Dayton / Lima, OH - HDTV - Page 224 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #6691 of 6719 Old 11-30-2015, 08:45 AM
mvcg66b3r's Avatar
Quoted: 102 Post(s)
From the Cincinnati HDTV thread:
Originally Posted by Balloonfanatic View Post
26-3 is going to be ION tv nov.30,2015.
Incidentally, Channel 26 was once an ION/PAX O&O.
From Wikipedia:
In the mid-1990s, Abry Communications (which had purchased WRGT-TV's owner, Act III Broadcasting) approached MVCT with a proposal to manage WTJC for eighteen hours a day. MVCT declined and chose instead to sell the station to Paxson Communications in 1995. Paxson kept a similar lineup for WTJC, airing religious programming in early mornings, infomercials for most of the day and worship music overnight. In January 1998, WTJC's call sign was changed to WDPX (for Dayton PaX). Accordingly, later that year, the station became a charter affiliate of Pax (now Ion Television).
In summer 1999, Paxson sold the station to ACME Communications, which dropped most Pax programming for a primary affiliation with The WB, along with syndicated programming; the previous WB affiliate was WUCT-LP (now WRCX-LP). ACME also changed WDPX's call sign to the current WBDT. WBDT maintained a secondary affiliation with Pax until mid-2004 at the latest, airing its primetime lineup (Touched by an Angel, Diagnosis: Murder, Weakest Link, etc.) on weekday mornings from 9 a.m. to noon and weekend late nights from midnight to 4 a.m.
https://en.wikipedia.org/wiki/WBDT
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is online now
post #6692 of 6719 Old 12-04-2015, 07:57 PM
tim58hsv's Avatar
Quoted: 20 Post(s)
AntennaTV is on 22.3 right now. Not sure why since the launch was to be 1-1-16.
Maybe it's only a test?
Name:	Snap 2015-12-04 at 21.42.54.png
tim58hsv is offline
post #6693 of 6719 Old 12-04-2015, 08:20 PM
tim58hsv's Avatar
Quoted: 20 Post(s)
Grit is now on 22.4 so it looks like WKEF will have three diginets instead of two.
tim58hsv is offline
post #6694 of 6719 Old 12-05-2015, 03:30 PM
Liked: 5
Ion is now on 26.3
tim58hsv likes this.
TNGTony is offline
post #6695 of 6719 Old 12-20-2015, 08:15 AM
skylab's Avatar
Four subchannels? I guess our local networks care nothing about picture quality on the main -1 subchannel.
So does DirecTV now run fiber in Dayton from the broadcasters? If so, that would appear to confirm what I am seeing -- the picture quality of directv is now noticeably better than OTA.
skylab is offline
post #6696 of 6719 Old 12-20-2015, 11:37 AM
hall's Avatar
Quoted: 320 Post(s)
Liked: 160
If I'm not mistaken, cablecos and satellite providers receive - or can - each channel directly, hence no loss of bandwidth (PQ). The only people who will see a reduction are the minority of viewers who get the stations via OTA.
hall is online now
post #6697 of 6719 Old 12-21-2015, 12:45 PM
dtv insider's Avatar
In Dayton market Satellite providers pick up the OTA signal decode the HD channel compress it and send out west to a uplink site. Time Warner has a fiber line into the station and picks up the ASI stream that is the same stream that is feed to the transmitters site. That is the reason the station can be off the air and cable still has programming.
dtv insider is offline
post #6698 of 6719 Old 12-21-2015, 12:58 PM
hall's Avatar
Quoted: 320 Post(s)
Liked: 160
I have Dish and when one of the local stations had an antenna outage, we were unaffected.
Many years ago, one of the engineers at WHIO told me that their facility, when it was on Wilmington, was the consolidation point for the local stations to both Dish and Directv and he indicated that they received the signals by fiber from each station.
hall is online now
post #6699 of 6719 Old 12-31-2015, 04:29 PM
tim58hsv's Avatar
Quoted: 20 Post(s)
WDTN 2.2 in Dayton, Ohio has finally dropped the SD version of their main channel and replaced it with Escape TV.
Paul210 likes this.
tim58hsv is offline
post #6700 of 6719 Old 01-02-2016, 08:58 AM
luvmyhdtv's Avatar
Hope its something we don't already have in Cincy or Dayton lol. Has anyone heard if WRCX or WWRD are ever going digital? I've gotten a weak analog signal in the past here in Clermont County.
KU 36" dish / C band 8' dish no longer hooked up, 47" Vizio 3D Tv with Philips 3D Dvd player, Gateway 3.6Ghz - 2Tb computer for home theatre setup
Old style CM4228 and 91XG antennas for OTA.
luvmyhdtv is offline
post #6701 of 6719 Old 01-03-2016, 07:31 PM
LilBro's Avatar
Inline amp / splitter suggestion
TV Fool: http://www.tvfool.com/?option=com_wr...b97d1510723788
We have Dish but want to also use OTA. We are located in Wilmington, about 2 miles from the air park on SR 134. I first hooked up our main flat panel and got pretty much all the Dayton & Cincy OTA stations. When I added a splitter so I could reconnect my stereo I lost the psuedo-religous channels but none of the others. I want to add one or two other televisions to the OTA antenna in our basement. The one will be about 30' from the drop, the other about 10'. Adding an amp to the tower is not an option.
What would be a good line / signal amp & splitter for this set up? I will probably need to connect two cables together to make the long run.
Thank you.
Für Elise  Support the Heart & Breast Cancer Foundations
LilBro is offline
post #6702 of 6719 Old 01-05-2016, 09:03 PM
Balloonfanatic's Avatar
Quoted: 55 Post(s)
Liked: 40
Thank you.
I just use a $20 10db. 4 output distribuion amp. from lowes at my house in sharonville. if it doesn't work you can return it. I tried a more beefier amp. in the past and the more powerful amp. actually caused me to loose channels(too much signal).
if you want more information I would suggest posting on the cincinnati avs forum. several television owners and station engineers are very active on the cincinnati forum.
Balloonfanatic is offline
post #6703 of 6719 Old 01-27-2016, 09:13 AM
Quoted: 55 Post(s)
Liked: 40
Ch. 2 is running commercials for the Justice Channel coming monday to channel 2.3.
post #6704 of 6719 Old 01-29-2016, 07:52 PM
Liked: 0
I'm receiving 2.3 Justice tonight(Fri).
DarkeRider is offline
post #6705 of 6719 Old 01-29-2016, 09:04 PM
tim58hsv's Avatar
Quoted: 20 Post(s)
They may have done a test run as it's not coming in here.
tim58hsv is offline
post #6706 of 6719 Old 01-30-2016, 11:06 PM
Liked: 5
Not showing up for me either right now. Must have been a quick test.
TNGTony is offline
post #6707 of 6719 Old 01-31-2016, 07:18 PM
tim58hsv's Avatar
Quoted: 20 Post(s)
The Justice Network is now on channel 2.3 in Dayton, one day early.
tim58hsv is offline
post #6708 of 6719 Old 02-10-2016, 05:49 PM
tim58hsv's Avatar
Quoted: 20 Post(s)
Apparently WKEF 22 has been advertising the American Sports Network coming Monday Feb. 15 on 22.2. So will GetTV, which currently airs on 22.2 be going away this time?
tim58hsv is offline
post #6709 of 6719 Old 02-10-2016, 08:52 PM
microbob's Avatar
Quoted: 35 Post(s)
Liked: 26
Maybe Get TV will move to WRGT 45.4 since they only have 3 subs.
Robert
microbob is online now
post #6710 of 6719 Old 02-15-2016, 11:25 AM
Nitewatchman's Avatar
Quoted: 33 Post(s)
Liked: 25
Currently, At 13:24 2/15, ASN is now up on 22.2, GetTV is gone from WKEF, WRGT hasn't changed anything.
Paul210 and tim58hsv like this.
Jeff
Nitewatchman is offline
post #6711 of 6719 Old 03-14-2016, 09:31 PM
tim58hsv's Avatar
Quoted: 20 Post(s)
For anyone that misses WHIO's 7 Weather Now broadcast which formally aired on 7.2, it's still available online at http://www.whio.com/videos/news/whiotv-live-news/vwy9N/ and it still looks just like it use to except the video quality seems better with the online version.
Paul210 likes this.
tim58hsv is offline
post #6712 of 6719 Old 08-25-2016, 01:35 PM
Bubster's Avatar
Quoted: 17 Post(s)
Looks like 7.2 METV is zooming lately? Why?
Have seen some pretty impressive quality for WS SD on 45.3 Comet when they show Stargate SG-1.
Bubster is online now
post #6713 of 6719 Old 08-25-2016, 04:50 PM
microbob's Avatar
Quoted: 35 Post(s)
Liked: 26
I know METV is available in HD but not in Dayton or Cincinnati. Maybe they are gearing up to have METV in HD.
Robert
post #6714 of 6719 Old 08-25-2016, 04:58 PM
Bubster's Avatar
Quoted: 17 Post(s)
Do they have the bandwidth? I have to do a little research, I haven't been keeping up lately. Seems like I saw mention of a new and improved OTA technology.
post #6715 of 6719 Old 08-25-2016, 06:30 PM
microbob's Avatar
Quoted: 35 Post(s)
Liked: 26
It's possible to add a 720p sub and have minimal effect on the main channel with current technology. WKRC TV has a 1080i main with a 720p and a 480i sub channel.
Robert
post #6716 of 6719 Old 10-06-2016, 07:42 PM
er824's Avatar
Quoted: 31 Post(s)
Is anyone having trouble getting WHIO-DT? I have an antenna in my attic, I'm getting all the other Dayton and Cincinnati networks. The signal strength meter in Windows Media Center shows full strength for everything other then WHIO-DT which is one bar.
er824 is offline
post #6717 of 6719 Old 10-26-2016, 03:02 PM
Unhappy
Yes the new OTA technology has been send to the FCC . (ATSC 3.0)
And by the way no tuners in any TV in the US will be able to pick it up.
Watch out for a new settop box to going with your new 4K TV.
post #6718 of 6719 Unread Yesterday, 05:47 AM
tim58hsv's Avatar
Quoted: 20 Post(s)
WRGT 45 will be adding Charge! TV to 45.4. Just did a scan and WRGT has already added 45.4 but is currently showing ThisTV (45.2) until Charge is ready to launch.
Paul210 likes this.
tim58hsv is offline
post #6719 of 6719 Unread Today, 03:28 PM
Bubster's Avatar
Quoted: 17 Post(s)
I would gladly trade this new channel for correct aspect ratios on GRIT and METV. Why do they do this?
Sorry for the rant :-P
