FOX KTXL Sacramento is Down? Or just rain fade? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-19-2002, 05:21 PM - Thread Starter
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
Getting very jumpy reception, if any at all. Stays at Zero for minutes at a time, then jumps to 50% or 75% for a half a second, then gone again.
Anyone one else?
Guess I'll have to check the weather for tonights big X-Files Finale.
Hammer
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is online now
post #2 of 11 Old 05-19-2002, 06:06 PM
Garrett Adams's Avatar
Quoted: 950 Post(s)
Liked: 1026
Receiving 40.1 fine down here in Stockton.
Garrett Adams is offline
post #3 of 11 Old 05-19-2002, 06:29 PM - Thread Starter
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
3-1 89%
10-1 83%
13-1 87%
40-1 00%
Hammer
post #4 of 11 Old 05-19-2002, 09:36 PM
JarredInTheHouse's Avatar
No problems for me in Stockton.
JarredInTheHouse is offline
post #5 of 11 Old 05-19-2002, 10:28 PM
Mike KE6HDV's Avatar
Watching the 10 o'clock news on KTXL, no problem signal is usually between 82-85 depending on conditions.
Mike KE6HDV is offline
post #6 of 11 Old 05-20-2002, 06:26 PM - Thread Starter
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
Very strange. Must have been weather related. The signal did slowly come back, and by 8p it was at normal levels with only an occasional drop out.
Hammer
post #7 of 11 Old 05-20-2002, 09:28 PM
SteveD's Avatar
I know the weather is awful tonight, but ZERO signal on all 4 channels? I usually get 100 signal strength from Granite Bay. I'm concerned that something else is wrong... maybe water on the coax or something? My analog reception is also very snowy - barely a picture on 31, 40, or 58.
SteveD
SteveD is offline
post #8 of 11 Old 05-21-2002, 12:06 AM
SteveD's Avatar
Well, one problem solved - I had a loose coax connector going from my pre-amp power supply to my tuner.
But, still no digital reception on 3 of the 4 Sacramento stations. My current signal strengths from my DST-3000 at 12 midnight on Monday (still raining, but it's let up quite a bit):
13-1 (dig. 25): 100
3-1 (dig 35): 15-18
40-1 (dig 55): 0-6
10-1 (dig 61): 0-6
Any ideas? I just moved to the area and this is the first storm I've had since I moved. If this is weather related, I'm very bummed. Funny thing is, I moved from Pleasanton and, although my reception was much weaker overall I didn't seem to notice much weather interference.
By the way, my reception in general has been excellent. 100 signal strength almost all the time on all 4 stations. On some evenings, I even get SF stations, and I'm probably 100 miles away!
My antenna set-up is CM 4228 (8way bowtie) with a CM 7775 pre-amp connected to a DST-3000.
SteveD
SteveD is offline
post #9 of 11 Old 05-21-2002, 12:34 AM
bigsmoniz's Avatar
At the position I used to recieve KXTL-10, I now get two Channel KOVR-13's. This has been going on for a week or so.
bigsmoniz is offline
post #10 of 11 Old 05-21-2002, 12:50 AM
bigsmoniz's Avatar
Let's try this again. In the space I used to recieve KXTV-10, I now get a duplecate of Channel KOVR-13. This is coming off the Dish system with the 6000 and the over the air modual. As I said, this has been going on for a little over a week.
Anyone else having this problem? Is there a way to reset the 6000?
post #11 of 11 Old 05-23-2002, 12:53 PM
bnam's Avatar
SteveD,
Try without the preamp -- I get 90-100% with the same antenna in Folsom.
Byas
bnam is offline
Closed Thread Local HDTV Info and Reception
