TWCNYC downtown tribeca - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-25-2002, 12:30 PM - Thread Starter
zielin's Avatar
Quoted: 130 Post(s)
Liked: 79
woop! of course without notice, i have digital cable. During my monthly call to them to see if service is in my area yet.. *poof* yes it is! digital and road runner.
now all that is left if that damn HD receiver. we are all looking @ june, aren't we?
i assume CBS is still being pumped thru and i can hook that up to my hipix.
what kinda spliter do i need? 1ghz one? can i get anything else?
TV: LG OLED65G6P, LG OLED55C7P (bedroom) | Receiver Denon AVR-X7200WA
Speakers 7.1: PSB Imagine T2 Towers, PSB Imagine C3 Centre, Imagine S Surround, PSB HD10
HTPC: i7-5960X @ 4.6ghz, DDR4 16gigs, Samsung 960 pro NVme, Intel 750 NVMe 1.2gig X 2, GTX Titan XP (SLI)
Sources: Oppo UDP-203, Tivo Bolt+, Xbox One S, PlayStation 4 Pro | Control: Logitech Harmony Elite, Xbox One Elite Controller.
zielin is online now
post #2 of 2 Old 04-25-2002, 02:43 PM
bsd
bsd's Avatar
A 1 Ghtz splitter is fine. Just insert the raw coax into the hipix. I'm not familiar with the hipix, but most boxes recognize the TWC signal as an OTA antenna signal (8VSB), not an HD cable box signal. You should be able to get CBS-HD. As far as I know, that is all you can get without the SA 2000HD box. With the box, you will be also able to get NBC, HBO and SHO. Good luck.
-Brett
bsd is offline
Closed Thread Local HDTV Info and Reception
