DTV antenna catches fire in Lubbock, TX - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-30-2002, 06:43 AM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
This article says it all!
Pete
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #2 of 10 Old 04-30-2002, 07:44 AM
woowoo's Avatar
Holy smoke!
Broadcast Engineer
woowoo is offline
post #3 of 10 Old 04-30-2002, 07:52 AM
M Chiarulli's Avatar
from station website:
Effort to be the First Digital Station Back on Track
Early Sunday evening, an apparent electrical short caused a fire atop NewsChannel 11's approximately 800 foot tower antenna. No one was injured. Monday, the damaged antenna was removed from our tower.
KCBD General Manager Bill deTournillon says a replacement antenna is on it's way. In the meantime, there should be no visible interruption in programming to most of our viewers. The new antenna should be in place in about seven to ten days. The digital signal is expected to be on air by mid-June.
Michael Chiarulli
Director, Telecommunications & Distribution Services
ABC-TV
M Chiarulli is offline
post #4 of 10 Old 04-30-2002, 11:30 AM
SeanKelly's Avatar
Holy smoke!
No pun intended, of course?
Sean Kelly / Independent Consultant
http://www.seankelly.tv/
SeanKelly is offline
post #5 of 10 Old 05-01-2002, 01:10 PM
George Molnar's Avatar
The station has streaming video of their DTV antenna flamout, see http://www.kcbd.com/Global/story.asp...6&nav=3w6y8iqg
George Molnar is offline
post #6 of 10 Old 05-04-2002, 09:16 AM
RMP in KY's Avatar
Let me ask a dumb question of the broadcasters here: What part of a metal tv antenna is flammable?
RMP in KY is offline
post #7 of 10 Old 05-04-2002, 09:57 AM
Akenyon's Avatar
Looks like the part that burned was the fiberglass radome. It also looks like the antenna was an interesting combination of a channel 11 turnstile with a channel 43 slot radiator or similar design. That sort of combination is not trivial to construct and there is a whole lot of plumbing under the radome including some apparently flammable insulation which along with the fiberglass resins made for a toasty tower top.
Akenyon is offline
post #8 of 10 Old 05-04-2002, 10:03 AM
Kipp Jones's Avatar
Ok, I think this station gets an extention!
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #9 of 10 Old 05-04-2002, 10:43 AM
proehm's Avatar
Need to ground test those de-icers first.
Paul Roehm
WRTV, Indianapolis
paul_roehm@wrtv.com
proehm is offline
post #10 of 10 Old 05-06-2002, 01:50 PM
hphase's Avatar
You would hope that they would do some full-power testing prior to stomping on the gas on May 1st (the deadline.)
hphase is offline
Closed Thread Local HDTV Info and Reception
