Milwaukee stations in lincolnwood? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-10-2012, 07:41 PM - Thread Starter
Ngnr's Avatar
I've read that it's possible to pull in Milwaukee stations in lincolnwood, but seems to be more of a sales pitch. Folks here know their stuff...so is it possible? If so, what would recommended setup be? Thanks in advance. PS: have 2 story house so 30' high setup is doable.
Ngnr is offline
post #2 of 6 Old 07-10-2012, 09:30 PM
BCF68's Avatar
Post a TVfool report http://www.tvfool.com/?option=com_wrapper&Itemid=29
but going by a general TVfool look-up of Lincolnwood you shoudn't have any issues.
BCF68 is offline
post #3 of 6 Old 07-10-2012, 09:33 PM
FSugino's Avatar
Quoted: 20 Post(s)
You should ask in the appropriate message thread, in this case Chicago, IL - OTA . Check this message for more info on how we organize and post messages here.
Flicks? Here's my collection. And I've seen a lot, too.
FSugino is online now
post #4 of 6 Old 07-11-2012, 04:59 AM
BCF68's Avatar
Since he was asking about Milwaukee stations I assume he lived in Wisconsin.
BCF68 is offline
post #5 of 6 Old 07-11-2012, 05:07 AM - Thread Starter
Ngnr's Avatar
Thanks all. Appreciate the advice. I'll switch to the Milwaukee firm, sorry about that.
Ngnr is offline
post #6 of 6 Old 07-11-2012, 12:49 PM
dave73's Avatar
He lives in Lincolnwood, IL, a nearby northern suburb of Chicago, near Evanston & Skokie.
To the OP, it is possible to pull in Milwaukee stations. However, since you live close to Chicago, it will be a challenge to get some stations, since some Chicago translators & other LPTV stations broadcast on the same RF channels as some full power Milwaukee stations. If you want to try, you need a deep fringe VHF-HI/UHF antenna & a pre-amp, & only use that antenna for Milwaukee stations. The UHF end must be pointed toward Milwaukee. For Chicago stations, you need a much smaller VHF-Hi/UHF antenna & no pre-amp pointed somewhere between the John Hancock & Sears Tower (or point at just the Sears Tower, since WYCC is the only full power English language station that broadcasts from the John Hancock (WGBO is the other full power station broadcasting from the John Hancock, but in Spanish). You'd join both antennas into an A/.B switch. Depending on the converter box or TV tuner, you might have to rescan everytime you switch antennas.
dave73 is offline
