Problem with Enemy of the State in Seattle - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-20-2002, 08:18 PM - Thread Starter
IssaquahHD's Avatar
Is anyone else having a problem with the audio for Enemy of the State in Seattle? I get a perfect picture, but a bunch of popping instead of audio. Is this a problem I am having or an overall problem? I am using a Sony HD100.
IssaquahHD is offline
post #2 of 6 Old 05-20-2002, 11:05 PM
darmad2002's Avatar
I had the same audio problems on my Zenith DTV1080. It lasted about 20 minutes then was corrected. Not sure what happened.
Darryl
darmad2002 is offline
post #3 of 6 Old 05-21-2002, 12:33 AM
Jolly1's Avatar
Totally unwatchable with the sound screwed up. Checked back later to see that they had switched from HD to 4x3 SD. Watched a DVD instead.
Looks like yet another local problem from KOMO as no one else from around the country seem to be reporting problems. I've been told that they have state-of-the-art equipment.
Jolly1 is offline
post #4 of 6 Old 05-21-2002, 08:21 AM - Thread Starter
IssaquahHD's Avatar
It was 4x3 SD till about an hour into the movie when they finally got the HD and Dolby Digital to work. I have noticed a lot of audio problems the last couple of days on KOMO. At first I thought it might be my equipment, but it looks like they are having problems. Anyone have anymore information?
post #5 of 6 Old 05-21-2002, 07:45 PM
jsnides's Avatar
Recorded the movie with my HiPix.
Watched it today. All was good. One of the better broadcast for DD 5.1, really put the surrounds to work.
jsnides is offline
post #6 of 6 Old 05-21-2002, 08:31 PM
erdc's Avatar
You can call KOMO technical personal directly at 206-404-4073 if you are having problems.
erdc is offline
Closed Thread Local HDTV Info and Reception
