Nashville, TN South of Franklin? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-24-2002, 01:15 PM - Thread Starter
dbroome's Avatar
I just got my DST3000, and am loving HDNet. I just read that ABC went live today and CBS has been live for awhile now. Anyone here live in Frankl;in or south in Thompsons Station that can give me an antenna suggestion?
dbroome is offline
post #2 of 6 Old 05-24-2002, 07:42 PM
RaggedEdge's Avatar
You're pretty close to the transmitters. Any indoor antenna would probably work. I have had good luck with the Radio Shack Indoor BowTie Antenna. You can pick it up at your local Radio Shack for about $20.
Alex
RaggedEdge is offline
post #3 of 6 Old 05-24-2002, 11:31 PM
Hjohn's Avatar
Quoted: 14 Post(s)
I live in Franklin and tried 5 different antennas to get CBS. Go to Randolph and Rice in Nashville or Columbia and get the Channel Master(4221?) Double Bow Tie. Trust me, after a week of aggravation with antennas this one is the best.
Hjohn is offline
post #4 of 6 Old 05-25-2002, 10:29 AM
Jon J's Avatar
Quoted: 29 Post(s)
Liked: 59
Hjohn is correct. CBS south of Nashville is hit or miss. A Brentwood poster pegs the needle with a bowtie while others about the same distance but with different terrain need a 10 foot yagi.
I initially tried the Channel Master 4-bay bowtie and ended up using the 8-bay version because of some hill problems. So, I've got a 4-bay for sale. Drop me a private message if you are interested.
Jon
When news breaks...we fix it.
Jon J is offline
post #5 of 6 Old 05-25-2002, 03:13 PM
Greg_Smith's Avatar
I live 2.8 miles SW from the WKRN-DT antenna and can't get my panasonic tu-hds20 STB to receive the DT broadcast using a modified RS-DBT antenna on my roof. WTVF-DT which is 17.8 miles N comes in fine. Unfortunately my panny STB doesn't have a signal meter.
Greg
Greg_Smith is offline
post #6 of 6 Old 05-27-2002, 03:04 PM
Greg_Smith's Avatar
Closed Thread Local HDTV Info and Reception
