$$$$$$ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-08-2012, 11:22 AM - Thread Starter
sarasdad's Avatar
I am looking for a way to lessen the cost for cabel without loosing my choices. I have 3 DVR'S and at 6 or 8 dollars rental each it adds up.
Can you have your own dvr box and is that possible to do without paying rental to Brighthouse?:cool:Thanks
sarasdad is offline
post #2 of 4 Old 08-08-2012, 02:09 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Yes and no. You'll still have to rent CableCARDS (at the tune of $2-$4 per device), but no DVR rental fees or monthly service fees to the cable company.
domino92024 is offline
post #3 of 4 Old 08-09-2012, 07:17 AM
BCF68's Avatar
Why do you need 3 DVRs? Is there really that much to record?
BCF68 is offline
post #4 of 4 Old 08-09-2012, 09:24 AM
rdoac's Avatar
You may be able to replace all of them with an HDHomerun prime, 1 cable card and Windows 7 machine as a server, then use XBox360s on each TV as frontends. I have never used this configuration so can't vounch for it, I use MythTV and OTA, but in theory you should be able to get all your channels including those marked Copy Once this way.
rdoac is offline
