Buffalo, NY - HDTV - Page 255 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #7621 of 7629 Old 05-15-2017, 12:23 PM
Trip in VA's Avatar
Quoted: 831 Post(s)
Liked: 252
Send a message via AIM to Trip in VA
I decided to delve into it a bit. If I put WNYB on channel 9, it causes 3% interference to WHAM and 13% interference to CKVR in Canada. If I put it on channel 10, it causes 3% interference to WHEC and 30% interference to CFPL in Canada. Suffice it to say, neither is acceptable.
WBNF-CD is a Class A station, which until the Incentive Auction, was treated just like an LPTV by Canada and thus was not protected from full-power stations like CHCH. (Even though it would be protected from US full-power stations.) It receives 16% interference from CHCH.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #7622 of 7629 Old 05-16-2017, 07:32 PM
Warrenl's Avatar
Originally Posted by videobruce View Post
Other than the current sole 'local' and CFTO out of Toronto, Erie PA, Kitchener and especially Olean are out also. The two county's north of here, Kitchener would be receivable and the southtowns along the lake, Erie PA may be possible.
Actually WVTT Olean, is on tower north of Machias and just south of Springville. In theory they should put great signal into Buffalo, they don't, but that is not because of their location, or assign power level. Not sure of WVTT strategy, they would be a perfect station to use for experimenting with the new 3.0 broadcast standard in the Buffalo area. Currently they are broadcasting This TV on an analog translator Ch. 20 in Olean and putting a solid analog OTA signal in Olean.
Warrenl is offline
post #7623 of 7629 Old 05-25-2017, 10:11 AM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
WBBZ/ ME-TV audio
I have noticed in the past 3 or so weeks WBBZ's audio has gotten terrible. Somewhere along the food chain the level has been cranked up to a point a limiter is clipping with the low level material at the same level as the peaks. To put it plainly film noise, clicks, pops are as almost as loud as gun shots. Very noticeable on series like Perry Mason where what should close to be inaudible hiss and background noise is at the level of the vocals. This also includes Hogans Heroes. S's are Z's in the vocals.
If you listen close you can hear the background level recover after loud passages. I contact the station engineer and got the typical response that I'm the only one that has complained. I was going to common on their typical viewers technical level, but didn't.
I viewed the same material in another room analog int. amp vs a higher end A/V receiver and get the same results as the engineer tried to blame settings here. No other station or material is this happening and it never did 3 weeks ago. Anyome else notice this of can confirm they do or do not? It's really obvious here, I have to drop my receiver volume 8-10db to compensate the the compression level increase.
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #7624 of 7629 Old 07-13-2017, 10:40 AM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
I guess no one watches or should I say listens to WBBZ here, or no one that is an audiophile?
It doesn't appear to be a local problem thou I'm not sure as local originating material from Clarence (their studio is not in Buffalo) doesn't seem to have the problem.
post #7625 of 7629 Old 07-17-2017, 01:34 PM
pmb1010's Avatar
I dont have cable TV at this house... and I watch all OTA, I've not noticed any issue with WBBZ.
My hearing isn't too good though. I will listen more closely and report back.
pmb1010 is offline
post #7626 of 7629 Old 07-18-2017, 04:14 AM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
It started a few weeks before the date of that post. It's VERY noticeable, it wasn't there before.
With older material (Perry Mason for one example) it's most noticeable. Listen for the background level, it's close to the level of the vocals if not louder sometimes. Film audio noise, hiss, scratches etc. come right thru. Also the audio distortion is greater. I'm not 100% sure it's not local material. Due to the far better audio quality of todays electronics vs 40-60 years ago, if it's there it's no where near as noticeable since the s/n ratio is far superior.
But most important, the overall audio level of their main and 1st sub channel is 7-8 db higher than any other station. I have to reach for the remote to crank it down.
post #7627 of 7629 Old 08-06-2017, 01:10 PM
pmb1010's Avatar
Sound level issue on WBBZ...
Nope, sorry to say but I just don't hear any issues with WBBZ. I listened on the OTA I have at house 1, and on TimeWarner cable at house 2 over the past few weeks. Compared MeTV to other channels. They sound OK to me. But decades of ruining my hearing without hearing protection has left me with sub level acuity... and loads of tinnitus.
I do have audio issues switching to 2-2 Antenna TV... its volume level is much lower than everything else.. I need to crank up the volume to hear that one.
pmb1010 is offline
post #7628 of 7629 Old 08-06-2017, 02:26 PM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
Thanks for the try. The tuners in use don't have a handle on levels to the extent of the difference what I'm hearing.
AFA WGRZ's sub channel, I use to record Johnny Carlson and I did notice the audio level was low, but the difference was nothing near what I hear on WBBZ. I guess no one else watches, or should I say listens to WBBZ around here.
post #7629 of 7629 Old 09-14-2017, 08:12 PM
el gran chico's Avatar
Location: Toronto, ON, CAN (7 million that don't count in Buffalo, NY DMA)
For Buffalo area OTAers who are NFL fans, CTV Two (42.1 CKVP) is carrying the Thursday Night games that are not on either NBC or CBS (NFL Network only)
el gran chico is offline
