Jitter and Blur - AVS Forum | Home Theater Discussions And Reviews
Old 04-18-2002, 05:19 PM - Thread Starter
era
era's Avatar
I've now had HDTV via Time Warner cable here in Greensboro NC for a couple of weeks and I'm pretty happy, but there's one thing...
The HDTV Demo channel is super--smooth pans, ultra-sharp definition of details. Quite what I was hoping for.
But.........the downside is the two movie channels....
The HBO movies almost always stutter or jitter during a pan--it seems as if the frame rate is about half (15 per second) what it should be and the image stammers across the screen like ABS braking does with a car. Also, the images are softer, less sharp than the Demo channel. Why is this?
I'm not mentioning the Showtime HDTV channels because they are almost always unwatchable--wrong aspect ratio for my widescreen TV and generally fuzzy.
Thanks for any answers...
era is offline
