SF-Bay NBC gone from 20-2? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-24-2002, 09:28 AM - Thread Starter
GQB
GQB's Avatar
I've been getting no content, but 100% signal from the SD feed of NBC (that's been piggy-backing on 20-2) for a couple of days now.
Have they stopped their agreement now that the Olympics is over?
If that's so, then I REALLY hope that NBC keeps doing special arrangements with HDNet... Bay area is screwed for NBC SD signal, let alone HD.
-jerry
GQB is offline
post #2 of 7 Old 04-24-2002, 10:01 AM
Ken Erickson's Avatar
I noticed that too last night. I don't know what could have happened. NBC hasn't completed the take-over of KNTV yet. As far as HDNet doing more for NBC - don't hold your breath.
Ken Erickson is offline
post #3 of 7 Old 04-24-2002, 03:45 PM
glgorman's Avatar
Late Monday night 20-2 had a still frame image that said something to the effect of "Subscription required for this DISHNet channel. Call 888- blah blah blah or change the channel". Later it turned to a different static promo image for DishNet with some background music.
No warranty is either expressed or implied. The universe is a figment of its own imagination. Your milage may vary. Not responsible for lost homework, missed bus transfers, or forgetting to buy a lottery ticket the day they run your birthday. Have fun.
Have spectrum analyzer, will travel.
glgorman is offline
post #4 of 7 Old 04-24-2002, 03:51 PM
dagman's Avatar
I guess you can't pick up KNTV? You live up in the North Bay?
dagman is offline
post #5 of 7 Old 04-24-2002, 04:14 PM
glgorman's Avatar
I'm in Martinez (in Contra Costa County). I get 11 and 12 (DTV) just fine using a 6 element Winegard dedicated Hi-VHF Yagi at about 41 feet. The signal is often more solid than the Sutro DTV signals, but nowhere near what I get out of Sacramento. I was just channel surfing and checking everything out the other night after the Mitsubishi upgrade when I discovered that apparently channel 20 gets their DTV feed for NBC3 from DishNET???
glgorman is offline
post #6 of 7 Old 04-24-2002, 06:47 PM
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
I recently have been observing a stutter or momentary freeze occuring on KNTV 12-1. During the Olympics I had no problem with the signal or reception. I am in Sunnyvale and am picking up KNTV off of the side of a UHF antenna pointed at Sutro. If others are getting a clean KNTV signal I guess I need to put up a small VHF roof mount antenna aimed at 12-1. Are those of you receiving 12-1 getting it clearly with no breakups or stutters? I am using a Unity Motion receiver and get all of the Sutro stations clear as a bell. I just want to be sure it is not a KNTV problem before I add an antenna and combiner.
..Doyle
M&K S150THX LCR, SS150THX Tripoles, 4 Speakercraft Aim-7 for Atmos
B&K AV5000 driving the M&Ks
Denon X4300H AVR
"So many tweeks....So little time!"
DoyleS is offline
post #7 of 7 Old 04-25-2002, 12:29 PM
NiteWrider's Avatar
I've been noticing the hiccups too, but then again, I'm about 55 miles from the KNTV transmitter(s) w/ mountains in between.
The interesting thing is that I can see the hiccups simultaneously on analog 11. Thanks to the split-screen feature on my set, I can tune into Ch. 12 on the left and Ch. 11 on the right. When the digital hiccup occurs on Ch. 12, a short burst of static-like interference occurs on Ch.11.
Maybe VHF is more susceptible to interference? If so, what kind of amateur/professional equipment is likely to cause interference on the same frequency as Ch. 11/12?
NiteWrider is offline
Closed Thread Local HDTV Info and Reception
