Fox Houston - Is it on 27.1 or 27.2? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-06-2002, 08:33 AM - Thread Starter
merc's Avatar
I've read that Fox changed their DTV 480p broadcast to 27.2, but I am still receiving a signal on 27.1 and my STB does not see anything on 27.2 at all.
Did Fox change their mind about multicasting?
merc is offline
post #2 of 6 Old 05-06-2002, 08:46 AM
hookem's Avatar
Just tried it on my STB, and 27-2 is remapped to 26-2. I get nothing on 27-1.
hookem is offline
post #3 of 6 Old 05-06-2002, 08:59 AM - Thread Starter
merc's Avatar
Thanks Hookum! What STB are you using? I am currently using a Samsung and it only shows up on 27.1 with nothing on 26 at all. The image currently shows the Fox 4:3 image with the Fox DTV- 27 blue side panels. I guess that I need to tune in when 24 or some native 16:9 480p is being broadcast to make sure that I am getting the right stuff...?
merc is offline
post #4 of 6 Old 05-06-2002, 11:53 AM
tumult's Avatar
off the subject, but where do ya'll find pbs in htown? using panny tu-hds20 and all i find is regular pbs on 8-1.
tumult is offline
post #5 of 6 Old 05-07-2002, 06:31 AM - Thread Starter
merc's Avatar
tumult: 8.1 is the correct channel for PBS. Some STBs remap that to channel 9 and my STB has it on 80.3??? Are you sure that your 8.1 is regular PBS and not the national feed that I see on 80.3?
merc is offline
post #6 of 6 Old 05-07-2002, 10:13 PM
Richard Slay's Avatar
Dear Houstonians:
I'm still waiting to hear about channel 20's plans so I can eliminate my last source of analog Dolby Pro-Logic and simply make a digital connection between my STB and my Technics SH-AC500 surround processor. (Ch. 8 is pretty much stereo-only so I can plug it into my passive pre-amp).
R. Slay
Richard Slay is offline
Closed Thread Local HDTV Info and Reception
