More channels upstairs than down - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-07-2012, 08:20 AM - Thread Starter
sstroyer's Avatar
Just installed antenna (RCA ANT751) in attic, including a pre- amplifier (RCA TVPRAMP1R). Reception is GREAT on upstairs TV closest to antenna and am receiving all channels I should be. On the TV downstairs though, I am not receiving NBC, ABC, and FOX.
The length of run downstairs is probably on the order of 75 feet of cable (RG-6 quadshield). Is it likely my pre-amp is too small?
I used antennaweb.org to find optimal pointing direction and I am pointed there. I tried about +/- 30 degrees of the recommended bearing with no change. The antenna install instructions say to point the small end of the antenna toward the stations you want to receive. They don't mean the nub sticking out from the mast attachment point as the small end of the antenna do they? If so, I'm 180 out, but probably thinking that's not the problem.
The TV downstairs is new, but not so zesty (Colby 19"). Is it possibly a TV problem- weak tuner? I'm thinking probably that's not the problem either though.
Anything else it could be? Any suggestions? If I need a stronger pre-amp, any recommendations?
Thanks and any help greatly appreciated,
Scott
sstroyer is offline
post #2 of 4 Old 10-07-2012, 08:27 AM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
Can you take the Coby upstairs & connect to the upstairs outlet? This would be the best starting point.
Digital Rules is offline
post #3 of 4 Old 10-07-2012, 10:28 AM
ProjectSHO89's Avatar
Quoted: 279 Post(s)
Liked: 130
Nope pretty unlikely. More amplifier power is rarely a needed attribute in simple installations.
More probable is that you have either a defective cable, splitter, or connector or it might just be a lousy tuner in the Coby.
ProjectSHO89 is online now
post #4 of 4 Old 10-08-2012, 05:40 PM - Thread Starter
sstroyer's Avatar
Eureka! It was an old splitter that was the problem. Thanks for the replies guys- you saved me a ton of needless effort and expense chasing this one down.
Best regards,
Scott
sstroyer is offline
