ota reception - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-29-2002, 05:00 PM - Thread Starter
Jerry A's Avatar
Can anyone suggest a good antenna technican. I am at my wits end trying to get local dtv reception. My reception sucks and I am only 11 miles from three transmitters, have a radio shack uhf antenna installed w/ preamp, and 40 ' up. Best signal I can get is 60 on one station and 23 on another, and 0 on the third. All towers are within 4 degrees of each other.:confused:
Jerry A is offline
post #2 of 2 Old 05-01-2002, 12:30 PM
sregener's Avatar
Well, you don't really give us a lot of information about what you're using right now. Radio Shack makes any number of UHF antennas.
*However*
You say you're 11 miles away and you're using a preamp? At this range, you might very well be overloading your receiver with signal. Have you tried reception without a preamp to compare? Even without a preamp, depending on your antenna, you may *still* be getting too much signal.
Unless you have extreme mountainous terrain, which could make reception difficult under any and all conditions, you might want to try Radio Shack's single and double-bow-tie antennas at ground level. Since you can return them for any reason, there's no harm in trying them out.
Finally, what's your analog UHF reception look like? Is it good/fair/poor?
Good luck!
sregener is offline
Closed Thread Local HDTV Info and Reception
