Buffalo, NY - HDTV - Page 250 - AVS | Home Theater Discussions And Reviews
 15Likes
post #7471 of 7476 Old 02-27-2015, 08:58 AM
Liked: 2
Send a message via Skype™ to FoxChief
Originally Posted by dsspredator View Post
I can't record FOX programs on WUTV because my DRV defaults to SAP 1 and WUTV moved their 5.1 audio to SAP 2.
I contacted them with no response. Does anyone here have a contact at WUTV?
Neither WUTV nor Fox Broadcasting moved the 5.1 anywhere, or changed a thing. It's always been on the same channels since 2005....But if you have anything at all on the front end of your TV, check your downmix if possible. I know you said you're watching OTA, but the equipment you're using suggests you are a satellite subscriber, because I watch OTA, with a roof antenna, and I don't have any issues at all, which is why this concerns me. I would like to try to help, but I need more to go on.
Another concern is, saying that you contacted us with no response. I respond to all viewers that call about everything a lot during the day, and return their calls if they leave a message and a phone number. I'm not as quick to check this AVS Forum site, but I am diligent at returning calls. But you have to, at least, meet me half way. If it's after hours, perhaps leaving a message with your phone number and your concern usually gets a response. It's usually better if you know with whom you need to speak if you call at all. Asking to speak to someone in engineering, during the day, is usually a good idea because we can answer questions like this. But saying "..no one responded to my call", doesn't necessarily mean you actually called this facility. It makes it sound like you're angry and wanting to point a finger at someone., when the problem could be right in front of you.
videobruce likes this.
FoxChief is offline
post #7472 of 7476 Old 02-27-2015, 09:15 AM
Liked: 2
Just a footnote.... by saying we haven't changed a thing...I'm talking about the procedure Fox uses to splice their network signal in and out. I'm not referring to the addition of GritTV to our stream, which would have absolutely nothing to do with this problem he's having.
FoxChief is offline
post #7473 of 7476 Old 02-27-2015, 10:01 AM
videobruce's Avatar
Quoted: 399 Post(s)
Liked: 189
Originally Posted by videobruce
He mentioned recoding on a Dish DVR.
Not quite. He said:
Recording OTA (RF 14) on a Bell 6141 (same
Then I have to assume this satellite companies receiver/DVR also has a OTA tuner?
Abundant OTA television is what makes this country different from all others. Lets keep it this way. If you like Wi-Fi so much, OTA fits right in. After all, it is wireless.
videobruce is offline
post #7474 of 7476 Old 02-27-2015, 10:19 AM
MPNASCAR24's Avatar
Quoted: 25 Post(s)
Liked: 26
I recently checked WUTV'S OTA Signal at my aunt's house which is closer to buffalo than mines & the sound for all programming appeared to be normal. Looks like dsspredator's problem has to be his equipment because FoxChief said no changes have been made to there 5.1 audio.
MPNASCAR24 is offline
post #7475 of 7476 Old 02-27-2015, 12:04 PM
unclehonkey's Avatar
Quoted: 83 Post(s)
Liked: 26
yes. Bell used Dish equipment but with their own software and model number. The guts are the same
So it almost sounds like its a setting in the receiver itself that needs to be changed. This sounds stupid but there is an option in the receiver that says "alternate audio" and gives other options. Maybe the poster needs to mess with that setting
unclehonkey is online now
post #7476 of 7476 Unread Today, 10:31 PM
Warrenl's Avatar
I don't really expect to get an answer to this question, but since it is obivious that WUTV and WNYO's staff appear to check the forum, I will ask. Has anyone heard if WNYO will build out on its construction permit and install a new antenna? I know the permit runs out on March 20th and I doubt the weather would permit them to install a new antenna, but you never know.
Warrenl is online now
