Can't find a HDTV schedule for WTTW - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-07-2002, 02:35 AM - Thread Starter
Arpacian's Avatar
I realize that WTTW's schedule does not match the national PBS so, How can find when particular programs are on. I just can from WTTW's homepage and after doing a search I couldn't find several that are listed by PBS national. Does this mean that WTTW will no broadcast certain programs if so why?
Arpacian is offline
post #2 of 3 Old 05-08-2002, 09:02 AM
drb
drb's Avatar
try www. titantv.com. It should give you the schelude of all tv programing, including ditigal, in your area. DRB
I WANT MY HDTV
drb is offline
post #3 of 3 Old 05-08-2002, 09:45 AM
SamR.'s Avatar
Don't rely on TitanTV either, as that only shows National Schedules. If you want local to go, http://www.networkchicago.com/wttw/
SR
SamR. is offline
Closed Thread Local HDTV Info and Reception
