Diplexor Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-02-2002, 10:40 PM - Thread Starter
tigerbacker's Avatar
Can you use a diplexor to send directv and ota digital throught the same coax. Circuit city tells me yes and my high end electronic store tells me no. Thanks
GEAUX TIGERS
tigerbacker is offline
post #2 of 9 Old 05-02-2002, 10:45 PM
JamesMH's Avatar
yes, although not as good as two cables.
JamesMH is offline
post #3 of 9 Old 05-03-2002, 11:42 AM
Belcherwm's Avatar
You need two diplexors. One to put the two signals together for the run into your house and a second one in the house that splits the signal back apart before you connect to your system's inputs.
Belcherwm is offline
post #4 of 9 Old 05-03-2002, 12:41 PM
turbobuick86's Avatar
Most, if not all, HD STB's will separate the diplexed signal internally. You can join them outside and bring one cable into your home and into your STB.
Radio Shack has one #16-2581 for ~$20.
Terry
turbobuick86 is offline
post #5 of 9 Old 05-03-2002, 02:12 PM
Chris Blount's Avatar
Quoted: 25 Post(s)
I have 2 diplexors hooked to my system. One on the outside and one on the inside. I use them to get my local digital stations to my STB down one cable. They do cut signal strength from the OTA antenna but not enough to worry about assuming you have a nice strong signal. I don't see any reduction at all in my satellite reception strength.
Chris Blount
Chris Blount is offline
post #6 of 9 Old 05-07-2002, 09:01 AM
Art Lloyd's Avatar
There have been quite a few reports of problems with diplexors. Obviously they do work but are the first place to look if problems occur. Art
Art Lloyd is offline
post #7 of 9 Old 05-07-2002, 06:55 PM
hodgear72's Avatar
I didnt know the stb could seperate for me. Does it matter? Will the Huges 86 do this? I guess it would save 20 bucks.
hodgear72 is offline
post #8 of 9 Old 05-07-2002, 07:33 PM
Page 4.7 of the E86 manual tells you how to use a single diplexor.
post #9 of 9 Old 05-09-2002, 04:08 PM
George33027's Avatar
diplexor do work, but make sure you need one.
Most STB's have 2 inputs, so you don't need a diplexor.
George33027 is offline
Closed Thread Local HDTV Info and Reception
