ABC KTRK Houston off the air? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-11-2002, 01:06 PM - Thread Starter
sharpe's Avatar
I haven't picked up an OTA signal for KTRK since last Sunday. I didn't changed anything in my setup and am still receiving the other HDTV stations. I suspect my antenna on a mast may have moved slightly, but want to make sure this is an issue with my equipment before heading up a ladder to move the antenna. Thanks!
sharpe is offline
post #2 of 3 Old 05-11-2002, 07:45 PM
coug7669's Avatar
Quoted: 16 Post(s)
KTRK was off for me too but only for one day. Am using Hipix with no antennea movement. KTRK has a history of going blank from time to time, once for nearly two weeks as a key component broke once. I do not know why you nor I had no reception. Did you try to rescan the channel? Its channnel 32 but gets remapped via the Hipix to 13.1. Right now Notting Hill is on.
coug7669 is offline
post #3 of 3 Old 05-12-2002, 07:49 AM - Thread Starter
sharpe's Avatar
I got it back too. But my Panny STB has never remapped it 13.1, but does so for all the other channels. I suspect the signal is weaker than the others. As long as I get I don't care where the station gets mapped. Thanks for the help.
sharpe is offline
Closed Thread Local HDTV Info and Reception
