digital. Even though the analog guide may say "info not avaiable" just push the info buttom and it will usually be there 24/7.
Belcherwm is offline
Closed Thread Local HDTV Info and Reception
