Looking for KGO & KQED DT bcst SFO area - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-24-2002, 11:23 PM - Thread Starter
N6SPP's Avatar
== Receiving from Sutro: FOX,KRON, NBC, CBS, WB, UPN-
all are solid sigs into N.SFO ....
== Where are KGO (24.1?) , and KQED (30.1?) ??
== rcvr:HD100 sony thanks, Rick
N6SPP is offline
post #2 of 6 Old 04-25-2002, 06:52 AM
Ken Erickson's Avatar
KGO and KQED are both on Mt Sutro.
Ken Erickson is offline
post #3 of 6 Old 04-25-2002, 09:03 AM - Thread Starter
N6SPP's Avatar
Bcst location ok- do i have the
right virt. channels? I understand KGO was off earlier this month..
== Just can't find kqed and kgo sigs off of Mt.Sutro (all other
stns from Sutro are 97% sig strength=sony HD100)..
thanks agn, Rick
N6SPP is offline
post #4 of 6 Old 04-25-2002, 09:24 AM
Have you tried to manually add KGO (24-1) and KQED (30-1)? Have you tried turning off the APG? You might want to try searching for DTC100 problems. I've seen a number of threads regarding the APG causing problems (but not for just KGO & KQED).
post #5 of 6 Old 04-25-2002, 02:10 PM
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
Sounds like a receiver problem. Both KGO and KQED have excellent signals with almost zero downtime. KGO has HD and SD signals. I don't have a Sony HD-100 so I can't help there.
..Doyle
M&K S150THX LCR, SS150THX Tripoles, 4 Speakercraft Aim-7 for Atmos
B&K AV5000 driving the M&Ks
Denon X4300H AVR
"So many tweeks....So little time!"
DoyleS is offline
post #6 of 6 Old 04-25-2002, 05:00 PM
fishman's Avatar
I have a DTC100 and receive a strong signal for KQED(78+ss), KGO (74+ss) and KRON ( 58+ss) all from a tough area/San Anselmo/Ross area in Marin. I CANT PICK UP ANY OTHERS! Its all really crazy as it makes NO sense to me since they all come from Sutro. A eng. from KPIX said to go to a full scan on receiver and just keep making some incremental adjistments. He also pointed out that there transmitter points slighly down to capture the low lying areas of the city. So, my take is that its not just the distance and outpoint , but maybe more to do with directionality.
fishman is offline
Closed Thread Local HDTV Info and Reception
