WTTW Chicago Problem - Two 11-1s - AVS Forum | Home Theater Discussions And Reviews
Old 04-21-2002, 11:53 AM - Thread Starter
WishIdInventedTivo's Avatar
Is anyone experiencing a problem with WTTW? Do you have 11-1 listed more than once?
I have a Zenith DTV1080. A few days ago I made the mistake of going into the channel list to activate a previously hidden channel. It was storming and I had lost the DirecTV signal. Well, apparently this is a bad time to enter the setup menu. (Note to self: don't do this again during any sort of signal disruption.) The STB suddenly started rebuilding the channel list.
Now I have two 11-1s. The one that doesn't display a signal is "WTTWD", the one that works has no station identification. I've tried rescans and manually entering a scan for channel 47 with no success. There is no option to delete a channel, but my understanding was that the rescan would remove non-existant channels. Both 11-1s are still there.
Anyone else seeing this? Does your 11-1 show WTTWD or a blank station identification?
WishIdInventedTivo is offline
Old 04-21-2002, 12:00 PM
vruiz's Avatar
There's a Local Info forum now, you know.
vruiz is offline
Old 04-21-2002, 12:14 PM
abbey641's Avatar
I get the same thing. They're data that sends you the 11.1 tag is directed to their analog channel instead of their digital. Hopefully they figure it out. In the mean time, you need to hit 47.1 to see the digital channel.
abbey641 is offline
Old 04-21-2002, 04:31 PM - Thread Starter
I didn't know that, thanks.
