Colorado Springs, CO - HDTV - Page 227 - AVS Forum | Home Theater Discussions And Reviews
post #6781 of 6848 Old 11-21-2012, 06:46 AM
lsilvest's Avatar
Hi Scott,
Thought this thread was pretty much dead.
I've never run into this, so I'm guessing it's a software problem more than a tuner issue.
What are you using to record, Windows Media Center or something else. Just out of curiosity, what tuner card?
You'll probably get more response from another forum. There's one just for HTPCs (Home Theater Computers) in the Video Components section.
lsilvest is offline
post #6782 of 6848 Old 11-21-2012, 07:05 AM
scottlindner's Avatar
I don't know if this is a RMPBS issue or an HTPC issue. I will cross post. Thanks!
I'm using Windows Media Center 7 and using an Asus EHC3-150.
I have two dual tuner HD Home Runs but I'm in the process of slowly migrating how things work in the house so this card is more of a transition piece than a permanent part of the setup.
Scott
scottlindner is offline
post #6783 of 6848 Old 11-21-2012, 07:39 AM
pgwalsh's Avatar
Quoted: 363 Post(s)
Liked: 257
Originally Posted by scottlindner View Post
Does anyone know anything about Blind Captioning (please correct me on the term) on RMPBS? I recently rebuilt my HTPC and using a new tuner card and this morning I noticed that a narrator is describing what is going on. Took me a while to realize it wasn't really part of the show itself. I'm recording OTA if that means anything. Is it possible to turn this off? Is it burned into the audio track from RMPBS, or is it a separate closed caption track? Is it the tuner card that is picking this up and my old tuner card did not? I apologize for the ramble of questions. I haven't encountered this before and I don't have a clue how to begin removing it. I did do some searching but couldn't find much on it.
Cheers,
Scott
You should be able to turn it off with either the CC function on your remote or through a setting on your HTPC. I don't know for a fact if it's forced on by PBS, but that wouldn't be normal.
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is offline
post #6784 of 6848 Old 11-21-2012, 07:43 AM
lsilvest's Avatar
I set up my daughter with the same thing you're running - Win 7 MC with the same ASUS card and she never mentioned a problem, but don't know how much she watched PBS, but she was in Longmont at the time and right now she doesn't have OTA hooked up. Have you tried recording on KBDI 12-1, 12-2 or 12-3 to see if you have the same issue?
I still use Beyond TV with XP SP3, so I can't really duplicate anything for you to test it and I'm leaving on a trip in a couple of days. I'll check when I get back and I can test that same card with win 7 on a spare machine if you haven't solved the problem by then. Hope someone on the other forum has an answer.
lsilvest is offline
post #6785 of 6848 Old 11-21-2012, 08:21 AM
chanceG's Avatar
I get both KTSC and KBDI OTA, and I don't have that problem on either one. This on 2xHDHR, Mac Mini and EyeTV.
Chance
chanceG is offline
post #6786 of 6848 Old 11-21-2012, 08:27 AM
It really was only one program that it happened with to date. It is Curious George Very Merry Christmas. It will air a few more times. I plan on recording all of them with various tuners to see why it happened this morning.
post #6787 of 6848 Old 11-21-2012, 09:25 AM
dkreichen1968's Avatar
Quoted: 17 Post(s)
Liked: 31
They are called "Video Descriptions" and they are a new government mandated feature. They should be on a SAP channel. Stations will be mandated to provide a certain number of hours of programming with them each week. About a year and a half ago I had some CBS programming that I recorded off of KCNC Denver using my DTVpal DVR that had the video descriptions and no way to turn them off. I haven't had that problem for a while now, and it may be a matter of the stations getting the bugs worked out of their systems.
It's 2015 and you're still paying for television?
dkreichen1968 is offline
post #6788 of 6848 Old 11-21-2012, 09:34 AM
Thanks for that information. It really helps.
post #6789 of 6848 Old 11-23-2012, 06:40 AM
I recorded the same show the next day and the Video Descriptors are not there. It must have been a broadcast problem and nothing to do with my setup. Thanks everyone!
post #6790 of 6848 Old 01-07-2013, 12:48 PM
lsilvest's Avatar
If anyone is still listening here, I'd like to know if Comcast still has QAM in Pueblo (or even Springs since if they have it there they'll have it here). I'd like to know before ordering for my daughter so she can use an HTPC instead of paying for extra receivers.
lsilvest is offline
post #6791 of 6848 Old 01-07-2013, 12:53 PM
pgwalsh's Avatar
Quoted: 363 Post(s)
Liked: 257
Comcast does have QAM in the springs, but if you use their box you'll only get SD. I don't use a box and I get the stations in HD. In that regards, it's difficult to use a subscription guide for recordings.
Also.. the QAM is only for the major broadcasting stations, everything else is encrypted.
I'm going to switch to OTA as soon as I can man up and get on my 40' latter.
pgwalsh is offline
post #6792 of 6848 Old 01-07-2013, 01:05 PM
lsilvest's Avatar
Thanks for the quick response. I think she'll be able to record with Windows Media Center using the local lineup and at least be able to watch in HD.
Right now she has DirecTV (still under contract) and the 2nd receiver is SD and she mainly watches local channels anyway and can use the main TV and DVR for cable channel recordings. Last time I was able to check, you could actually get Altitude HD through QAM and that was when I only subscribed to internet with them. She's switch to Comcast for internet and right now they have an offer of internet and tv for $39.99 for 12 mos. So, we'll just drop the DTV 2nd receiver and get cable basically for $4 a month and be able to get the qam HD to a 3rd TV which is an LCD which is hooked up to the computer.
lsilvest is offline
post #6793 of 6848 Old 01-07-2013, 01:26 PM
eddie_d_lopez's Avatar
same in pueblo as springs looks like, QAM available direct connect, but only cbs, abc, nbc, fox, spanish language, and wgn-tv in hd. you'll pick up a few other national channels too, but since they're not in hd, there not in my favorites.
SlingTV, E.D.L.
eddie_d_lopez is offline
post #6794 of 6848 Old 01-07-2013, 01:27 PM
pgwalsh's Avatar
Quoted: 363 Post(s)
Liked: 257
I just called comcast because my introductory 1 year offer ended and they raised my rate to $69.00 from $39.99. They wouldn't change it over the phone to a reasonable rate, so I have to go downtown to do as I did before. This time if they are problematic, I may switch to Peak Internet. I can also just cancel for a few days and sign-up again. I wish they'd just offer a good rate all the time.
pgwalsh is offline
post #6795 of 6848 Old 01-10-2013, 03:52 PM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 38
Thinking about cutting the cord.
Currently we pay $110 / month for internet (QWEST), Phone (that we don't use), and HDTV. What kind of OTA stuff is available in the springs and what kind of equipment should I buy? I am guessing ABC, CBS, NBC, Fox, and RMPBS. Wife likes having a DVR to record shows. We don't watch a ton of TV. We could switch to a wireless internet provider for $40/month and that would save us quite a bit. I need reliable internet but it doesn't need to be blazingly fast.
ETA: TV fool confirms that just about any antenna at my house should pick up the afforementioned channels. I was thinking I could get a small HDTV Antenna and mount it where the dish currently resides. It's not that high off the ground but all the wiring is in place and hooked up. Good idea, bad idea? It's about 7' off the ground and I'm guessing pointing south. I do kind of live on the backside of a hill...
djkest is offline
post #6796 of 6848 Old 01-10-2013, 04:13 PM
pgwalsh's Avatar
Quoted: 363 Post(s)
Liked: 257
There's a few extra channels, but nothing to really talk about. I think OTA is a great path and if you want extra content use a media streaming box. I use XBMC and install a plugin called freecable. It essentially parses web sites that post their shows online. It's like a DVR without the dvr. There are several others, like SportsDevil, if you're into sports.
I use internet phone at my house because every wireless provider seems to have poor reception where I live. I use a company called ITPVoip. They have much better rates then comcast etc and excellent support. Their support is so good, that they called me every few days and walked me through and issue, which I later discovered through my own investigation was an error with my access point firmware.
pgwalsh is offline
post #6797 of 6848 Old 01-10-2013, 04:32 PM
lsilvest's Avatar
While you're contemplating the change, Comcast is offering TV+Blast Internet for 12 mos. for $39.99. Hate Comcast, but that's pretty cheap and you could get the locals QAM for HD.
I've been recording for years with an HTPC and antenna, still using XP and BeyondTV which works great, but Win7 MCE will do it for you also. For phone, if you don't need call forwarding, MagicJack is pretty good and only $69 the first year and $29 after. I used it for over 5 years and outside of an occasional glitch it worked great, but they quit doing call forwarding and I switched to NetTalk but have had a problem with calls breaking up that they are trying to help get fixed.
lsilvest is offline
post #6798 of 6848 Old 01-11-2013, 11:09 AM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 38
Thanks for the tip. My wife just informed me that we are currently paying $150 a month. :/ So a change is coming. I could do Dish + Wireless for $85/month + tax but then after a year the DISH goes up by I think $30 or something.
I might look into the Comcast BLAST thing. With Comcast it's really tough to figure out what the "next rate" is going to be.
djkest is offline
post #6799 of 6848 Old 01-11-2013, 11:16 AM
lsilvest's Avatar
With Comcast the next rate will be your firstborn and one kidney.
lsilvest is offline
post #6800 of 6848 Old 04-08-2013, 12:15 PM
Nick in Manitou's Avatar
I am posting this here because I am hoping to be able to assist another Colorado Springs HT builder while reducing the amount of stuff I have to move...
A job change is taking us away from Colorado (for a while, anyway) and I have most of the OC703 that I picked up for the HT.
22 pieces, 2'x4', 2" thick. One bundle of 12 pieces has never been opened and the other bundle has been opened and 2 pieces have been removed but the rest are in the original packaging.
This is an opportunity to get your OC703 without having to worry about minimum orders, etc.
I also have some mass loaded vinyl, some Green Glue and some SC-175 Acoustic Caulk to give away to anyone who can use it!
I hope that I am not breaking some major rules by mentioning this here, but I wanted to get this out to a local audience.
Nick
Nick in Manitou is offline
post #6801 of 6848 Old 04-08-2013, 12:50 PM
pgwalsh's Avatar
Quoted: 363 Post(s)
Liked: 257
Wow... good stuff. I'm on the westside and have a naked room that has some acoustic fiberglass and wallboard, but I'm looking to redesign a the equipment rack area and this may come in use.
pgwalsh is offline
post #6802 of 6848 Old 08-08-2013, 06:14 PM
Quoted: 17 Post(s)
Liked: 31
OEM Parts, off of Hancock north of Fillmore, has a lot of high quality Winegard TV antennas that are a good choice for the Colorado Springs market for less than $20 a piece. Get them while they last!!! wink.gifbiggrin.gif
If you're on the north side, point one north northwest for Denver stations.
post #6803 of 6848 Old 08-26-2013, 06:24 PM
iowegian3's Avatar
A reminder that the Foxy Moms Expo is coming up in October.
Careful with the cougars there, son.
www.therenegaderoadhouse.co Southern rock, pop and country favorites play here!
iowegian3 is offline
post #6804 of 6848 Old 08-27-2013, 08:48 AM
pgwalsh's Avatar
Quoted: 363 Post(s)
Liked: 257
Don't think I'll be watching that one, but thanks for the heads up.
pgwalsh is offline
post #6805 of 6848 Old 10-07-2013, 08:43 PM
gman76's Avatar
Comcast upped my bill about a month ago. Have the DoublePlay package for 118 incl taxes. I talked to them and threatened to leave again. They dont care. It's the tv part that costs so much. I get basic HD service, no DVR, no HBO. I seriously want to go to Dish or DTV. I have 3 verizon cell phones in the family. I know I could bundle verizon/DTV. I will likely keep comcast internet. Any other thoughts/ideas?
gman76 is offline
post #6806 of 6848 Old 10-08-2013, 07:19 PM
Quoted: 17 Post(s)
Liked: 31
Which channels do you actually watch, and what programs?
post #6807 of 6848 Old 10-27-2013, 03:08 PM
gman76's Avatar
Well they did another thing to upset folks. My bedroom tv which has no box or converter now gets ..... nothing. Comcast just cut off all channels in the clear. I'm switching to one of the sat guys. This is the last straw.
gman76 is offline
post #6808 of 6848 Old 10-27-2013, 05:00 PM
oriolesmagic's Avatar
Quoted: 58 Post(s)
Liked: 72
What are you expecting to get in the clear on satellite?
oriolesmagic is offline
post #6809 of 6848 Old 10-29-2013, 10:40 PM
gman76's Avatar
No, I guess comcast just irks me now. The sat guys will charge me for every box. But dont they have a C30 or a Joey (dish) to tune in a separate program? The comcast DTA's were awful since they did SD only. I guess comcast has newer HD boxes, but dont want a big set top box for the bedroom (occasional use). What tees me off is paying $75 for basic HDTV.
gman76 is offline
post #6810 of 6848 Old 11-16-2013, 09:27 PM
Quoted: 17 Post(s)
Liked: 31
There are HD DTAs. I'm pretty sure that Comcast has them. I have seen them for TWC and Bright House, so I'm fairly sure that Comcast has them also.
Edit: I just remembered I know for sure that they have HD DTAs and I've seen them with my very own eyes.
