Updates for HDTV In Toledo, OH? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-04-2002, 04:23 PM - Thread Starter
Nate Thompson's Avatar
Just wondering if anyone has heard of anything about the local affiliates getting their HDTV broadcasting up and running. I had heard something about this Summer a couple months ago, but nothing since. If you have any information I'd apprechiate it.
Nate Thompson is offline
post #2 of 4 Old 05-04-2002, 07:15 PM
Ken H's Avatar
First, you probably can get some, if not all of the 7 Detroit DTV stations.
In Toledo, WNWO-DT (NBC) has been on for a few months. They are on UHF 49, remapped to 24. From the west side of the Detroit area, I can get them fine with my directional roof antenna/preamp.
WTOL-DT (CBS) has reported testing on UHF 17, see this recent post for more info:
http://www.avsforum.com/avs-vb/showt...hreadid=137847
Check out www.titantv.com
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 4 Old 05-05-2002, 07:28 AM
bcolon's Avatar
Ken H
What antenna would you reccomend for receiving the detroit stations from the toledo area. I will need an indoor antenna due to association restrictions, but I do have an attic to put it in.
Thanks for the info!
bcolon is offline
post #4 of 4 Old 05-05-2002, 09:47 AM
Ken H's Avatar
Your association can not legally stop you from having an outdoor antenna. This is based on federal law. For details see: http://www.fcc.gov/csb/facts/otard.html
and do an HDTV search here at AVS for 'homeowners fcc'. You'll find a ton of info.
As far as the type of antenna, a UHF/VHF directional yagi is usually a good solution. Radio Shack has the VU-190XR, typically on sale for about $50. It's 13' long and it's what I use to get the Toledo stations.
To take a step up, look at the Channel Master & Winegard brands available from: www.starkelectronic.com
Stark also has a wealth of basic antenna info.
Also worth investigating:
http://www.antennaperformance.com/
http://www.wade-antenna.com/specs.htm
and the broadcasters choice:
http://www.blondertongue.com/
You will also probably need an antenna preamp, of which the CM & Winegard are popular choices.
Good luck.
Ken H is offline
Closed Thread Local HDTV Info and Reception
